Question about Panasonic CT-36SX31 36" TV
Need to ask how to Repair my TV.
I have a 36" Panasonic Flat Screen TAU that was made in mexico in 2002 by the way of canada (Go Figure). When you plug it in you can use the remote to turn it on but it just clicks and crackles for a second and goes off or it seems the remote won't do anything it has to be unpluged for a few seconds and if it is plugged back in it will do the same thing again. I took off the back to check it out and blew the dust out and found that if I tap on a relay marked RL801 it clicks and does the same thing but does not come on. When I tap on the relay it lets off a tiny spark. Copuld the problem be the relay or is it preventing a bigger problem ? Could the Fly Back # PVRM081A1-2603 be the problem? Please Help Me So I may repair myT.V. and Thank You for your time. P.S. I also need a parts guide and repair manual for circuit board # 2NP2AH027.
I have bought the same tv used from someone for what sounds like the same problem... if the cable input was being used the TV would click off after a few mins.... thus leaving them to think the TV was only good for gaming; by using the RCA inputs. ... of course you can always use the same RCA inputs for cable tv by using a vcr or digital cable box to tune your stations... how ever it turnd out that the CT-36SX31CE has two cable inputs (ANT1 and ANT2) . when i used ANT2 the TV works fine, leaving me to belive these are two seperate tuners. However inorder to use ANT2 input u must turn it on in the menu. (thus leaving ANT1 off)...do this by pushing "action" button, then "setup" , then "prog chan" then goto "antenna" and change it to ANT2, exit by pushing the action button a few times. Now when selecting different inputs using the TV/VIDEO button the ANT2 input will take the place of ANT1.
hope this helps someone.. :)
Posted on Jan 08, 2009
I have received this TV from my boss who said it was done in, so I took it to the audio store I deal with and it was repaired. It was a heated power problem.
Panasonic 36" Tau 2002 year made, MDL CT36Sx31CE
Problem I have is that there is no remote for it and I cannot get a universal one to work with the tv system.
Is there a place in Brampton, Ontario that I can get one for this TV??
Thank you
Posted on Sep 21, 2008
  • 934 Answers
Check F801 for open and if open replace with 6.3a 250v slo-blo...
If open and replacement slo-blo opens immediately suspect audio Ic2301 Part Number # An5277. Ic shorts and drags down 30v line stressing main fuse.
Always replace C832 using a 35v 220mf. (original is16v/220mf).
Also, another possibility could be the deguass thermistor D808 P/n# D4ddf1r50001 but try the above first.
Bill
Posted on Dec 15, 2007
Dead TV ; No power led ; has 12 & 24 volts at power supply .
I would recommend calling our Product Support Team, so you can schedule repairs at:
U.S. and Canada - 1-877-467-4289
Mexico - 01-800-926-3000
We're here to answer your requests daily from 7 am - 12 am CT.
However, if it requires repair, it may be more cost effective to purchase a new TV.
Oct 22, 2013 | Insignia NS-L42Q-10A LCD TV
Insignia bluray/tv combo 2009 player read error
Disc(s) could be damaged. If this is not the case, then you would need to setup repair service by calling
Oct 08, 2013 | Insignia NS-LCD37 37 in. LCD TV
24" Panasonic Tau... about 9
Tv is old the tv CRT-(tv tube) it CRT Yoking circuitry not good as before.The tv deguassing coil in not eleminating all the interference of the tv functions anymore.Move the tv unit to the right or to left like about 3 or 4 inches either sides will help for this problems.
Apr 18, 2011 | Panasonic CT-24SL13 24" TV
IS IT DELL 2606C TV LCD WORKING ON PAL SYSTEM?
U bought it in Euroupean,Asia countries?Yes,it will all those regions countries run on PAL frequincies.If u bought it in the US,Mexico and Canada.No the tv will not run on PAL or any PAL devices.The US,Mexico and Canada run on NTSC and NTSC devices only.
Jun 01, 2010 | Dell W2606C 26 in. HD-Ready LCD Television
Have a panasonic tau tv that remote codes don't work
Try a "1" in front of those codes; i.e., 10250 or 10051. Worked for me first try after an hour of frustration and failure. Woo Hoo!
Feb 21, 2009 | Televison & Video
PANASONIC 36" TAU --- NEED HELP
Sounds terminal. Companies build things with "planned obsolescence" in mind. In other words. You buy a TV today, and the warranty says it's good for 4 years. 4 years and 3 months later, it dies.
I hope someone else can help you.
Good Luck!
Apr 01, 2017 | Panasonic CT-36D32 36" TV
Panasonic TV will not power up when power button pressed
caps in power supply failed look for 1000 mfd 16 volte caps.
Apr 13, 2008 | Televison & Video
Color adjust on panasonic tau flat screen ct36sl13g
Good day.
Try to have the circuitry of your tv resoldered because I think there are loose connections in the unit causing a single color to be dominant.
chris
Nov 01, 2007 | Panasonic Digital Video Duplex, Color...
Panasonic 36HX41E Tau 36" HDTV Won't turn on
i think line out put transformer is leaking high voltage.if u r nat an technetion then dont try to on tv agin because high voltages can damage several costly ic in the set.
May 25, 2007 | Panasonic CT-32HX40 32" TV
Open Questions:
Panasonic CT-36SX31 36" TV Logo
482 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
