Question about LG Cell Phones
LG KG25 My daughter phone is asking for "enter security code" when she turns it on. Have tried default code of 0000 with no luck and also 1234 with no luck. Please help before she throws it at the wall. Unable to get past the screen asking for code.
Mine was the last four digits of my phone number.
Posted on Aug 19, 2008
I believe it's a 6 digit solution, try 000000
It worked for me, then I was able to customize what I would like instead.
Posted on Aug 12, 2008
My LG KG110 is not switching on asking for a security code what is it i tried all the no's i know bt its not working
You have to enter the default security code
Default will be 0000 or 1234 or 12345 or 00000(For default code check user manual of user handset).
If these won't works somebody changed security code.
To reset security code you need to flash your handset
To flash you need *USB cable compatible with your handset *A C omputer *PC suite of your handset *Internet connection(Min speed 1Mbps)
To flash *Install the PC suite *Connect to USB *Open the PC suit *Select UPDATE PHONE SOFTWARE**
**Please don't disconnect while updation process
Jan 17, 2011 | LG KG110 Cellular Phone
Reset lg versa
Tap “Menu” then tap “Settings & Tools” – “Phone Settings” – “Security”, for security purposes, enter in the last four digits of your wireless number (default), “Reset Default”, It’s done. PS: Restore phone is a complete reset, you will lose everything saved. ex. contacts etc..
Also, default codes can vary. If the last 4 digits of your phone number does not work try: 1234 or 12345 or 0000 or 0000
Feb 03, 2010 | LG VX9600 Cell Phone
Lock phone and forgot unlock code
Try entering the security code. The security code is supplied in the manual. If it doesn't work, try a hard reset. If it doesn't resolve yet, try a Firmware upgrade. It may not work ( Firmware Process ) as you can have a upgraded Firmware already. In that case, try to contact the Lg Service Support. They will update the phone to its default settings and will also make the phone's lock code defaulted. Thus enabling you to only entering the default code ( which is normally 1234, 12345 or 0000 ).
Thank you Sir, Have a nice day.
Sep 24, 2009 | LG VOYAGER VX10000 Cellular Phone
Hello
yes for the first security code it is default, try 12345, or 1234 or 0000, or 00000 then put in your own when its ask for a new security code ok
Jun 29, 2009 | LG CU500 Cellular Phone
LG CE 0168 phone security code
If your phone is blocked. You will have to take it to your nearest network provider outlet to get it unblocked.
If your sim card is blocked. You can go to your network suppliers website, where you can obtain the puck code to unblock the sim.
Dec 04, 2008 | Cell Phones
Locked Motorola SLVR L7 cell phone
When your phone is asking for the unlock code you will see that you can press the menu button and after that you will be prompted to enter the security code.
Security code - 000000
Unlock code - 1234 or 0000
These are the standard codes for a SLVR L7. Good Luck
Sep 06, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Lg cu400 cell phone IMEI # 011071003749585
The default lock code (security) is 0000. and default, PIN1 is 1111, and PIN2 is 2222
If you need further help let me know. If you get it wrong enough you will be asked to enter PUK code. Then you only need to call up your provider and they will assist you.
Thanks,
Lee
Jun 19, 2008 | LG CU400 Cellular Phone
LG KG800 Cellular Phone chocolate
use the last four digits of your phone number
Dec 25, 2007 | LG KG800 Cellular Phone
LG CE 0168 phone security code Lock
have you left the phone off for 24 hours if you switch it on and it is asking for security code i can get the master override code for your phone but i need the imei number and the code number off the back of your phone under battery the imei is 15 or 16 numbers long might be like123456/44/22343/2 and then the other one is about 6 numbers long 123456 if you give me these i can give you master code if your phone dont ask for code then you need to get it flashed at a shop to unlock it hope this is some help
Oct 29, 2007 | LG CU500 Cellular Phone
Cell Phones Logo
57 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
