Question about Sanyo EM-S5002W Microwave Oven
Sanyo microwave EM-X515G
When i press the miro button on my microwave and then press start, it will run normally but it won't produce any heat to cook the food. but then, when i press the grill button and then the start button it works. help
  • bhtcaller1 Sep 15, 2008
    well the microwave itself works, but I'm not receiving any heat. The power,fan,clock, and the digital counter all works , but that's it !
  • sampobee Sep 26, 2008
    well the microwave itself works, but I'm not receiving any heat. The power,fan,clock, and the digital counter all works , but the heating is just not coming on-I have only used it for 6months
  • 833 Answers
I'm thinking that the circuit board has a problem. I doubt it will work but disconnect all the connectors on the board...with the power off and reconnect. It may clean off some goo. If not, use your method as long as it will work and then consider a new board.
Posted on Dec 17, 2007
How do I set the microwave for 50% power?
Hello, Linda -
Without knowing the make and model of microwave oven you are asking about I can only give general instructions. You can add the make and model of microwave by choosing Comment and adding the information there.
Generally, after placing whatever you want to heat or cook in a microwave save dish or on a microwave safe plate and place the food and dish inside the microwave and closing the door, you follow these steps:
- Using the key pad / number pad, press in the time you want the microwave to run
- Assuming there is a POWER button on the key pad, press that button
- Most likely a P will display
- On the keypad, press 50 (for 50 %) or maybe just 5
- Press START
This web page provides detailed instructions:
https://www.leaf.tv/articles/how-to-adjust-a-microwaves-cooking-power/
Best wishes.
Feb 24, 2018 | Microwave Ovens
Sears kenmore elite has a message display to enter tcp code. kenmore microwave oven
TCP is "True Cook Plus" in Kenmore speak.
Here is a cut/paste of a section of the manual.
*CUSTOMIZING TrueCookPlus' You may find that you prefer TrueCookPlus® to cook your food more or less. TrueCookPlus " can adjust to your tastes - to cook your food hotter or cooler - automatically: Example Clear 1. Press the Clear button. (§H§ 1 2. Press the TrueCookPlus® button twice. 3. If you want less cooking time when you enter a TrueCookPlus code, press 1. This will decrease the time by 6%. 345 4. If you want more cooking time when you enter a TrueCookPlus® code: Press 3 for 3% more cooking time. Press 4 for 6% more cooking time. Press 5 for 9% more cooking time. 2 5. Press 2 to reset TrueCookPlus* to factory setting default time. 6. Press the Start button.
I didn't try to clean up the copy
Hope this makes sense and helps.
Sep 14, 2017 | Kenmore Microwave Ovens
R-402JW-T won't cook
From your description you have a bad door switch, there are usually a few of them located inside the microwave under the keypad control board that will need a digital meter to trouble shoot.
Jun 28, 2012 | Sharp Microwave Ovens
My morphy richards p80d20p-yu microwave runs normal but won't heat food
The problem is caused by a bad magnetron, inverter board, "7 years old or less" and possibily the keypad control board.
May 02, 2012 | Microwave Ovens
Not heating
Hello
Power Supply
Check whether there is a proper power supply. Look to see whether the cord is connected to a grounded 3-prong outlet and the cord is fully plugged in. If the electrical system is built-in and no power cord is visible, replace or reset the household fuse or circuit breaker.
Microwave Functions
Some basic microwave operational steps may affect whether the microwave is heating. Open and close the microwave door, as the unit will not function with the door open, and push "Stop/Clear" to cancel any previous settings, such as the timer, which do not heat the microwave oven.
Setting the Microwave
Once the power to the microwave has been reset, or verified as working, and the microwave is ready to run, select a new cook cycle and press "Start" to see if the microwave begins to run and cook food as expected. Allow the food to cook for the alloted time and then open the microwave door and check to see if the food has cooked or heated. Choose a longer cooking time and restart the microwave if food is heating but is cooking slowly.
Repair
If all efforts to troubleshoot the function and power to the microwave still do not get the appliance heating food as expected, there may be a repair issue that needs to be addressed. Contact professional technician for advice.
Oct 05, 2011 | Sanyo Microwave Ovens
My samsung microwave oven is not heating up food. It works normally, lights on, food turning on plate, but not heating the food.
if your microwave does everything you have described , and you can hear the cooling fan running as well after you press the start button , you probably have a faulty wave guide. The wave guide is also called a Magnetron Tube. It is the main part of the microwave which produces the microwave energy . If this part is not functioning it is best to replace the entire unit, rather than have it repaired .
Oct 03, 2010 | Samsung Microwave Ovens
My ifb microwave oven is getting hot outside while
Normally when u cook food in microwave the fod is cooked by microwaves, which means the heat is generated with in food. The temperature inside is never too hot and all the heat produced is absorbed with in the food.
On the other hand when the grill is switched on, a separate heatting element gets switched on. You can see this red hot element on the top side of inside of microwave. the heat from this element gets transferred to food through air circulation. But partof heat also gets transferred to the walls of microwave oven. This is the reason the wall feel hot during use of grill.
As i see ther is no problem with the microwave itself. Jut kep delicate thngs a bit away from the microwave.
Oct 17, 2009 | LG Microwave Ovens
How doI change the power on my microwave?
  • Press "Time Cook" or "Micro Cook."
  • Enter cooking time.
  • Press "Power Level".
  • Select a desired power level 1-10 (default is 10).
  • Press "Start"
Jul 06, 2009 | GE JES1855 Microwave Oven
My Panasonic Microwave Genius 1300W will not heat up the food and the rotate dish spins and the sensor reheat will not heat up the food. Nor cook Pop Corn when pressing the buttons to 2:00 cook time. I...
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
May 14, 2009 | Panasonic NN-S960WA Microwave Oven
Microwave doesn't heat food anymore
Benjamin
Apr 21, 2009 | Frigidaire PLMV168 Microwave Oven
Sanyo EM-S5002W Microwave Oven Logo
265 people viewed this question
Top Sanyo Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
robert landry
Are you a Sanyo Microwave Oven Expert? Answer questions, earn points and help others
