Question about Jl Audio 12W3 Car Subwoofer
Car Sub JL 12w3 low sound
I am running an older JL Audio 12w3v2-D4 off of a Blaupunkt THA1350 Amp. The sub is wired in parallel to run on 2 ohms. I know that the amp should have no issues running this sub but the only noise I am getting from the sub is very very soft. I don't believe the sub is blown since I have never smelled that distinct blown sub scent. Any ideas what is wrong?
  • KrazyJ Dec 28, 2007
    I solved this on my own but i thank you for the help. Seems kinda odd that you would look up the amp specs but not the speaker specs to find out that 300 watts is the rms for the speaker.
    Problem Solver:
  • 14 Answers
So I am assuming that you have just setup/wired this up recently? Have you had this working before?
You can have a look at the gain control on the amp & see if this have been set really low. This will help if the signal coming from your stereo is weak. The other thing I would suggest is to make sure that the amp can actually push this sub. I know what the specs say:
  • 1 channel audio amplifier
  • 1 x 350W RMS @ 1.0% THD
  • ThermalThrote full-on power assurance
  • 2 ohms stable (non-bridged mode only)
  • RCA type inputs
  • 0.3-6.0 VRMS input capability
  • Continuously variable High-Pass & Low Pass 50-250 Hz
  • Continuously variable Bass Boost settings (0 tp +12dB)
  • Frequency responce: 10-30,000 Hz
  • S/N >104 dBA at full power @ 0.1% THD
  • >80 dBA at 1W/1M
  • Remote gain control, mounting hardware & screws included
but I don't believe most of these. Many manufacturers embellish what their products can actually do! With the bigger more established brands such as JL Audio you will have no problems, their products have been tried & tested so much on the competition circuit.
Posted on Dec 28, 2007
  • Travis Sumner Dec 17, 2013
    Im having the same "low noise" problem. How did you fix it. My subs were running perfectly a few days ago
Try to install 3 12w3d6 subwoofers connecting 3 sub together to put them in box
You need to wire them according to the limitations of your amp you can pull a 1 ohm overall load just by connecting all of your coils in parallel- or you can get an overall load of 4 ohms by wiring each sub individually in a series configuration which will yield a 12 ohm load per sub -and then wire the 3 sets in parallel which will bring your ohms back down to 4. You can do a lot with that many coils it depends on your amp really-ideally a 1 ohm stable class d mono amp that is 1000-1500 watts rms would knock the **** outta those things JL is the good stuff.
Jan 16, 2010 | Jl Audio 12W3 Car Subwoofer
Who to wire JL audio 12w6 to its max
Hello shermalestuc,
The JL Audio 12w6 v2-D4 has dual 4 ohm voice coils that can be wired for either a final load to the amp of 2 ohms (parallel) or 8 ohms (series).
If your amp is 2 ohm stable, the best power solution for a single sub is to use the parallel configuration, both positives and both negatives together and then to the amp.
Nov 08, 2009 | Jl Audio 12W6 Car Subwoofer
How do i wire two audio pipe dvc woofers to this amp. do i use all four terminals on da amp. jl audio 500.1
Hello smoovek2008,
The JL Audio 500/1 outputs 500 watts RMS into a load from 1.5 to 4 ohms. Whether your subs have 2 ohm or 4 ohm voice coils, they should be wired in series and the subs paralleled to the amp. The final load to the amp will be either 2 ohms or 4 ohms, both of which the amp can handle. If you parallel the voice coils and then parallel the subs, the final impedance will be either 0.5 ohm or 1 ohm, both too low for the amp.
You can wire each sub to a separate set of terminals or both to the same set. The terminals are connected internally. It doesn't matter which of the +'s or -'s you use.
Hope this helps.
Sep 25, 2009 | Jl Audio 500/1 Car Audio Amplifier
How 2 wire 3 jl audio w6 v2
Hello mikey4569mky,
Unless your amp is stable below 1 ohm, there's really only one wiring solution. And that is to series the voice coils making each sub 8 ohms, then parallel all 3 subs to the amp for a 2.67 ohm load. If you parallel the voice coils and then parallel the subs, the impedance will be 0.67 ohms, much too low for most amps.
You could parallel the voice coils and then series the subs for a 6 ohm load, but the amp won't put as many watts into a 6 ohm load. Most are optimized for 4 ohms or 2 ohms. And it's not good to run subs in series anyway.
Here's the wiring diagram.
Hope this helps.
Sep 13, 2009 | Jl Audio 12W3 Car Subwoofer
My amp is protecting unessacarily when ran at 2 ohms
are you factoring the ohm rating from running them parallel?
2 x 2o subs parallel = 0.5 ohm (lowers ohm's)
2x 2oh subs series = 4 ohm
IT is posable that you are calculating the ohm rating fine, BUT some SUBS can reach lower ohm rating while hitting bass- i didnt know this till i had a rather insane sub that would dip to 1ohm while hitting hard bass causing my amp to go into protect mode.
May 21, 2009 | Rockford Fosgate T10001 bd Car Audio...
Is a 15 w3 d-4 better then a jl audio w3-d2
All of the JL W3 subwoofers are essentially the same. The "d2" and "d4" suffix refers to the voice coil configuration. "d2" = dual two ohm coils, "d4" = dual four ohm coils. Depending on the number of subwoofers in your system and the amplifier(s) you are using to power them, one or the other of the configurations may be "better".
Generally, you want to have the load on your amp to have the lowest possible impedance consistent with the amps capability to operate properly with that load. It's normally referred to as "impedance matching". Greater power (watts) is produced, and louder sound, when the amp can deliver power at a lower impedance.
If your amp is only capable of supplying power at 4 ohms, you want to make sure that the configuration of your sub(s) represents a 4-ohm load. If the load is higher, say 8 ohms, then your amp can only deliver about half the power of which it is capable. It would be OK to run them a 8 ohms, but they would not be as loud. On the other hand, if the load was lower, say 2 ohms, your amplifier would soon overheat and go into protect mode.
So the trick is to first decide on how many subs you want. Then choose an amp/sub combination that "matches".
The DVC or dual voice coils just gives you more options in selecting and configuring. Say you want 2 subs and you are going with the 15w3 d-2. Your amp is the JL Audio G-MAX monoblock. The amp puts out 1200Wx1 Chan. at 2 ohms or 600Wx1 Chan. at 4 ohms. You would wire both of your subs voice coils in series making each sub 4 ohms, then wire the 2 subs in parallel to your amp making the final load 2 ohms, the best "match" for your amp.
Mar 29, 2009 | Jl Audio 15W3-D4 Car Subwoofer
Jl audio 10w6 x zapco350
These subwoofers are dual 4 ohm voicecoils.
Parallel wiring the 2 voicecoils would net a 2 ohm mono load.
Connect both + on the sub to the + on the amp.
Connect both - on the sub to the - on the amp.
Many professionals simply jumper the 2 + and 2- on the sub.... then run 1 set of wires from one of the terminals to the amplifier.
Thank you for using FixYa - a FixYa rating is appreciated!!
Jan 27, 2009 | Jl Audio 12W6v2 Car Subwoofer
500/1 settings to run jl13w6 v2 d-4
Just had a look at both amp and sub on the JL Audio website. The amp runs from 1.5-4ohms. 4ohms at 14.5V. The sub is running dual 4 ohms coils. That's what the D-4 means. So should be an easy set up. The amp has two mono outputs, so one for each coil. It looks like the perfect wattage to run the sub real nice.
Web page for amp: http://mobile.jlaudio.com/products_amps.php?amp_id=439
Web page for sub: http://mobile.jlaudio.com/products_subs.php?series_id=18
Nov 19, 2008 | Jl Audio 1000/1 Car Audio Amplifier
12W3V2-D4 ENCLOSURE
12W3v2-D4 sealed or ported enclosure use.
Sealed 1.25 ft3 23" x 14" x 10"
Ported 1.75 ft3 29" x 14" x 12.25" - Slot port size 1.375" x 12.5" x 23.75"
12W3v2-D4
Fc: 47.4 Hz F3: 41.3 Hz Qtc: 0.83 Recommended Port Tuning: 30.3 Hz
Maximum wattage: 600 watts per driver.
I hope this helps you, more info can be found at: http://mobile.jlaudio.com/pdfs/12W3v2_MAN.pdf
Jun 24, 2008 | Jl Audio 12W3 Car Subwoofer
12W3V2-D4 ENCLOSURE???
They need 1.4-1.7 cubic ft per sub(ported box) less if it is sealed but I wouldn't recommend that, it sounds like ****. Google "Re audio box calculator" and use it to adjust your dementions to your application
Jun 22, 2008 | Jl Audio 12W3 Car Subwoofer
Jl Audio 12W3 Car Subwoofer Logo
333 people viewed this question
Top Jl Audio Car Audio & Video Experts
hoyzee1
matthew walsh
Level 1 Expert
Morne Olivier
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
