Question about Intel Motherboard
Wont startup i have a gigabyte 945pl-ds3/s3 motherboard and i updated the bios and i had to turn the computer off and when i restart it it wont turn on the screen is blank i cant even push delete to go to cmos set up what can i do ?
You may want to try to reset your CMOS.
Try to locate the manual for this particular motherboard. The manual should show you the location of the CMOS jumper on the motherboard. Once you have located the information that will tell you which pins on the jumper have to be shorted to clear the CMOS, you can start the process of clearing CMOS.
But before you change the pin settings, you must make sure that your computer is completely powered down. You must remove your power source to the unit, because CMOS is where the BIOS settings are saved when the unit is turned off but yet it still receives power.
If you succeed with clearing the CMOS and can bootup,get to the BIOS settings make sure you go to the PNP/PCI settings are set not to lose the new settings
Posted on Dec 15, 2007
  • 3 Answers
1.may be the smps(power supply) not be proper.check power supply......
2.processor may be corrupted
3.bios cell may not be working proper
4 Suggested Answers
SOURCE: Motherboard D945GCL Problem
i need for d945 gcr intel driver
Posted on Feb 14, 2008
  • 1019 Answers
SOURCE: Asus Motherboard not booting
Once you,ve Flashed The Bios unsucessfully the board is dead.
Theres Nothing You Can Do, Unless The Bios-Chip Is In A Socket On The Motherboard, Which Is Removable.
You Can Then Send It To A company to have the bios re-flashed.
The Bios Is The Motherboards Memory. Instructing it What to Do on Boot-up, what it,s capabilitys are, what to do, what to look for
For when they,re connected to it, what how to configure items. et,c et,c. By re-flashing The Bios.
You,ve rendered The Board Useless
The Valuable Lesson Here Is. If it,s Not Broken Don,t Try to Fix It. Look On The Internet For Bios/eeprom Reprogramming.
Mike @ Compurepair.
Posted @ 09.21 AM ( G.M.T )
Posted on Mar 03, 2008
colliewob
  • 781 Answers
SOURCE: Cannot change cmos settings.
Try this.
Open case somewhere on motherboard will be (reset BIOS) or word to that effect. it will be a small 2 pin connector with a jumper on 1 pin connect the jumper across both pins for 30 seconds remove jumper fit back over 1 pin (not get lost) reboot your BIOS should have reset to default hope this helps post comment if does please
Posted on Jul 27, 2008
GIGABYTES GA-965P-DS3 motherboard cost features
Ref:
GIGABYTE Motherboard Socket 775 GA 965P DS3 rev 1 0
May want to look on the board to find out what version it is and select the right one in the link.
Jul 07, 2014 | Cooler Master (CAC-T05-UW) (CAC-T05-UWA)...
Multimedia driver
This is the manufacturer webpage support, you can get the driver from there.
http://www.gigabyte.com/products/product-page.aspx?pid=2536&dl=1#driver
Good luck.
Remember to rate my posible solution. Thanks.
Jul 12, 2011 | Gigabyte GA-945PL-S3 Core 2 Duo/ 945PL/...
Just installed seagate barracuda 250gb 6gb internal hard drive with a gigabyte ga-945pl-s3 mother board and it will only recognise 130Gig! been through the bios but nothing stands out to say enable larger...
The maximum hard drive you can install depends upon the BIOS. You MAY BE able to install a larger hard drive if the BIOS upgrade will allow it. I suggest you go to the Gigagyte WEB site to check on this possibility.
http://www.gigabyte.com/support-downloads/support-downloads.aspx
May 19, 2011 | Seagate Barracuda 7200.9 (ST3250824A) 250...
What CPU is compatible with the motherboard GIGABYTE GA-065P-DS3?
The following CPUs are compatible:
Core 2 Extreme Core 2 Quad Core 2 Duo Pentium Extreme Edition Pentium D Pentium 4 Extreme Pentium 4 Celeron 400 series Celeron D
You may need to update your BIOS to get full support for all of these CPUs. Literally dozens of CPUs are supported by your motherboard.
Feb 22, 2011 | Cooler Master CAC-T05-UW ATX Mid-Tower...
WHAT IS THE APPROPRIATE CPU FOR GIGABYTE GA-965P-DS3
This is a socket LPA 775 motherboard, it will accept almost all core 2 / quad core intel cpu's, here is the full list from gigabyte.
(you may need to unpate the bios for some CPU's)
http://ee.giga-byte.com/products/mb/cpulist/ga-965p-ds3_20.html
Sep 01, 2010 | Gigabyte 965P-DS3 (GA965PDS3) Motherboard
965P DS3 v3.3 Wont Keep overclock
cmos chip on motherboard might be bad or theres a jumper you need to set to change bios settings. mabey the mobo won't take the the upgrade.
Dec 31, 2008 | Gigabyte 965P-DS3 (GA965PDS3) Motherboard
No Display
Try to remove the motherboard (BIOS) battery in order to return to it's manufacturer's default settings....
Oct 18, 2008 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
Logitech r-20 Speakers
Appreciate the direct "Ask Me".
It would seem that the documentation where you sourced the info S-Series Ultra Durable Motherboard. 945PL-DS3/S3 (rev.2.0) is intended for a number of different models. From what I can gather, you have a Giga-byte motherboard either a GA-945PL-DS3, GA-945PL-S3 or a GA-945PL-S3E all Rev. 2.0.
Assuming that it is a 945PL-DS3 (rev. 2.0), then the audio driver would be "Realtek Function driver for Realtek Azalia audio chip (Including Microsoft UAA Driver)". Pls verify if it were so.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 27, 2008 | Logitech R-20 Computer Speakers
My computer restart
Goto -->My computer---->Properties---->Advanced tab ---> Click Startup and recovery button ----> uncheck the Automatically restart.
If any problem in ur computer this settings restart the computer.
Hope this will help you......
Aug 07, 2008 | Gigabyte Computers & Internet
Intel Motherboard Logo
215 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
Computer Links
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
