No instruction manual for Conia LCDTV How do i scan for new channels now I have a new ariel?
As above? I'm not sure how to set up/scan for new tv channels now I have a new ariel, I don't currently have sbs, or 31 because my old (Pre 80's ) ariel did not support those channels. Other members of the household purchased tv but have mislaid any documentation that came with it. NO I didn't steal it, they bought when I was overseas. Please can you help or point me in the right direction.
  • Veets Dec 26, 2007
    We did not recieve any directions with our new TV/DVD.
    DPC-ITEM #00809-1332
    STYLE #PVS31170S1
    SIZE: L 52.70CM X W 22.60CM X H 46.60CM
    We are not able to use the TV with Gamecube.
    Thank you,
    V. Sullivan
    e-mail address:
  • renacath Dec 03, 2008
    We did not recieve a manuel with our new TV we have a
    conia plasma the model:CPDP5003HD
I have a conia model clcd1910 cant get volume at all
Posted on Jul 31, 2009
How do I add the HD channels picked up my HD antenna to the master channel list on my Visio TV?
Hello, with the set on, press the menu button, move the cursor down till the "Tuner" section is hi-lighted, click on it. Then the first selection is "Tuner Mode" click on it, the choose "Antenna" click on it. Then move to the "Auto Channel Scan" and click on it, and let it set all your channels. when done, just exit menu and change channels as desired. you can go to page 39 in your manual for these instructions: Tuner Mode
Select Cable or Antenna depending
upon which equipment you have
attached to the DTV / TV Input.
Auto Channel Search
Automatically search for TV channels
that are available in your area. Be
sure to first select the correct tuner
mode above. The TV will search for
analog and digital channels. When the
search is done, press EXIT to begin
watching your programs. thanks, Terry
Oct 09, 2012 | Vizio M220NV 22 in. LCD TV
Telefunken analogue color TV model MP-A2055VT-H to connect up digital decoder set-top box. The TV only has an RF input. no other plugs. Searched all 80 channels and I cannot find an AV channel on the...
The simplest solution would probably be the use of an RF Modulator. Feed the RF Mod with the A/V signals from the Conia CSTB12, set it to transmit on Ch 3 or 4, tune the Telefunken to either channel.
In most Telefunken TVs we have worked on, the A/V INput/OUTput would be on the SCART connectors as shown below.
To my understanding, a Conia CSTB12 as sold in Australia has a composite RCA (yellow) Video OUTput and L/R White/Red audio OUTputs. What would be needed would be a A/V signal to SCART adapter/converter.
If your Conia CSTB12 has an S-Video, then this may be used.
If your Conia CSTB12 has an HDMI, then something like this may be used.
Incidentally, should you be interested, there are comparable receivers to a Conia CSTB12 that has SCART OUTputs.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 14, 2008 | Televison & Video
Conia 32" LCD TV will
Good day!!!
please try to set auto scan..
just go to the menu using remote control then go to the settings and find auto scan..
please complete the 100% scan for better results..
thanks for using fixya.
have a nice day!!!
Jun 30, 2011 | Televison & Video
My universal remote went out and somehow the tv-a Sansui-got switched from channel 3. How can I get it back to channel 3 so the converter will work? I tried changing channels manually at the tv but it...
Look in the owner's manual for instructions on having the TV scan channels. Make sure the converter is on before starting the scan. If that doesn't work, you'll have to buy or borrow a universal remote to take care of it (enter 3, 03 or 003 on the remote control). This will happen every time you remove power to the set, whether it is unplugged or you have a power failure, so start saving up for a new remote control.
Dec 07, 2010 | Sansui 27" TV
Sony V lcd 32 inch losing digital channels and after doing a resetting scan it is ok for about 30 mins.... then screen image breaks up totally and message 'weak signal' shows on screen. Help,please.
You answered the question in your question.
''weak signal' means exactly that, however it can also mean the signal is too strong.
If you have a booster installed into the ariel remove it, if not, try one. Make sure the TV is directly connected to the ariel, not via a DVD recorder or any other devices which require an ariel input.
Sony tv's have very sensitive tuners installed so its just a case of making your aprticualr settings compatible.
Check signal strength over at
Nov 29, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Hotel lock, not available but im sure there is another way
Not all sets have a hotel lock.....key in for a google search on the model and get a free download of the user manual.
May 20, 2009 | Sansui HDLCD3210 32 in. LCD TV
I need to rescan the channels but it is not an option under menu.
you will need to manual scan. you must put on the ariel as this gives you the pictures check the instructions. for searches, if you dont get any channels after tuning then take it back to where you got it,
Apr 22, 2009 | Axsion Televison & Video
Recieving no digital channels in my LCD TV
hi there alot of the updates for the system should automaticly download via ariel to the tv to keep you up to date some times if the strenght of the signal isnt srong enough then you might not get the update they send out , one thing i have found is that if you use an ariel booster then this makes the signal stronger this helps particularly if you have more than one tv set up with the same ariel, you could try unpluging all ariels to other tvs making sure the ariel lead you are using has no conections in it as this also gives you loss of signal if there are multiple conections in the lead runing from the ariel to your tv set hope this helps some
Cheers ;)
Feb 05, 2009 | Toshiba Regza 42C3030DB 42 in. LCD TV
Universal remote codes for a conia tv?? Help me PLEASE :)
Thank you guys! just bought our universal remote control and now we able to use 1 remote for everything especially our conia plasma tv and it really works the 0821 code...
Mar 05, 2008 | RCA Universal Remote Control
Televison & Video Logo
778 people viewed this question
Top Televison & Video Experts
