Question about NetGear RangeMax WPN824 Router
Reset how do I reset my wpn824. I forgot my password.
  • 560 Answers
You can reset your Netgear router/wireless wpn824 router to the factory settings from within the router manager. The reset procedure removes all user-configured settings and returns the router to the original factory settings.
For this reason, only reset the router if you encounter problems that can't be solved with other methods.
Step 1: Check that your Netgear router/wireless wpn824 router is properly connected with your system or not. If it is OK, then press reset button on Netgear router for at least 10 seconds. The 'test' light should flash during this process.
Step 2: Now open browser and enter Netgear's IP address into the address bar. Generally, '192.168.0.1' is the Netgear router IP address but you can find specific IP address in Netgear wpn824 router manual.
Step 3: Now enter your default username and password to log in to router.
Step 4: Click 'Erase' button under the 'Revert to Factory Default Settings'. This process will erase all your previous changes that have been made to the router and restore the configuration settings to factory setting. Don't interrupt the process until the process is finished.
Once the router's 'test' light has stopped blinking and the configuration page you are on has refreshed, the wpn824 router has been reset.
Feel free to get instant online Netgear router
support at http://www.vtechsquad.com/netgear-router-support/ to fix Netgear router/wireless router issues.
Posted on Oct 12, 2012
  • 108 Answers
On back side of the router you will find reset button Take a look at below screen shot, keep on pressing it for few seconds router will reset back to factory settings.reset - ff3648c.jpg
Posted on Dec 15, 2007
2 Suggested Answers
jaye_ellen
  • 591 Answers
SOURCE: netgear wireless router wireless light won't light
Once \you reset your router, the router must be set up again in orser to use it wirelessly. Connect with CAT-5 cable router to computer, go to http://192.168.1.1 log in to router with name = admin and password left blank. Go into the Wireless section, set your SSID (Network Name) and whatever security you want to use. Write it down, do not forget, you should be back on line. Contact me if this does not work jaye.ellen@gmail.com
Posted on Dec 20, 2009
Need to reset password for belkin54g
Hello.
If you are having trouble logging into the router's setup page and you forgot the password for the router, you need to reset it to default settings, thus if you do that, you need to setup the router again.
To reset the router to default settings, press and hold the reset button on the back panel of the router for 30 seconds. Once the lights are stable you need to setup the router again just like what you did the first time.
Dec 01, 2011 | NetGear RangeMax WPN824 Wireless Router...
How do I restore the router back to it's factory user name and password? Since I forgot the setup username and password.
Press and hold the Default reset button on the rear panel until the power light blinks... about 10 seconds
Release the button and wait for the router to reboot
Jan 04, 2011 | NetGear RangeMax WPN824 Router
Forgot my network password
You have to options, use a computer that is connected to the network either with a wired connection or a wireless that is connected and go into the router using it's IP address and check the password that way, or reset the router to factory settings and set it up again
Aug 19, 2010 | NetGear RangeMax WPN824 Router
Forgot my password to allow other devices to access my network.
Just reset your router and use (admin) for user name and password. To reset your router you can see a small hole in your router which is labeled reset. Use a pin and insert it to the hole and push.
May 31, 2010 | NetGear RangeMax WPN824 Wireless Router...
What do i do when i forgot my routor password?
There is a small hole on the back of the WPN824 right next to the rightmost ethernet connector. Press the button inside using a paper clip for 15 seconds. This will do a factory reset of the device.
However, this will wipe *all* of your settings.
The router resets its LAN IP adress to 192.168.1.1 and the administrator password to "password".
Feb 06, 2010 | NetGear RangeMax WPN824 Router
Netgear wireless router wireless light won't light
Dec 19, 2009 | NetGear RangeMax WPN824 Router
Forgot password for my netgear range expander
Reset it and reconfigure it. You need to know the configuration of your wireless router to make your range expander work again. Can you still connect to the Internet without the range expander?
Sep 12, 2009 | NetGear RangeMax WPN824 Wireless Router...
FORGOTTEN ROUTER PASSWORD
you can accesss it with following default link
http://192.168.1.1 or
http://192.168.0.1
then type username as "admin" and password as "admin" or blank or "password"
then go to wi fi security then go to encryptipn key then checkthat key it is your password for network.
Jun 25, 2009 | NetGear RangeMax WPN824 Wireless Router...
Forgot my password
There will be a "reset" button somewhere on the back of the router ...no doubt a small hole you need to stick a straightened out paper clip into. Press the rest button and the router will go back to factory settings. Netgear usually use the user name "admin" and the password "1234" to log into routers for default. Any WEP/WPA settings you has set on the router will be gone too, so you need to go back in and set up your security again.
Dec 30, 2008 | NetGear RangeMax WPN824 Wireless Router...
Hi I forgot my password and cannot use my ipod touch because of this
the password to your router? default is admin:password
If you've changed it, you may have to reset the router. This can be done by using a paperclip inserted into the reset hole on the back of the router, and starting over!
NetGear RangeMax WPN824 Router Logo
381 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
