Home | Kenmore | 53509 Dehumidifier | My kenmore deh...
Kenmore 53509 Dehumidifier
Problem for Kenmore 53509 Dehumidifier
My kenmore dehumidifier compresor runs the fan
By whattax on Sep 22, 2009
My kenmore dehumidifier compresor runs the fan runs but no water in the bucket . Compresor freon lines both same to have the same tempature ( flow and Return ) . Is a freon charge the answer ?
Comments:
Sep 22, 2009
- hing is clean and the unit is only 1 year old. (fourniershva)
Sep 22, 2009
Best Solution
posted on Sep 22, 2009
Helpful)
fourniershva
Rank: Guru
Rating: 93%, 59 votes
More than likely not. I would start by making sure all coils are clean, (both evap and condenser) and to make sure airflow is not being obstructed. Most factory charges appliances don't leak refrigerant and therefore should not have to be charged during there useful life. Hope this helps
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" It was a confirmation of what I thought, but still no water, even at 35%. " - whattax
Popular Solutions for Kenmore 53509 Dehumidifier
Questions and Unsolved Problems for Kenmore 53509 Dehumidifier
Do you recommend Kenmore 53509 Dehumidifier?
Answer
Answer
I left the equipment on for at least 3 hours and when i check it is empty
Answer
I used the tray instead of the catch basin and hose on my dehumidifier. How can I get it to work... (More)
Answer
Compressor and fan doesn't turn on what could be causing it?
Answer
My kenmore dehumidifier won't pull the moisture out of the air, the motor is runing when turned on... (More)
Answer
stops running . The unit will sit there for a few minutes then repeat the cycle over again. It is... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Kenmore 53509 Dehumidifier:
Top Dehumidifier Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dehumidifier Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
