Question about Averatec 3200 Notebook
Will not boot
What does Primary Master Hard Disk Error mean, will not boot?
Can get into BIOS, setup, but does not find hard drive.
    Genius:
  • 1,601 Answers
Sounds like the hard drive or the controller went out on it.
Posted on Dec 15, 2007
Primary master wdc
Primary Master .
This is where the hard disk parameters are entered for the primary master IDE/ATA device, the first drive in a modern IDE system. See the hard disk section for details on what these terms mean and how these devices are set up. The various settings for the drive are discussed in detail in the IDE Setup / Autodetection section. The default setting for this on a system with IDE autodetection, is usually "Auto"
WDC That Mean Western Digital Company.This's Logo HDD.
First Time If you have Problem With Bios You can Select Load Default Bios to clear any fault setting before.and select Save&exit.
To verify problem again.
Jun 22, 2015 | Computers & Internet
Siig sc-sat212-s4, stops boot when connected
While most computers are capable of starting up properly with external drives connected, from time to time the external drive can cause confusion during the startup process. The computer may attempt to boot from the external hard drive rather than the primary internal drive. This causes the computer to fail during startup because the external hard drive does not have the operating system installed on it.
Disconnect the external hard drive from the computer. In order to minimize the risk of damage to or loss of files on the external drive, shut down the computer if possible, or hold down the power button on the computer until the computer turns off and then disconnect the external hard drive. Restart the computer with the drive disconnected. If the computer still does not start up, it is possible that the computer is attempting to boot from the external drive. Reconnect the external drive and restart the computer. Watch the screen as the computer boots up. A prompt will appear indicating which key to press to enter "Setup" or the "BIOS." Press this key when the prompt appears. On many computers the key is either Delete ,F2 or F10. Use the keyboard of the computer to navigate the "Setup menu" that appears. (Advanced Bios Features.) The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ? or using the arrow keys you can load failsafe or optimized defaults this will set the boot order. Highlight the option for "Boot Disk" or "Startup disk" and select the "C:/" or the primary internal hard drive. Press the associated key, labeled so on the bottom of the screen, to save the changes and restart the computer. This will allow the computer to boot from the appropriate drive. Hope it helps.
b>
Jan 23, 2013 | SIIG Scsat212s4 Pci Serial Ata 2 Channel...
How do I go into bios to make my primary 1 hard drive found
During the boot process you will see on the screen to press a certain key to enter setup usually the delete or f2 key this will vary depending on your operating system and computer
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change the first boot device to your hard drive)
Hope this helps.
Nov 25, 2012 | Computers & Internet
When i installed hard drive and set the jumper on primary master it dint show up and in bios the txt is showing like that primary master drive 0 (not installed)
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test or replace all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard)) drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
? single or master :::::
master with slave ::'::
???????????????? slave? :::':
note the plastic jumper is
Feb 06, 2011 | Seagate Barracuda 7200.7 40 GB Hard Drive
Boot error always
Hello sir, hi your boot error can be caused by the following:
  1. Your IDE hard disk is not the first boot, and wrong available boot on the bios. Check your BIOS setup for proper boot device.
  2. Your IDE hard disk has bad serctors, since its P4, I estimate your drive to be 8 years or more. You may need to format the hard drive again and reinstall your OS (windows XP).
  3. IF your HD cannot be formated, or no amount of windows installation can be done on the disk, its time to replace it.
  4. Your IDE cannot be detected by the motherboard. check your BIOS configuration for proper hard disk setup.
  5. Your IDE hard drive and your CD drive are both master or both slave, set the hard disk to master and the CD drive to slave. The settings can be seen on the case of the HD and CD drive.
  6. Your IDE ribbon cable is bad.
  7. Your 4 pin molex power cable to the HD is loose.
If I miss out something, please let me know. thanks.
Nov 08, 2009 | ASUS P4S8X-X Motherboard
Cloned hard drive "C" (WD 40GB) to A Deskstar 8oGB using external enclosure. When I remove the old drive and install new drive and boot up I get Msg drive 0 not found retry or enter setup. If I enter setup...
there are few thing you ahve to keep in mind
there are two type of hard disk
1. IDE
2. SATA
As per your hdd capacity it should of IDE type.
Now there are two IDE slots on motherboard. One is Primary and other is Secondary
You can fix two hdd with one IDE Slot that mean you can fix up upto faour IDE hdd at a time
Now again there are Primary master and Primary Slave
and
Secondary Master and Secondary Slave
Now You have to examine what was the location of previous hdd
1 Primary Master
2 Primary Slave
3 Secondary Master
4 Secondary Slave.
Now you have to make a HDD master or Slave.
just in between data cable connector and power cable connector there is a jumper. that specify the master or slave. do reply me if it works well thanks
Oct 01, 2009 | Hitachi Deskstar 7K250 80GB...
What is the term ntldr mean, i get this message when trying to install a new hard drive
Computer hard disk drive is not properly setup in BIOS
Verify that your computer hard disk drive is properly setup in the BIOS / CMOS setup. Improper settings can cause this error. Additional information on how to enter the BIOS / CMOS setup can be found in document CH000192.
Mar 23, 2009 | Computers & Internet
Primary master hard disk error
i also need help
my motherboard cannot detect also my SATA harddisk
my Mother board is K8V-X but in boot options i see my harddisk
but in main menu no SATA..
so thats why i cannot reboot or reformat my pc
May 29, 2008 | ASUS K8V-MX Motherboard
Will not boot avaratec 3260
Most likely it is one of two things. Either your hard drive has died, or your hard drive is not properly seated in the notebook.
Check the drive to make sure it is seated properly and securely.
Restart your notebook, enter setup, select auto for the hard drive selection, save setup and restart.
If that doesn't fix the problem, you most likely will need to replace the hard drive.
Dec 15, 2007 | Averatec 3200 Notebook
Problems Installing my 160 GB Seagate SATA HDD
Check the SATA/RAID controller setting. It could have been set to [Disabled] Refer to your user?s manual for a detailed description on how to enable the onboard SATA/RAID controller by adjusting the jumper or BIOS settings. Regards SparkGap
Sep 24, 2007 | ASUS P5RD1-VM Motherboard
Averatec 3200 Notebook Logo
82 people viewed this question
Top Averatec Computers & Internet Experts
k24674
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
