Question about ASUS M2N32-SLI Deluxe/Wireless Edition ATX Motherboard (1254095)
Second display not working
I have asus m2n-sli deluxe motherboard wiyh two pci-e slots.I insert two pci-e nvidia graphic cards in two slots. but only one slot is working .
  • chalasani Dec 15, 2007
    please give me a sugession
  • agask2 Nov 09, 2008
    my slot 2 appears not to work with the geforce 8800GT. Both cards work in slot 1. device manager only detects one card.
I think the cards have to be SLI ready. They use an additional bridge in installation. Therefore to be able to use dual video cards they must both be the same SLI compatible model.
Posted on Aug 09, 2008
    Champion:
  • 238 Answers
Hi check for the BIOS settings for having both the cards work ..if not then try interchanging the card & slots with each other to check if one of it is faulty?
Bye Let me know
Posted on Dec 15, 2007
I bought 4gb Ram aditional to reach a top 8gb Ram for my ASUS M2N-E Sli and since then i experienced some problems, like Blue Screens, blackouts when i Scroll on my Firefox or some black rectangules...
i just looked at the specs of your motherboard it will support 2 graphics cards are/do you have both working or using only one you might need to check and make sure they are securely seated or remove the card/s and make sure the socket/s are clean and dust free the blue screens has me concerned
Support two identical NVIDIA SLI-Ready graphics cards (both at x8 mode)
ASUS two-slot thermal design
If your computer came with a motherboard disc the drivers could be on it
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers
Want to make sure your drivers are in place and no errors have occurred? Simply click start right click on my computer select properties then select device manager scroll to Display Adapters and click on the small "+" you should see the model of your PCI Express graphic card there. If there is a problem with it, a yellow exclamation mark should appear besides it. If you don't see it everything is OK and your card is working properly.
Jun 25, 2011 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Need m2n sli drivers..help?
Your SLI drivers as you mentioned were installed when your chipset drivers were installed. (NVIDIA nForce CK804 Chipset Driver).
If you use 1 PCI-E graphics card the bios will need to be adjusted to [Auto].
Using 2 PCI-E graphics cards you must install the EZ selector card correctly. See page 4-20 section 4.4 Adjust; SLI Configuration. Than see section 4.4.6 in your manual
Open the Asus link below if you need drivers for your M2N-E SLI;
http://www.asus.com/Search.aspx?SearchKey=M2N-E%20SLI
This may seem a bit tricky but its not. First time around the bios settings using SLI graphics cards will appears tough but you'll get it.
Cheers!
Mike
Oct 16, 2009 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Asus m2n sli deluxe sli 1 is 16 and 2 is 8 how to work 8 8
THIS MAY BE THREE WAYS ONE IS THREW THE BOIS
AND
JUMPERS ON THE MOTHERBOARD
VEDIO CARD
AND
SOFTWARE DRIVEN FOR THE MOTHERBOARD AND VEDIO CARD
THE MONITOR TOO [DRIVERS]
PROPERTIES, ADVANCE SETTINGS
IF YOU NEED MORE INFO PLEASE CONTACT THREW THE WEB SITE
ROD
Feb 05, 2009 | ASUS M2N-SLI Deluxe Motherboard
Asus a8n sli premium
From the Asus support site.
If you installed total 4GB memory, the system will detect less than 4GB of total memory because of address space allocation for other critical functions, such as:
- System BIOS (including motherboard, add-on cards, etc..)
- Motherboards resources
- Memory mapped I/O
- configuration for AGP/PCI-Ex/PCI
- Other memory allocations for PCI devices
Different onboard devices and different add-on cards (devices) will result of different total memory size.
e.g. more PCI cards installed will require more memory resources, resulting of less memory free for other uses.
On a SLI system, since PCI-Ex graphic cards will occupy around 256MB, another 256MB will be occupied after you install a 2nd PCI-Ex graphic card. Hence, 2.75GB memory left only if two SLI cards installed on A8N-SLI Premium while 3.0GB memory left with one graphic card without other add-on devices.
This limitation applies to most chipsets & Microsoft Windows 32-bit version operating systems.
If you install Windows 32-bit version operating system, we recommend that you install less than 3GB of total memory. If more than 3GB memory is required for your system, then below two conditions must be met: 1. The memory controller which supports memory swap functionality is used. Chipsets later than Intel 975X, 955X, Nvidia NF4 SLI Intel Edition, Nvidia NF4 SLI X16, and AMD K8 CPU architecture support memory swap function. 2. Windows 64-bit OS which can address more than 4GB memory.
Jan 06, 2009 | ASUS A8N-SLI Deluxe Motherboard
Graphics card no display, not recognised
Hi DarkPredUK.
You need to check you're bios. (See below).
The PCI-E card (Single video card) must be placed into slot, PCIEX16_1 as shown on page 2-3 & 2-18 in you're user manual. The bios must be set correctly as seen on page 4-26 to PCI-E first. You must have two PCI-E cards installed to run SLI mode. (They must be exactly the same graphic cards).
Asus M2N-E SLI main web site/drivers, manual ect.
http://support.asus.com/download/download.aspx?modelname=M2N-E%20SLI&SLanguage=en-us
Good luck DarkPredUK.
Need more info? Post it here or click the Ask Me.
Mike
Jul 11, 2008 | Computers & Internet
ATI Radeon HD 3870 problem
Hate to dash your hopes, the chipset (northBridge) is Nvidia and the PCI express slots are also controlled by the Nvidia chips, the 2 pci-express are nvidia-sli supported.
manual
Page XI (11 of 140) Also page 18 (38 of 140)
and finally
Apr 15, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Describe your ASUS A8N-SLI Deluxe nVidia video card
Yes, you do. Your board was built with the idea to use 2 graphic boards to get great video
NVIDIA® SLI™technology revolutionizes PC performance by combining multiple PCI Express GPUs in a single and scalable system! Gamers and hardcore enthusiasts know that dual GPUs mean increased, supercharged 3D graphics and performance
Dec 09, 2007 | ASUS A8N-SLI Deluxe nVidia nForce4 SLI...
Compatible AGP at 16x?
After a brief check of motherboard specs, what I see is, the 7600GT card will run at 16x in the 16x slot, but if you have TWO SLI cards they both run at 8X. Makes sense. Unless there is a public outcry concerning this, I'd suspect the info you have is a bit off. ZT3000 "Beta tester of "0"s and "1's"
Aug 20, 2007 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
ASUS M2N32-SLI Deluxe/Wireless Edition ATX Motherboard (1254095) Logo
103 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
