Question about Mitsubishi WS-65511 65" Rear Projection Television
Green led light on for 3 seconds then off, will not power up
Would like to get pictures and directions of DM board with bad capacitors. Heard a lot about bad caps. Also had bad fuses F9A05 & F9A04 replaced along with coveregence IC-STK392-570 replaced.Tried diagnostic code and got diagnostic code 12. But still gettimg green light on for about 3-4 seconds then off again, will not power up.I checked on in which I think are the caps, one looks swollen but will replace all, need to know if I'm looking at the right thing. Will be greatly apperciated if anyone could help! E-mail address is dvmanderson@comcast.com. Happy Thanks Giving God Bless!!
Hi I have the blinking green light next to the power button, I have a Mitsubishi wide screen hdtv made in 2003. It will blink for a minute then stop. I would like to know what to look for inside and any advice on how to to replace the needed parts. My e-mail is simitom1@yahoo.com Thank you..
  • katecraft Jan 02, 2008
    same problem tried to reset it waitting for the help line to call me back any idea of what it maybe something I can fix or should I call the service center??????
  • martsk Jan 04, 2008
    I am having the same problem. I can't get the green light to stop blinking even after I try to reset it. Nothing I do works...
    President:
  • 4,402 Answers
Blinking Problem
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Picture of bad caps
http://www.auctioncreations.com/wd62525a.JPG
Posted on Feb 25, 2008
Blinking light with no picture or sound
If you have a green blinking light,
Most likely issue is with bad capacitors on the DM an FMT boards.
1) Look for bad 1000uf 16v caps on the dm board and the fmt board.
2) checked surface mount fuses (small white boxes) on DM and FMT board
Look carefully for other bad capacitors in the general area.
Start here and let me know the results.
Note, there is a lot of disassembly to get to these boards. Not a fun project.
Feb 20, 2011 | Mitsubishi WD-62525 62" Rear Projection...
I fixed the blinking light, but still no picture
The constant blinking green light means for one minutes and then goes solid green, that the TV is not booting up. This is a common problem on this set.You need to remove the shield from the DM board (standing upright on the left where the DTV RF connector is)and inside you will see the four leaky capacitors (1000 MFD 16 VOLT)replace them,plug the TV in and wait 70 seconds for the blinking light to stop,then turn on the TV.The hard part will be removing the board from the TV(lots of screws and connectors,takes time)
a3d2d2a.jpg You must do some checks first:LED does not stop blinking after plug in. Verify the standby supplies, 12-volts at connector KA pin 17, 6-volts at KA pin 18 and the 28-volts at KA pin 19, if the supplies are present suspect the DM PCB part # 934C067001 LED does not stop blinking after plug in. Check C9B01, C9B02, C9B10, and C9B11 (1000 UFD 16) on the DM PCB, if they are bad replace them with part # 181P734030 (680 UFD 16 V). LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature; this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds . LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector RF pin 4 and 5 on the Signal PCB if low suspect problems with the switches/buttons on the Control PCB part # 935D736001. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector RF pin 4 and 5 check good suspect the E2P PCB part # 934C061001.
Just click below for more information.;
http://www.fixya.com/support/t838883-mitsubishi_wd_52825_tv_wont
Hope it may help you ;
Regards,
VOTIT
Oct 04, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Ws-48313 no power
This model is equipped with a keyboard lock feature; this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds. 2. (Power LED may be on after plug in) check for no less than 4.4 volts DC at pin 3 of PC9A21 on the Power PCB, if low or missing replace PC9A21 part # 268P058020. Hope this helps if not let me know and I will go further
Sep 07, 2007 | Mitsubishi WS-48313 48" Rear Projection...
Tv wont turn on just the green light comes on 3 times
Ur tv DM power supply board have dead leakages capacitors.U have tools,solders and soldering iron?U know how to do soldering.Tries websites like Tvrepairworld.com,Tvrepairkits.com buy a capacitors kit to replaced dead leakage capacitors to the DM power supply board.
Jul 05, 2010 | RCA P61940 61" Rear Projection Television
Green power light keeps blinking
hi friend,
Repairing It Yourself
If you decide to repair the TV yourself, I recommend that you obtain a copy of the repair manual for your Mitsubishi TV from the Techlore website by going to Mitsubishi Service Manual. It will provide some direction, however it is technically written and may be difficult for the NOVICE to understand. If you are unable to locate the the service manual for your specific Model at the above Techlore link, you may need to purchase the service manual online at ServiceManuals.net.
If you decide to have a service technician do the repair, insist that the "DM" module is removed from the TV and ONLY the four 1000uF, 16V Capacitors (Caps) located on the DM Module are replaced. MOST techincians will INSIST on replacing the entire DM Module and not simply the capacitors. The cost is about $200 for a technician to replace the capacitors and $1000 for replacement of the DM Module. As you will read below, doing the repair yourself will cost less than $4.00 for the 4 Caps.
A Few "Cautions"
  1. Keep yourself "grounded" when working with the circuit board. Static electricity will destroy electronic components.
  2. When replacing the Capacitors, press them "down" onto the circuit board as far as they will go, hold them down, solder into place and clip the excess terminal lengths flush with solder. Only by doing this will the metal shield (little silver box) slide down and over the circuit board during re-assembly. There is not a lot of clearance when doing this, as the 105C Capacitors are slightly longer that the originals. With minimal effort everything does fit back together.
  3. Use ONLY 105º C capacitors with a voltage rating of 35 V.
  4. Re-insert the DM circuit board into the Mother board; press virmly and ensure a proper seat of the DM board. Next, slide the metal case down and over the DM circuit board. Refer to my "Lesson Learned."
Basic Troubleshooting
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
hope this helps u
please rate me.....................
thank u for using fixya
regards
sivaranjini
Nov 24, 2009 | Insignia IS-LCDTV32 32 in. Television
Mitsubishi tv model ws-65315, when i turn the set on, the green light comes on for a second then the set turns off what could it be
Check the voltages at the test points on the power supply. If the voltages are correct and all the fuses are fine, check for swolen capacitors on the format and the DM boards and replace them
May 31, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Green light flikering
Replace all 7 capacitors in the DM Module on the DM Power Supply Board. If it is similar to the WS-65869 and WS-65513 it will have a metal enclosed DM Module at far left of chassis, looking from rear. About 4 or 5 connectors, screws, and Module slides out. Take top shield off. Take good notes or use digital camera or video recorder to make re-assembly easy. These capacitors are 1000uf@16 volts. They always check good, just replace them! After re-assembly plug AC in and wait 90 seconds or more (green Timer LED will stop blinking), then press Power button. If Timer LED doesn't stop, look for small pinhole (System Reset) and press switch with pen or small screwdriver, then wait for green LED to stop blinking. Then Power On TV.
Feb 08, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WS 65909 Power
The constant blinking green light means that the TV is not booting up. This is a common problem on this set.You need to remove the shield from the DM board (standing upright on the left where the DTV RF connector is)and inside you will see the four leaky capacitors (1000 MFD 16 VOLT)replace them,plug the TV in and wait 70 seconds for the blinking light to stop,then turn on the TV.The hard part will be removing the board from the TV(lots of screws and connectors,takes time)
Just click below for more information.; http://www.fixya.com/support/t838883-mitsubishi_wd_52825_tv_wont
Regards,
VOTIT
Sep 27, 2008 | Mitsubishi WS-65809 65" Rear Projection...
If you got a 12 then that means no code error, check again and make sure. or go to www.ctechnicians.com and read what is said.
Nov 22, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Green light keeps blinking? Any clues
Sep 23, 2007 | Mitsubishi WS-65613 65" Rear Projection...
Open Questions:
See all Mitsubishi WS-65511 65" Rear Projection Television Questions
Mitsubishi WS-65511 65" Rear Projection Television Logo
166 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
