If go to start then run. That will open up a box for you. Type in that box cmd. When Dos opens type in ipconfig When you see the default gateway, writhe down those numbers. It should start with 192.168.?.?. Type that into the address bar once you've typed exit to make DOS disappear. This should take you sto your router page. Then you can start configuring your router.I hope that helps
Earthlink lists this as the number to call when you purchase someone else's router 1.800.327.8454. Hopefully if they are not the right people that can direct you to the correct people to call when you have earthlink's equipment.
I hope this helps.
When I try to install the router as per, the instructions, as I connect the line from the tetephone to the router the broadband disconneects.
Iv got a netgear wpn824 wireless router which iv had for a while, it has been unpluged for the last few months, I have tried to re-install the software but it will not allow me to start the setup process, Now it doesnt open the setup CD, can anyone help... PLS........
Running vista on new laptop. The laptop recognises netgear but will not connect to internet.
