The 1996 Ford Bronco takes a 18" replacement wipers on both drivers side and passenger side. Don't just go by lengths though - when buying windshield wiper blades be sure to always use the application guide book at the store or now-a-days you can Google 'lookup wiper size'.
You want to look this up because correct wiper fit is more than correct length, it's also proper attachement. Not all attachments fit all arms. Using the application guide or looking up wiper size online will avoid headaches of buying the right lengths with the wrong attachements.
The replacement wiper blades will come with step-by-step, illustrated instructions and once you have the instructions and the wiper blades/arms in your hands in front of you, it will all make better sense and will an easy maintenance task. Very simple and takes 5-15 minutes usually not requiring any tools.
If in your budget, upgrade to the newer-style frameless "beam blades" which perform better than conventional framed wipers. I use Trico NeoForm Beam Blades which are fantastic.
Hope this helps!
