Question about Acer Aspire 3002LCi Notebook
No power I have had no known damage to my 2 year old laptop,  Recently I cannot get it to power up checked all connections ok, but still no power up.  The yellow light flashes on the front when i try to power up, but then stops flashing.  Any help?
  • 383 Answers
No power or computer does not turn on. Additional information to why you may be recieving now power from the computer and/or why the computer is not turnning on.
Computer Power Supply Information Because of these precautions, no extensive information will be found on this page about opening power supplies.
No display on monitor. If no power light (green or orange light) is seen on the monitor display try pressing the power button until it comes on. If no light comes on after several
Good Luck/Please dont for get to Vote.Thank you.
Posted on Dec 15, 2007
Toshiba L305 wont hold charge
I will suspect the battery first. I make sure the battery I reseat the battery, make sure the charger is well plugged in and no damage to the cable. The next step is that I would test with a known good battery and if the problem still persist test with a known good AC charger. If the battery and AC charger and its cable/cord are determined to be good I will be thinking of big/expensive issue with main board which may not worth the trouble if the laptop is relatively old like 2 years
Feb 12, 2012 | Toshiba Satellite L305-S5907 Laptop
I have a acer 4740g laptop.I ve got display problem.It shows several lines and i cnt work on it.Recently it got little pressed on its display.Can any1 help me?
Hello shreejan_man
First thing to do is to test the screen. Also you have not mentioned if there is any cracks or damages.
Plug the laptop to an external monitor (any type will do). If the display on the external monitor is OK then it means the laptop screen is damaged.
If the display on the external screen is the same as the laptop then the problem is internal with the graphic chip or the video contacts.
this laptop is not that old since acer released this model last year. Check you warranty status on it. Some acer laptops come with two year warranty. Check the laptop carefully, if there is no sign of physical damage, (cracks, chips ...) then take it back as a warranty issue.
Good luck
please leave comment, vote if this helped.
Feb 24, 2011 | Acer Computers & Internet
My Dell Inspiron 1525 is now around 4 years old and recently it has not been able to charge and only works when it is plugged in. Also when i start the laptop, it displays a message saying i need to...
As you say the system is 4 years old update the bios
your download link is here!
IMP. Be sure to plug in the battery and it should be charges above 10 % and the system should be connected to the mains power supply also ensure there will not be a power outage during the update process
this will resolve the issue 100 %
Dont forget to say thanks!
Aug 11, 2010 | Dell Inspiron 1525 Notebook
Why is the red light on when connected to the mains? Also the battery doesn't seem to be charging. The pc is only 6months old and used once or twice a week?
1. your battery may need replacement
2. your power supply may need replacement
3. The connection power jack may be damaged and not receiving contact with the power supply.
4. the longevity of a laptop battery can be from 1-3 years max depending on usage.
5. check the power supply adapter with a volt meter to see if it is giving proper voltage.
Mar 13, 2010 | Samsung NC10-14GW Notebook
Toshiba Laptop approx 3 years old. It fell out of
Please handle your PC with care. Since it fell abt 6 in., it must have some connection problem that will still be repeated as soon as it bangs. If it doesn't work in few days from now, check the HDD it may have caused damage because of the fall. Then if you can open any board, unplug connections from outlets then press soldered connections in the motherboard.
Just a pre-caution. But if it persist, see your supplier's technician.
Thanks
Dec 11, 2009 | Computers & Internet
How do I chaarge the battery on my lap top
1. connect the ac adapter from a known good power source.
2. plugin the battery to the laptop.
3. check bios if batt is recognize or performing normally (to do this turn on laptop keep tapping f2 to boot to the bios options)
4. just leave the laptop with the ac adapter connected and it will charge laptop automatically, just leave it for about 4 hours.
Oct 13, 2009 | Dell Latitude D600 Notebook
My Phillips 32pw8759 TV screen is Permanently blank
There might have been a power surge that had damaged the two units. For the reset, having the tv unplugged overnight should do it. If it does not work you may want to check the power supply of the tv for leaking capacitors or burned resistors or loose solders.
Aug 15, 2009 | Philips Televison & Video
Computer doesn't accept power
check the metal post inside the power jack connection. very carifully try to wiggle the metal post and see if it moves or if its there at all. if the post wiggles, it is probably broken and needs to be re-soldered...only someone who knows how to do that should as you could damage the board trying yourself.
also try plugging it in without the battery.
do any lights come on at all when its plugged in or power buttons are pressed?
Mar 28, 2009 | Dell Inspiron 2200 PC Notebook
New 6600 mAh battery won't charge
Is the AC adapter the original that came with the laptop or is it a replacement?
Check the label on the laptop (on the bottom of the laptop) for the voltage and current requirements.
Check voltage output of the adapter with a multimeter, this voltage should be slightly higher that the voltage than what is shown on the adapter's label because there is no load on the adapter.
It could be that the current (amps) that the adapter is delivering less power than the laptop's requirements, whilst it can power the laptop it may not be sufficient to charge the battery fully.
Try charging the battery overnight by shutting down the laptop but leaving it connected to the mains. Then boot up the laptop in the morning and check the battery's charge state. If the battery is at or near full capacity, then the problem is a (part) faulty adapter.
Jan 07, 2009 | Acer TravelMate 8200 Notebook
Acer Aspire 3002LCi Notebook Logo
583 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
