Question about SanDisk Sansa m240 MP3 Player
I cant change any of the songs on my mp3!!!
My pc manages to recognize my mp3 via usb ...
but then when i access the sandisk on the F drive i cant get any of my music. i cant delete, i can only add.
when i use the other connection mode, my pc doesn't recognize it.
what the hell is going on???
  • Anonymous Dec 15, 2007
    I need to find the software to download and get music off the mp3 player
  • koby12 Dec 16, 2007
    Hi there. I am unable to delete any of the songs on my sanasa m240
    please help
    Jennifer
    Sergeant:
  • 239 Answers
Try it in your realplayer and see if you can add and delete there after you syncronize it, Try that see if it works for you, Hope so, also if you do manage to hook up with usb go into the setting and check and make sure that all options are check that you want to work, If you see that there is a way to let the sanddisk manage music on my sansa or you can do it, If sandisk is managing it, It will not let you add music, so change that and see if that helps ya out, You may also notice that there is another way to connnect in the sandisks options again, I hope that gets you up and saving music, Take Care and Happy Holidays
Posted on Dec 15, 2007
I dont have sandisk driver for my sansa E260..i cant transfer songs..
Sansa Not Recognized: Try connecting it to the back of your computer or another computer the back straight to the motherboard this should be USB 2.0 and see if it will recognize it as sansa or Drive/removable drive. if it does then download the sansa update software and install it. Make sure you disconnect the sansa and connect it when asked. This will update your sansas firmware and add the Usb Mode. Try to connect it to your computer at home it should recognize.... link for update software (http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) download to a flash drive much easier. Make sure USB mode is MSC
Recovery Mode may also allow your computer to recognize the sansa
lock your sansa hold in the rec key on the left at the same time push the menu/power button this will take you to recovery mode then connect to the computer Start the update software when finished disconnect.... Sync to upload songs to the sansa......Hope this works
Dec 01, 2010 | SanDisk Sansa e260 MP3 Player
No pc recognizes the V-touch 8gb mp3 player by Visual Land
Windows xp, Vista, and Windows7 should already have a driver included for the v-touch. It's possible that if your computer has a compact flash card reader, that it maybe preventing the v-touch driver from being correctly installed. Try using the "Safely remove Hardware" to temporarily remove your cf card reader. Then try plugging in your v-touch. It should now correctly install the driver and the v-touch will show up as a new drive. In Windows Device Manager under "Disk Drives" you should see 2 new devices - "Company PNP Platform OPN USB Device" and "Company PNP Platform SDC USB Device
Dec 21, 2009 | Visual Land V-Touch Digital Media Player
Delete songs from mp3
1) Go to Settings/USB Mode and change to MSC mode which make it works as a flash drive/memory stick 2) In Windows explorer, you should see two drives in My Computer, one for the unit, one for the card slo 3) As for a 'normal' PC, you can now just delete any files/songs from your Sansa directories in either drives! (you can also move existing or add new files). note: if your normally use SanDisk Media Converter program or Windows Media Player, you must change the USB mode setting on your Sansa back to 'MTP' before those programs can see your device.
Dec 20, 2009 | SanDisk Sansa e260 MP3 Player
Cannot add new music or access previously loaded music
I know you hate to do this,..but reset your sanDisk, first,..if you've done this and it still doesn't allow you to add,..you will need to make a change in your settings....go to USB, then make sure you have selected "Auto Detect".
Jul 07, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
I want to save the songs that are already on my sansa e260(4gb) on to a sd card because my screen cracked. is this possible?? i dont have these songs saved on my computer anymore!!
If the player is not totally dead, your PC should be able to recognize it via the USB connection.
If that is the case, you can open it on your PC as a storage device (drive) and copy the files, either to your hard drive, or to a separately connected SD card.
Apr 08, 2009 | SanDisk Sansa e260 MP3 Player
Help plz
What op system are you running?
Aug 05, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Can not access device neither directly nor via PC
I have the same frigging problem with mine. What's the solution?
Mar 19, 2008 | SanDisk Sansa e140 MP3 Player
Cant tranfer songs
you need to try a bunch of things to try to figure out whats wrong. you can try
different computers
different usb ports
how the device appears in device manager
changing modes on the player itself
Feb 05, 2008 | SanDisk Sansa e200 MP3 Player
SanDisk Sansa m200
If you are just using windows explorer (my computer) to access the files on the player you might need to set your players usb mode to "MSC", if it is set to "MTP" then you will need to access the mp3 players files via a music management software like winamp or wmp.
Feb 04, 2008 | SanDisk Sansa Clip MP3 Player
Downloading Muisc
i need to put some songs for my ipod
Dec 12, 2007 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa m240 MP3 Player Logo
46 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
