using headphones to make calls while playing music on the same computer at the same time. i have 2 outlets for speakers 1 is at the back of my cpu and the other is in front. i want to use the latter for my loud speaker so that i can play music while im using the the other outlet with my headset while making calls at the same time.
Depending on the type of case and motherboards you have this may vary. normally the secondary audio connections are located near the front usb pins on the motherboard they look like these
these are connected in this order from left to right red-white-green-black.
On other mboards the audio connections are a straight . . . . .
and usually the plugs on the case for these are connected to one another also connected by red first on the left. Let me know how you go. thanks
Ive just looked at the specs for two motherboards 1,Asus P6T Deluxe V2 2,Asus M4A785TD-V EVO. WHATS...
(More)
Ive just looked at the specs for two motherboards 1,Asus P6T Deluxe V2 2,Asus M4A785TD-V EVO. WHATS your views on these boards as to building your own computer etc?
i have a pi945gcm mercury motherboard and i have lost the cd which comes with it. I need to install...
(More)
i have a pi945gcm mercury motherboard and i have lost the cd which comes with it. I need to install the audio and display drivers
I removed and replaced the 5v jumpers on an Asus p4p800 mb and now USB is hosed. Should I clear the...
(More)
I removed and replaced the 5v jumpers on an Asus p4p800 mb and now USB is hosed. Should I clear the cmos?
By fault I have inserted the DDR ram in the wrong direction and switched on the system. It didn't...
(More)
By fault I have inserted the DDR ram in the wrong direction and switched on the system. It didn't start. Then I found the fault and corrected it. But now still the system is not working and it emits a "beep" sound. Is there anything I can do?
