Zenith floor model tv model # SG2719TR
My T.V. wouldn't do anything. I couldn't even turn it on. I unplugged it then plugged it back in, it worked fine. It happened again, this time when I tried that little trick Y-C and the time came up but no picture or sound. Where did the Y-C come from & how do I get rid of it? I'm lost without my T.V.
Thanks,
snakehead
  • 1074 Answers
SOURCE: TXP3071WHX/XAA Won't Power On
Hi greetings from belize after your set was pulled from the WALL it got a static causing the microchip to damage ,that is what you call a dead set.take it to a tech to have him look on to replace the chip and your regulator.or the whole power supply.good luck
Posted on Mar 21, 2007
SOURCE: Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Posted on Jul 19, 2007
ChadL777
  • 69 Answers
SOURCE: Picture turns into looking like a reverse negative
Often you will get a bluish or reddish looking picture if your wires from your cable box/satellite or DVD player are inexpensive RCA type video cables. Try using a nice set of component cables or HDMI cable from your sources to your TV. If this is your setup, try this first...its the most inexpensive first option.
Posted on Dec 31, 2007
  • 1153 Answers
SOURCE: RCA Television D52W14
The first thing in this unit is to check the ribbon cable that goes from the front control panel to the back ssb board, I would unplug and replug to make sure seated properly. Then try it again. There are alot of screws to take out but worth it if this solves the problem.
Posted on Jan 08, 2008
SOURCE: Rca Big screen shut down and now no power
NO audio and no picture .... no power to on - off button. Checked outlet and it is good .... cable connection good - checked with another tv....
Posted on May 15, 2008
MY 1994 ZENITH TV MODEL #SMS7571BT WILL NOT TURN ON, i HAVE TRIED PLUGGING INTO DIFFERENT OUTLETS, USING THE REMOTE, I EVEN TOOK THE BACK OFF TO SEE IF ANYTHING LOOKED WRONG, ITS A LITTLE DUSTY BUT NOTHING...
The power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem
May 31, 2011 | Televison & Video
1997 ZENITH TV WON'T TURN ON. UNPLUGGED, PUSHED POWER BUTTON FOR A1-2 MINS. AND PLUGGED BACK IN BUT NOTHING.
hiya mate if you have had this tv since 1997 exelent the life even for ordernary tvs is only 5 years time for a new one sorry mate
Dec 11, 2010 | Zenith Televison & Video
Power problem with Zenith D56W25 56 in. Rear Projection Televisi
you can try to shut the tv off ,unplug the power to tv and anything that is powering the tv[pvr] .now plug in the power to the box first wait,30 seconds or so ,now plug in the tv wait,now turn the t.v. on,WAIT unless it starts smoking just wait.see what happens.
Apr 18, 2010 | Zenith D56W25 56" Rear Projection...
Tv wont turn on... light blinks yellow as if its going to power on.. and just shuts off... for my zenith dlp 52 inch tv
I had this same problem. The Zenith rep told me to unplug the TV, hold the power button down for 30 seconds, plug it back in and then turn it on. It worked and I haven't had a problem with it since. I hope this helps. Good Luck!
Mar 06, 2010 | Zenith D52WLCD 52" Rear Projection...
POWER SUPPLY
zenith are famous for bad soldering even going back to the 80s with the 960-05 boards in the space command sets.
i would pull out the circuit board and check the soldering before doing anything else.
Sep 09, 2009 | Zenith Televison & Video
Problems with B25A10Z Zenith 25" tv
that model has had a few different problems that cause this. bad micro,bad regulator,bad caps and tuner shorts. suggest you take to the shop for an estimate
Sep 07, 2009 | Zenith B25A10Z 25" TV
High pitch buzzing.
Hi there
Let's make ur problem a bit clear. "white lines" how? where?
meaning retrace lines with full raster or a single vertical line?
buzzing sound? without even turning the power switch of the TV to "ON" or when u just plug the power cord?
I'll check for schema, mean while can u tell me where the resistor leads to? is it a fusible resistor? if so , to which area the resistor suppliers power?
Regards
Rifaa
Nov 12, 2008 | Zenith C27A24T 27" TV
Zenith Remote controller
It's a Zenith remote, MBR 3440 is the model #, 124-202-01 is the part #. To program, press and hold PRG button until red light stays on, press TV,AUX etc, enter 3 digit code (www.xdiv.com) press Enter.
Jan 10, 2008 | Zenith HCS3000R Headend Controller For...
Only DVD works
rca jacks may be goin out, one of our did that and i had them replaced for under 20 bucks, jason
Dec 13, 2007 | Zenith B25A02Z TV
Cannot turn television off without unplugging
it might be due to on/off switch failure.
Oct 14, 2007 | Zenith C27V22 27" TV
Televison & Video Logo
90 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
