Question about Samsung TXN3271HF 32" TV
Tedelex TV I did check the fuses they are fine with the meter so what could be the problem fuses ok, still not swiching on
Would it be reccomended to buy a tedelex tv
Posted on Jan 15, 2009
  • Man Said
    Man Said Aug 12, 2014
    i ansir for you az tv frequncy in hotbird
    thank you
    Sergeant:
  • 300 Answers
The switch could be broken.
check cord fuse, fussable resistor, or the horizontal transistor.
Az.
Posted on Sep 22, 2008
I have tedelex EC2159 remote codes it should be 3 digits not 4
Pilot remote control codes for TEDELEX:
30 results. Displaying page 1 of 1
NR Brand Model Type Pilot Supertel* Easytel Unitel 1 TEDELEX 1452 R/C P1679Y 2 TEDELEX 1452 TV P1679Y 3 TEDELEX 1455 TV P1655Y 4 TEDELEX 1458 TV P1655Y 5 TEDELEX 1459 TV P1655Y 6 TEDELEX 2052 TV P1679Y 7 TEDELEX 2056 TV P1690N 8 TEDELEX 2092 TV P1679Y 9 TEDELEX 2096 TV P1690N 10 TEDELEX 2098 TV P1655Y 11 TEDELEX 2099 TV P1655Y 12 TEDELEX 2122 TV P1545Y 13 TEDELEX 9227 TV P1690N 14 TEDELEX 9422 TV P1655Y 15 TEDELEX 9427 TV P1655Y 16 TEDELEX 9628 TV P4263 17 TEDELEX EC 2528 TV P4190N 18 TEDELEX EC 2909 TV P4264 19 TEDELEX G 148 TV P4263 20 TEDELEX G 149 TV P4263 21 TEDELEX G 202 TV P4263 22 TEDELEX G 209 TV P4263 23 TEDELEX N 9034 SA VCR P1814 24 TEDELEX RC 94 R/C P1655Y 25 TEDELEX RC 97-PI TV P4263 26 TEDELEX RC 98A R/C P4190N 27 TEDELEX RC 98D TV P4264 28 TEDELEX SOME MODELS VCR 29 TEDELEX SOME MODELS VCR P4205N 30 TEDELEX STUDIO 3000 G TV P1690N
* Note: Supertel, Minitel and PRO-TEL universal remote controls will share the same code.
Feb 26, 2017 | Televison & Video
Tedelex tv makes a clicking sound and does not want to go on
test the horizontal transitor with ur multi meter if it is bad replace with thesame number but if is not bad then u replace the LINE TRANSFORMER with thesame number
May 30, 2015 | Televison & Video
We moved unpluged tv an now it won,t go on
check the fuse in the plug if ok try the on and off swich on your tv will by on the side some were
Apr 07, 2014 | Westinghouse Televison & Video
Cdi wiring diagram
All those items are controlled by the switch box, on the left side of the handlebar, check that the wiring junction box to that switch box has good connections. Use a volt meter to check for power supply also check if the fuses are ok.
Oct 31, 2013 | Bajaj Caliber 115 Motorcycles
While running the computer all of sudden switched off
If your PC SMPS is ok then your PC motherboard has been faulty. pls checked it from service center.
Oct 13, 2009 | ASUS P5GD2 Deluxe Motherboard
27' magnavox tv model 25e503
you need to check the primary input ac connection e.g fuse and then measure if you have 330 volts across the filtering capacitor..if this is ok or the fuse blows then disconnect ac-line and check pwer supply eg smps swiching transistor...probably gone to heaven..and replace it and optcoupler..i.e. refere to eventual kit from philips they have repair kits for your tv!...it may be a "standard" problem..if you can get a copy of servicing the smps...in technical manual for your tv it is best...ron
Mar 03, 2008 | Philips Magnavox 27MS343S 27" TV
Will not turn back on
Take off back cover. The problem power board is to the right of the board where the power plug feeds into the TV. There is a large white fuse right bend the power plug. With a meter it read ok; about 8 inches deeper into the TV on that board was the resister next to two fuses. My 4 amp 125 volt fuse did not read on my meter. After replacing, it worked fine.
Feb 12, 2008 | Pioneer SD-P50A3Q 50" Rear Projection...
Tedelex TV
tv screen locked a padlock appears in the screen.
Nov 23, 2007 | Toshiba 32A33 32" TV
Tedelex colour TV
first check the fuse in the plug.if its ok then the fuse in side the tv might have blown,if you are going to check the fuse in side the tv your self PLEASE make sure that the tv is NOT plug into the mains and be very careful that you do not touch any of the circuit boards as you will/might get a electric shock..the fuse might be a 20mm glass type,inside the fuse you should see a piece of wire if this is broken then that is the fault,if you cannot see the wire then you will need a meter to check the fuse. if you have no meter to check the fuse then take the fuse to a tv shop to check..hope this will get the tv working,if not then im afraid the tv will have to be taken in for repair..all the best..Lee Bruce.
Nov 22, 2007 | Toshiba 32A33 32" TV
Samsung TXN3271HF 32" TV Logo
372 people viewed this question
Jerry Greenberg
Jerry Greenberg
