Question about Dell Dimension 5100 (D51L1) PC Desktop
UTILITIES THERE IS NO UTILITIES ON THE F12 KEY WHEN PUSHED ON START UP THE PUT IN A NEW MOTHER BOARD/ HARDDRIVE/AND MEMORY STICKS IN THE PROCESS HAVE LOST UNTILITIES ON START UP AND HAVING TROUBLE WITH OTHER UNITILITIES............
  • Dave MacPhee
    Dave MacPhee May 11, 2010
    You mean you can't get into bios setup menu?
    Sergeant:
  • 313 Answers
Did you get the new motherboard from Dell?
Are you sure the memory is compatable with your new motherboard?
Is the processor properly placed with thermal grease, and CPU fan secure?
Are all the fans working?
When rebuilding a computer all these things are paramount, and one must know what they are doing.
Posted on Apr 03, 2008
Sir i have this mother board with i5 processer. As i am using windows 7 , 2gb ram of kingston ,HDD of 500 and having LG DVD drive . Now i am facing one problem that i cant even start my system because it...
Hi :) Some times the problem can be a bad sector on the ram try switching the ram around in the sockets put stick 1 in slot 2 and stick 2 in slot 1 if this works the fault is in the original stick 1. What happens is the Data is being lost between the install CD and the Harddrive and it can't load windows properly.
Sep 13, 2011 | Intel Desktop Board DH67VR Media Series...
Tip
Sony Memory Stick Formatter Software If your Sony Memory Stick has stopped...
If your Sony Memory Stick has stopped working in your digital device,
Sony's Memory Stick Formatter Software may be able to format your Memory Stick in a more compatible way for your device.
Compatible operating systems include:
* Windows® 7 Starter / Home Basic / Home Premium / Professional / Enterprise / Ultimate
* Windows Vista® Home Basic / Home Premium / Business / Ultimate
* Windows® XP Home Edition / Professional
* Windows® 2000 Professional
Preparation
* Confirm that the write-protection switch of the Memory Stick is set to the "Write enable" position.
* Insert the Memory Stick into the Memory Stick slot of the device or computer.
* If you are using a file recorded on Memory Stick with another application, quit the application before beginning the formatting process.
The Format Process
Note: Formatting will erase all files in the Memory Stick. Always double-check the Memory Stick contents before formatting to prevent loss of important data.
* To start Memory Stick Formatter, click Start->Programs->Memory Stick Utility->Memory Stick Formatter.
* At the "Drive List" screen, click to highlight the drive letter that represents the Memory Stick device/slot.
* Click the Start Format button.
* At the "Warning..." screen, confirm that you wish to format the Memory Stick, and click OK. Note: To quit the process, click the Cancel button.
* Do not remove the Memory Stick from the Memory Stick slot during formatting, as this may cause corruption.
* At the "Format was successful" message, click OK.
* To quit the Memory Stick formatter utility, click the Exit button.
Download the Sony Memory Stick Formatter Here.
I hope that helps.
____________________________________
Click here for Sony's Memory Card File Rescue software.
on Apr 18, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
Tip
Preparation
The Format Process
I hope that helps.
on Apr 18, 2010 | Sony 2GB Memory Stick PRO Duo Memory Card
My bios will not start keeps saying cant find cdrom. mother board p4p800 cant get online to get proper bios to flash any helpful ideas? jason
when the computer first starts hit the f8 key or the f12 key, it really depends on the bios, and change the boot settings to go from harddrive not cd rom
Sep 18, 2010 | Computers & Internet
My hp 5750 beeps 4 times what seems to be the problem??? thank u
This means that your memory is bad or not installed correctly. Open your pc up and remove all memory from the mother board, then dust it, place the memory back in and it should work. If you still have this problem, leave only 1 memory stick in and try starting up your pc, if your pc starts up then the other memory stick is bad and you will need to replace it, if your pc still does not start, remove the 1st memory stick and put the 2nd memory stick in its place and try booting once again. If this still does not fix it, then the memory slots might be bad, try putting the memory sticks in different memory slots and each time try booting your pc. If this does not work, try buying new ram, worst case scenario you will have to replace the motherboard. Or just replace the computer if both memory slots are bad on the motherboard, and i mean IF. Good luck!
Sep 02, 2010 | Computers & Internet
Tip
Preparation
The Format Process
I hope that helps.
on Apr 18, 2010 | Sony 1GB Memory Stick PRO Duo Memory Card
Tip
Preparation
The Format Process
I hope that helps.
on Apr 18, 2010 | Sony Cyber-shot DSC-H7 Digital Camera
Monitor says check signal checked the monitor on another computer works fine changed mother board same problem only things still left memory and hd and dvd rom drive.
The problem is something you have recently changed( i.e. new memory, processor, video card) does not agree with your board. Good place to start is to remove ALL memory sticks and pci adapters and try it then. Try one component at atime and start putting them back in. Restart and run every time you put something new in thew board. Hope this helps
Oct 02, 2009 | Microsoft Windows Vista Home Premium with...
ASUS Asus P5QC Motherboard
Hello edwardfuller:
Do the same as you did, only this time remove all plug in boards and if there is anything connected to the mother board such as extra fans, speakers, and so on, remove all.
The board will detect any shorts, or overloads or problems in cards and so on , and will not turn on.
If it still will not work, check your memory sticks.
Remove all memory and place one at a time in the first slot, and then proceed to turn on and test.
By elimination, you can find the problem.
If all fails, then something may be wrong with the mother board.
take care, hope this will help,
Sep 02, 2008 | ASUS P5QC Motherboard - Intel P45, Socket...
Dell Dimension 5100 (D51L1) PC Desktop Logo
16 people viewed this question
Alun Cox
