Question about Mitsubishi WS-55515 55" Rear Projection HDTV
Ws-55515 When I press the device button on my remote the snow becomes delayed then shuts off. Tried to go into tv menu options to see if i could hand enter devices but when i go to the A/V icon it freezes then shuts off. Thanks Dan
    Novelist:
  • 192 Answers
You will need to reset the Netcommand and tunerws-55515 - 2.gif settings in the set.
The little indented button in the front of the set needs to be pushed in (when the set is off). The front light will blink for about a minute or minute and a half.
Then, reprogram the Netcommand settings.
This should solve your problem.
If you need more information, then, reply to this post and I will respond.
Posted on Dec 15, 2007
Video is snow. no images just lines and snow. the only menu that appears on the screen is the net command set up menu. after a couple of minutes the TV powers OFF no matter what i try. i tried pushing the...
A suggestion: try with the original Mitsubishi remote to do the soft restore: Menu, 1,2,3, enter.
BEFORE YOU RATE THIS SOLUTION LET ME KNOW WHAT YOU FIND.
SD TECH
Jul 05, 2011 | Mitsubishi WD-62725 62" Rear Projection...
Trouble changing device
Your problem may be solved by re-initializing the set. With the tv on use the remote and push MENU,2,1,7,0. A display will come up. Use the up down arrows on the remote to select INITIAL and press the enter key on the remote. That should do it.
May 04, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Tv won't turn on with remote or front panel
Try this :
Follow the steps below for the initial set-up:
1. Select the "MENU" display by pressing the "MENU" button once.
2. Press the number buttons "2", "2", "7", "0" in sequence to select the "OPTION MENU" display.
3. Press the "ADJUST" button to select "INITIAL."
4. Press "ENTER."
Good luck...
Jan 11, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Tv wont respond because device menu is changing through each device
I had a similar problem: my WS-55511 would not respond to the remote and the front control buttons (with the exception of Power) cycled through the Device Menu. I solved this problem by disconnecting the front panel. Here's how to do it: 0. Unplug the TV
1. Remove the speaker grill from the front by pulling forward: there are no screws. 2. Disconnect the two cables that are exposed after the grill is removed. 3. Plug the TV back in, wait for 5 minutes to reset. 4. Try using the remote.  Hope this helps!
Oct 06, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Blinking light mitsu ws-55515 rptv
if the set is shutting down it should blink a code. Try pushing in the menu and input buttons on the set both at the same time and hold them in for 8 seconds to see if the self diagnosis will falsh a two digit code. Let me know what happens
Mar 24, 2008 | Mitsubishi WS-55515 55" Rear Projection...
Mitsubishi ws-55515 light blinking
Sounds like the remote is not programed correctly or the input sources have been changed.
Call the cable company and complain that it worked before they came and shoud work afterwards.
Mitsubishi WS-55515 55" Rear Projection HDTV Logo
90 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
