Question about Hifonics Brutus BX 1605D Car Audio Amplifier
Hifonisc bx 1605d
Well the amp sent its main output stage to its line out stage. it smoked and burned up. i can see all the blown components there is three resistors and a vouple of transistors. all on the output stage. can i just replace these transistors and resistors.
    Problem Solver:
  • 8 Answers
I think you could but before doing that did the amp itself send the output to the line if it did then replacing the parts would be pointless. if it was a hook up problem then replace parts and don't let it happen again
Posted on Dec 15, 2007
I have a SPL phantom dk-3400 car amp and when i
Even withou the help of any diagram you have a visual indication. Look inside to the area of the burn. identify the component. check around the burned area for the cause of the burn. it could be the failue of the output or the power side. equipped with a multimeter you must be able to identtify stage by stage the short of the circuit. remove, replace and test. afterwards connect the woofer - check if your woofer coils are damaged too- Hope this helps? Good day
Jul 12, 2010 | SPL PHANTOM DK-3400D Car Amp
Will hilfonics brutus 2010d mono work??
Well with the correct powering system, heaps of paralleled 12 volt Batteries, & a Beefed up Alternator to charge them, I guess so, BUT it is only Mono, so you will need TWO to provide stereo output
Mar 06, 2010 | Hifonics Brutus BX 1605D Car Audio...
Brutus amp output problem
must be a bad amp..have you tried bridging them maybe youre channels are out it happens even if its brand new...factory deffects
Feb 21, 2010 | Hifonics Brutus BX 1605D Car Audio...
Does not power up
Use a meter, check voltage at main power input, should be at least 11 volts. Check the resistance on your ground and if you have it grounded to a seat bolt or side panel move it to the floor. ( don't drill without looking underneath!) you don't want to replace a fuel line! or worse!. Check your remote trigger for 12v and check the amps fuse. Beyond that, the problem would be internal and need serviced. If you can work at board level, post a comment and I can help you further.Hope this helps
Sep 30, 2009 | Hifonics Brutus BX 1605D Car Audio...
I got all power from my hifonics amp but no output. everything is hooked up correctly was working but all of a sudden stopped
check to make sure your rcas are good, check to make sure all your connections to your subs are good and if they are most the time this meens your pre amp in your amplifier is out.
May 04, 2009 | Hifonics Brutus BX 1605D Car Audio...
Cant get protect mode off on amp
you burned up a couple of dioeds if if wnt go back to a regular mode
Apr 01, 2009 | Hifonics Brutus BX 1605D Car Audio...
Denon AVC1530 Amplifier Protection mode
Protection means that the output stage of the amp has detected a problem. Usually this is because there is DC present on the speaker line indicating blown outputs. Figure on $25-$45 for parts plus the local labor rate for the repair.
Dan
Sep 07, 2008 | Audio Players & Recorders
No output
Maybe you should check your remote wire!
Apr 16, 2008 | Hifonics Brutus BX 1605D Car Audio...
Think my amp might be fried!!
if the connections is good,then you have no out,then the problem is inside the amplifier,you must refer a qualified personnel near you
to open your amplifier.
Feb 21, 2008 | Hifonics Brutus BX 1605D Car Audio...
P4004 - Blown Components
if burned components are on output stage or amplifier section on board..Then look at the oposite side of amp..Both amplifier section should be a mirror image oof componentc from other..that way you can know the values of parts.If they are on power supply section ..Then you might need manual if available..
Dec 23, 2007 | Rockford Fosgate Punch P4004 Car Audio...
Hifonics Brutus BX 1605D Car Audio Amplifier Logo
142 people viewed this question
Top Hifonics Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Jaime Hernandez
Marvin
Marvin
Are you a Hifonics Car Audio and Video Expert? Answer questions, earn points and help others
