Help. My Palm is sick.
It turns on. I get a Tungsten "welcome" screen.
It goes to time and date page then freezes. Won't respond at all.
Can't even turn it off. I've done repeated resets. Same scenario every time.
Doctor, is there any hope?
I turn it on and is freezes on initial time and date. Several soft reset done without any help. Even did one hard reset. It worked OK for about 20 min. Then started flickering and the stylus response was extremely slow. Now having the same problem with it freezing on the time and date. HELP!!!I turn it on and is freezes on initial time and date. Several soft reset done without any help. Even did one hard reset. It worked OK for about 20 min. Then started flickering and the stylus response was extremely slow. Now having the same problem with it freezing on the time and date. HELP!!!
You can't post conmments that contain an email address.
Have you tried doing a soft reset? To do a soft reset, use the tip of the stylus to gently press the reset button inside the hole on the back panel of your handheld.
You can try doing a hard reset. A hard reset will delete everything on your device. All your
data will be deleted, and formats, preferences and other settings are
restored to their factory default settings. Don't perform a hard reset
unless you've backed up your data, or you're willing to lose everything. Here is the link for directions for the Hard Reset:
Hi, I recently had some problems with my Palm. I went through the Palm online chat support which was free. You can do phone support but it will cost about $15. Here is a link to Palm support. If you scroll to the bottom of the page there is a link for the chat service. I have very good results. Best wishes. I hope this works for you.
When you turn your Palm on, on the main page there should be a list of icons. Make sure in the upper right-hand corner All displays with an arrow pointing down.
Then, click on the World Clock icon to change the date/time for your Palm.
I had the same issue. What you need to do is to hold the power on/off button than press the reset button. The screen turns off (get black) than the will ask you to make a hard reset (which end up deleting all datas). The Palm will power on like the first time you turned it on after you bought it. Than depending which version you have it will possible ask you which language you will like to have as default. After selecting you neet to setup the rest. If this is done you sync it all data will come back :-)
diddo, what gives?
