Question about Apex Digital GB51HD09 51" Rear Projection Television
Apex Digital GB51HD09 51" 2002 model situation
I hit the on button, light flashes 4 times and then nothing. It turns on some days for 15 minutes and then off for a few more days. Somedays it turns on for a few hours then nothing. I dunno man. Should I trash it or what? Any help would be much appreciated. Garbage day is This comming thurs.
I experienced the same problem. I found a small capacitor in the corner of the board with a bad solder connection. You do have to remove the 6 screws holding the board to the plastic slide to get to the back side of the board.
Posted on Jan 21, 2008
    President:
  • 4,402 Answers
Try looking in the troubleshooting section of the operating manual (usually near the back) to see if that tells you about flashing 4 times
Sounds like a loose connection or a part that heats up, sometimes you can get a can of freeze (radio shack) and spay on the part if the part is over heating to see if you can get it to stay up longer.
Posted on Dec 21, 2007
I have an apex ld3249 tv with remote. The remote died a couple of days ago. I have had the tv for 6 weeks. A universal remote will not work. A new Apex remote is $60. Is this going to be an ongoing problem...
Hello
There is no warrantee for the remote control for any company's set. A universal remote should work with your Apex tv. I'll give you the model and codes for the remote that suit to your apex TV. Buy one and match it to your TV.
PHILIPS [CL 034] universal remote control.
Codes are:-
0023 0223 0123 0741
Proceedings
Direct Code Entry
1. Press and hold the CODE SEARCH
button until the red indicator stays
on, then release the CODE SEARCH
button.
2. Press and release the desired Mode
button (TV, VCR, etc.). The red
indicator blinks, then stays lit.
3. Enter the 4 digit code from the code
tables. Note: after a valid code entry,
the red indicator turns off. For an
invalid code, the red indicator
flashes.
4. With your device on, press
CHANNEL UP. If the device
responds, no further programming is
required. Note: If some buttons do
not operate your device, try one of
the other codes for your brand.
OK.
Feb 15, 2011 | Apex Digital Televison & Video
Won't turn on
Can u tell me model no and brand name so that i can help u sir..
Sep 03, 2008 | Samsung PCN5425R 54" Rear Projection...
Problem with code for apex ld3249
You can power scan for the code.
Turn ON the electronic device you want to program the remote to control.
Press the Mode button( sat,tv,dvd,aux) on the remote until the appropriate mode light is flashing.
Press the Power button. The mode light will stop flashing and stay lit.
Press the Up or Down arrow button to set the remote to the next code. The Down arrow button scans backward and the Up arrow button scans forward.
When the correct code is reached, the device (whether a TV, VCR, or other) will turn off.
Press the pound key button to store the code in the remote control memory. If the code is valid for your remote, the mode light will blink 3 times.
Turn the device back ON by pressing the Power button.
Press sat mode key once you power back on the tv to be able to operate the receiver box.
Try some other functions to make sure you have the correct code. Occasionally the Power button may work when others do not.
If the other buttons work you are finished.
If the other buttons do not work, repeat the previous steps. The scan will resume from the last code stored.
The mode light will flash rapidly when the scan has returned to the starting point and all codes have been tested for that mode. The remote control may not control some device models.
Apr 07, 2010 | Apex Digital LD3249 LCD TV
Chance time in cherokee 2005 with navigasion is no time botton
If you have a VIC (Vehicle Information Control), hold the set button down until the hours start flashing. Once the hours are flashing, hit the set button to change the hours until you've got the hours correct. Then hit the Select button and the minutes will start to flash. Hit the Set button until your minutes are correct and then hit the Select button again whereby the AM/PM button will flash, hit the Set button until your time's correct, then hit select to move to the day, date and year and when you're finally done, (after all the hitting of the SET & Select buttons, just hit the Select button and nothing will flash and your time is set. Should you have a radio that displays the time, push down and hold the TIME button until the hours begin to flash (with the radio turned off), then turn the volume wheel until the correct hour is displayed. To adjust the minutes, turn the Tuning knob until the minutes are correct. Once you're done, don't touch any of the buttons and the clock will display the correct time on it's own...when you've released all the buttons and dials.
"00 Buck"
Nov 06, 2009 | 2005 Jeep Grand Cherokee
Apex DT250 wont turn from standby (red light) to On (green light)
The DT250 has one or more bad 470uf 25v capacitors. You should replace all four. Look at some of these youtube videos for how do do the replacement.
http://www.youtube.com/watch?v=on_2CP52cW4
http://www.youtube.com/watch?v=YCSNWi3UHf4&NR=1
Order 4 new 470uf 25v capacitors from digikey.com P/N P10274-ND
Use first class mail as your shipping method. Will be under 10 dollars total.
Sep 24, 2009 | Apex Digital HT-150 System
Turned off when i was looking at it
You need to replace the battery in this unit as its not putting out enough charge to power the unit even tho it says it charged.
hope this helps
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 22, 2009 | Creative Labs Zen Digital Media Player
Apex tv converter box won't turn on.
what can my customer do to get his remote to work? red light on but no green light.
Jun 20, 2009 | Apex Digital HT-150 System
TV won't come on
unplug it for 10 minutes then turn it on at the console(not the remore) and hold the power button in for 15 seconds. this resets most apex tv's
Oct 06, 2008 | Apex Digital GB55HD09W 55" Rear Projection...
Apex GB51HD09 will not turn on
On the power board you will find 4- 35Volt X 1000mfd radial lead capacitors on the right rear corner of the board all in a row from right to left, the 2 outside capacitors have gone high ESR. This is a common problem with this model.
Dec 21, 2007 | Apex Digital GB51HD09 51" Rear Projection...
Time change on Pioneer car radio
Turn the raido/cd player off. Hit the clock button. Time will display. Press and hold down the audio button for 4 seconds. Use the arrow keys to change time. Press and hold the audio key when finished until the time is done flashing.
Nov 07, 2007 | Pioneer KEH-P2030 Cassette Player
Apex Digital GB51HD09 51" Rear Projection Television Logo
89 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
