Question about Frigidaire FEF336BC Electric Kitchen Range
Code F9 I start the self clean, and it shuts down and flashes code F9
  • 1 more comment
  • dallasbragg Jan 03, 2008
    Having the same problem. Where and how do I get another EDC?
  • Anonymous Apr 25, 2008
    oven beeps, door locks, and flashes F9
  • Anonymous Mar 17, 2014
    i stoped the oven while in self cleaning mode
I am having the same problem...don't understand that solution at all?
Posted on Jan 03, 2008
    Sergeant:
    Champion:
  • 310 Answers
Lock motor relay watchdog is active when it should be off Microprocessor checking the operation of the EDC lock relay after self clean is selected, relay failed. Replace EDC.
Posted on Jan 01, 2008
Frigidaire smooth top electric range flashes f9 after cleaning
The "F9" error code means the EOC (electronic oven control) has found the lock motor switches to be out of sequence or shorted.
Test switches and if there is nothing wrong then replace the EOC.
What is the model number?
Nov 28, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Kenmore Electric Range model 790 has F9 & F1 code error
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
Apr 20, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Stove door locked and continues to beep and flash code F9
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$$%^^%$
Mar 27, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Door locks and F9 fault codes
Feb 24, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Cancelled self-clean, F9 code came up, door lock light flashing, can't use oven
HI,
your model number confirms that your range was manufactured by WCI (Frigidaire). although this doesn't help you now, it may help if parts are needed.
now, there is an indepth guide online to fixing this common problem and I would like you to go through it and see if it helps you solve your problem.
http://www.applianceaid.com/clean-lock.html
If you have found this site previously then I apologise, if you still need help, by all means post again and someone more qualified may help.
Hope this is of use to you ;)
Phil
Oct 25, 2008 | Kitchen Ranges
My oven flased an F9 error....
The solution to this issue is to finish running the self cleaning feature to this oven, Shutting off the oven or opening the door before the self cleaning feature has completely run will send a F9 error from the safety co0ntrol unit feature built in to the system bios of the control circuit, You will need to close the oven and set the option self cleaning to run now. if your error message prevents you from taking these steps you will need to unplug the oven from the wall socket and let it sit for an hour to reset the screen and then run the self cleaning feature all the way trough, it will shut down on its own when the self cleaning cycle has completed
Oct 24, 2008 | Frigidaire FEF366 Electric Kitchen Range
Error code f9 on self cleaning range.
I get a f9 message when I turn my oven onto clean and then it shuts off and goes to clock...what's the problem
Oct 01, 2008 | Frigidaire PLEF398AC Electric Kitchen...
Jenn-air shut off while cooking giving f9 code
code F9 keeps flashing when I attempt to turn on my oven. What does this mean?
Sep 03, 2008 | Jenn-Air JES9800A Electric Kitchen Range
Frigidaire FEF336BC Electric Kitchen Range Logo
174 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
