Check to see if there is a pump filter, if not, then there is probably something stuck in the pump, you will probably have to remove pump to clear it.
Please rate my solution.
Thanks.
Was this helpful?
Yes
No
Popular Solutions for Tricity Bendix AW1000W Front
Our AW1001W is 2 yrs and 2 mths old. After a few weeks of strange intermittent banging during a spin...
(More)
Our AW1001W is 2 yrs and 2 mths old. After a few weeks of strange intermittent banging during a spin cycle (like a cricket ball bouncing round the drum), it has ceased spinning at all. So I tried to turn the drum from the inside and met some resistance. So with a little force I managed toturn it and felt the belt come off the back and the drum consequently become very easy to spin. So I removed the top and the back panels and the first thing that struck me was what appeared to be spattering of black and brown dried drip marks all over the bottom half of the back of the drum / panel, clearloy coming from the bottom of what I assume to be a main bearing (where the belt wheel centre goes into the drum). I got the belt back on to the wheel and ran a spin cycle. It worked, but as it got up to full speed I could see the belt wheel kick out by a few mm's ever time the bang happened, which at full speed was quite often and increased in frequency as the spin cycle went on. At this point I cancelled the spin cycle and tried to play with the wheel. I noticed that with my hands at 9 o'clock and 3 o'clock there was no forwards or backwards play, however with my hands at 12 o'clock and 6 o'clock I noticed that 6 could be pushed in slightly as 12 would slightly pull away from the drum. not by much but quite noticeable given that there was no movement at all with 9 and 3. I'm no mechanic, but would I be right in concluding that the bearing has gone? and if so is this common? And is it easy / cheap to fix (not by myself - wouldn't know where to start!!) ANy help would be massively appreciated as our baby's wearing smelly clothes now!! Andy.
i cant open the door on the machine when the wash cycle has finished any help or advice would be...
(More)
i cant open the door on the machine when the wash cycle has finished any help or advice would be welcome before my wife attacks it with a hammer and knife...
I have a Tricity Bendix AW1000 it finnished a cycle, but still had a lot of soapy water in it. When...
(More)
I have a Tricity Bendix AW1000 it finnished a cycle, but still had a lot of soapy water in it. When I tried to run a rinse, it didn't do anything. It would sit for 10 minutes before end lit up?
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
