Question about Dell E173FP 17" LCD Monitor
Brightness and contrast screen in center of monitor and can't remove it
I have a dell monitor and the brightness and contrast screen keeps popping in the center of my screen and i cant't remove it why?
  • 4 more comments
  • Anonymous Apr 17, 2008
    i cant remove luminance to my monitor. what should i do to remove it?
    what should i do to remove the contrast in my monitor?
  • Anonymous Mar 16, 2014
    "brightness contrast pop" problems on viewsonic
  • Anonymous Mar 19, 2014
    brightnes/contrast window appears and flashes
  • Anonymous Mar 21, 2014
    I can not seem to get the Screen Brightness and Contrast correct, screen seems to bright Philips 221v, tried re set to factory, no luck. can you come up with a solution to my problem
  • Anonymous Mar 25, 2014
    contrast / brightness screen keeps popping up
  • 238 Answers
The micro switches on the monitor are getting short which is triggering the menu, try to clean it with a switch cleaner or check if the switches can be replaced, do this only if u r an expert in handling things like this or take some proffessional assistance.
Posted on Dec 15, 2007
Change brightness
The second button from the left on the bottom corner by the power button is the brightness button. If you press it the brightness menu is pop up on the screen. With the menu up you just use the three buttons on the left to select the function and the increase or decrease the brightness and contrast on the monitor.
Aug 07, 2013 | Dell E178FP 17 inch LCD Monitor
I have a dell crt monitor. Luminance Temperatura pop up on the screen and it go on and off. Sometimes contrast or bright appear on bottom of the luminance temperature. How do I fix?
Sep 01, 2010 | Dell E773C 17" CRT Monitor
Contrast/Brightness Menu repeatedly pops on screen/won't go away
What kind of system do you have there? Regular PC + monitor or All-in-one/Laptop?
Dec 30, 2017 | Dell E172FP 17" LCD Flat Panel Monitor
Brightness contrast pop problem
one of the buttons will have dust in it causing it to trigger randomly or it is faulty take it apart and replace the buttons, make sure you do all otherwise it will still do it the work on impedence and they are all in series
May 28, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
The brightness/contrast menu keeps popping up and scrolling through the exit, brightness and contrast options. It is a Dell E173FP monitor. I have tried disconnecting and reconnecting the cables and...
Try pushing the buttons for the brightness if it does the same thing you need to replace it, the buttons might be damaged already by pushing too hard or it got stuck.
If this is just a new LCD monitor about 1 to 2 years old contact tech support of dell so you can get this replaced.
Jan 30, 2010 | Dell E173FP 17" LCD Monitor
Brightness/contrast window pops up and scrolls through fast
The up/down button on your flat panel is stuck. Please contact Dell Technical Support to have the monitor replaced if its still within warranty.
May 28, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Monitor control panel keeps popping up on screen
hi..if you soldering iron or do you have a electronic technician you need help him.the defective parts need to replace is Tack switch inside the CRT/Monitor..Thanks and Good Luck...^_^
May 10, 2009 | Dell E551 15" CRT Monitor
Dell E173FP 17-inch Flat Panel Color LCD Monitor
The dell monitors are bad with capacitors going out, check caps in power supply and video board. You can use a can of freeze, it would be easier that way. Just be careful not to touch anything, because these monitors can shock easy.
Sep 06, 2006 | Dell E173FP 17" Flat Panel LCD Monitor
Dell Ultrasharp 21' monitor
I had the same issue. I pressed and hold the + button and the monitor did an auto adjust and the pop up stopped.
Aug 23, 2006 | Dell UltraSharp 1702FP 17" Flat Panel LCD...
Dell E173FP 17" LCD Monitor Logo
936 people viewed this question
Alun Cox
