When I Put Dvd's In My Cd Rom Drive To Play On My Laptop, It Doesn't Do Anything And Doesn't Come Up Saying There's Anything In There But It Does Make The Loading Noises Then Just Stops! Can Anyone Suggest A Solution? Thanx =)
You need a program, like nero. if that doesn't work then put a DVD in the drive & see if the computer picks it up in the my computer. the first thing that goes in a CD/DVD-RW drive is the DVD heads, thats if your drive is a CD/DVD-RW. Have a look on the front of the drive tray, if it say CD-RW DVD ROM then it doesn't burn DVD's it only plays them.
goto run and type "compmgmt.msc"(without quotes) and select disc management if the dvd drive is showing below the hard disks means your dvd drive is working fine only thing you have to do is to right click on the CD-Rom 0 and change drive letter and paths to it .if the CD ROM option is not seen in disk management then you have to go to the device manager option under computer management and expand cd/dvd -rom drives and you will find your dvd drive model if not that means that your dvd drive has got hardware problem
CD Drives read only
COMPACT.DISKS.
DVD/CD Combo drives are meant to have support for DVDs and CDs
Of course it's not going to work! it's not compatible, either buy an external CD/DVD Drive. or replace your CD Drive with a DVD/CD Drive.
Does your laptop have a DVD drive? It is likely that the Sims Double Deluxe disk you have is a DVD ROM and not a CD ROM.
If this is not the case, try clicking My Computer and selecting the CD drive to see if the computer recognises the disk at all. Run setup.exe if it does.
computer acer aspire 1360 pc dvd drive dease not book dvd driver stop working c drive was over laoded and the computer whent in to disk clean and deletelte the driver for the dvd rom i can no longer play cd dvd or use the crw or dvd RW ASPIRE 1360 2.8GHZ PLEASE CAN YUO HELP LOST THE DISK THAT CAM WITH THE MACINE YUORs garyfifiled@talktalk .net
hi
you need to check if the drive is Cd rom or a DVD rom if you try to play a DVD on a Cd rom it wont play, IF you are doing everything right then
try this
Go to my computer i mean right click on my computer and click on properties and then hardward tab >> and device manger>> and under DVD and cd right click on it and uninstall it and restart the system
