Question about Frigidaire ATF6000ES Front Load Washer
Frigidaire Affinity ATF6000ES Error code E-48
Can anyone tell me where I can find out what this code Means?
I had a tech from Howards out today, He said a wire had come loose.
2 loads later Same problem.Washer turns off Before spin cycle Clothes stay soaked.I thougt the spin cycle had failed but after watching the washer during a cycle it turn itself off in the wash process
Any help would help
  • Anonymous Dec 31, 2007
    machine starts washing for a few minutes and then before it spins the machine stops and starts at the beginning, and then when we cancel the load the door won't unlock.
  • 264 Answers
You might have some thing in the pump check pump first if Therese nout in there then it might be your brashers you will have to look on ebay and don't for get to wright your model number down there really cheap if you get stuck get back to me i will help
Posted on Jan 07, 2008
Frigidaire affinity error codes
I appreciate your inquiry, friend!
I see that you would like a list of Frigidaire Affinity washer error codes. I was unable to locate a full list of codes. Are you currently experiencing an issue with your washer? What error code is being displayed? With more information I will be able to assist you further. -Matt
Mar 12, 2015 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
What do i do when my washer affinity frigidaire displays E20
Hello friend, thank you for your post!
I see your question is labeled under Frigidaire washer, ATF6000ES, and your washer is receiving an error code of "E20". "E20" stands for the water is not pumping out fast enough which means it could be an issue with your control panel or drain pump. I would recommend having a professional come out and properly repair your appliance. I hope this is helpful. -Matt
Sep 27, 2014 | Frigidaire ATF6000ES Front Load Washer
What is ef 0
Open the lower panel and search for a trouble shooting tech manual. There inside the you'll find the error codes.
Feb 07, 2014 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
How to run diagnostic on frigidaire affinity ATF6000ES front load washer
Hello Tony bent - What issue is the unit experiencing exactly? Can you tell me if it is displaying any specific error codes? If I know more information on what the issue is, I can try to better assist you further.
Sep 26, 2012 | Frigidaire Affinity ATF7000E Front Load...
Fridgidair affinity washer paused with error code EF2
According to ( ) : EF2 Condition Too much suds Check/Repair Reduce the amount of high-efficiency (HE) high-efficiency detergent being used in the washer.
Aug 31, 2012 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Frigidare affinity error code E23
Hello, welcome to FixYa.
I understand you have a Frigidaire Affinity ATF6000 series washer with an error code E23, correct ?
If that is indeed the error code you receive in the display it is potentially bad news unfortunately, as that indicates either loose wire (fingers crossed) or a failed drain pump relay on the control board. This is how it is described in the Frigidaire service tech manual.
Further to this, if it is not a loose wire at the pump or on the control, the only remedy is to replace the control board, unless you are proficient at electronic repairs (including soldering techniques) and can purchase an exact relay and replace just the relay...though that doesn't guarantee the control hasn't suffered collateral damage in the process.
A new control is part #134523106...
it is available at several on-line parts vendors such as "" or "" to name a couple as these links will provide.
Hope this answers your question and helps you move forward. Let me know how you make out or if anything isn't clear. Good luck and thank you for choosing FixYa today.
Macmarkus :)
Oct 29, 2011 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Frigidaire Affinity ATF6000ES frozen
IF there is an E attached to the 45, it is your control board and the control board would need to be replaced. This is per the "Washer Tech Data Sheet"Hope that helps...
Mar 19, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Affinity/dr error
dr code means door not closed
get some crc spray and spray into lock on machine
that will lube the workings and should fix problem
Mar 13, 2008 | Frigidaire ATF6000ES Front Load Washer
It means the door isn't shut all of the way.
Aug 17, 2007 | Frigidaire ATF6000ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
443 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
