Question about Amana ALW540RA Top Load Washer
Amana ALW410DAW washing machine
Our belt on this washer went out and we ordered a new belt. We are now trying to put the new belt on but can not figure out how to do so. Can you expalin an easy way to do this?
  • slysti18 Sep 19, 2008
    i cant get the pump off the motor, i have all 3 bolts out but still cant get it off. please help
sir fixalot
  • 146 Answers
SOURCE: washing machine belt replacement
I found the exploded parts views for that model number branded as a Maytag. Look to see if the are the same on the link below:
http://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=LWA60AW&mfgModelNum=PLWA60AW&fkMfgID=1
Use the parts diagrams as a reference.
Remove drain hoses, motor
Move motor inward while removing belt from pulley under tub
Three screws with star heads hold pump to motor and careful when removing pump--it could crack if it is frozen to motor shaft.
Posted on Jan 04, 2008
  • 1028 Answers
SOURCE: How to change drive belt on Amana washer
remove the 4 bolts holding motor to tub and frame remove wire harness from motor remove pump hoses turn assembly upside down 3 torx screws hold pump to motor note routing of old belt around idler pulley and pump studs reinstall in reverse
Posted on Apr 24, 2008
SOURCE: replace belt on amana washing machine
Do you mean the water pump? If so, it's likely rusted on the shaft. I used a couple 15" screwdrivers as pry bars. Got it off, didn't break the pump, you might not be so lucky. Clean the shaft with scotchbrite, a dab of silicone lube will make it easier next time. If you have a camera take a couple pics BEFORE you take it all apart. The belt will fit 2 different ways, and one way will chew up the plastic pump support post. Don't ask how I know. (Took a lot of effort to get it off, but you have to in order to change the belt. A new pump, if needed, is about $20 around here.....)
Posted on Dec 22, 2008
onthejob5130
  • 640 Answers
SOURCE: need instructions on how to change the belt in my washer
you have to take back off,,always unplug first..thats it just remove back take screws out all the way around back,,put belt on motor than spin drum pully...
Posted on Jan 06, 2009
  • 686 Answers
SOURCE: Amana Washer LWA50AW doesn't spin
pry up the top remove screws on front panel toward top set front panel aside and you should see what you need to do
Posted on Feb 27, 2009
Amana LW8303L2 will not spine
http://www.washerhelp.co.uk/washing-machine-repairs.html
http://www.repairclinic.com/Washing-Machine-Repair-Help
Belt replacement on these is a slightly intimidating job to the uninitiated, but possible.
http://www.american-appliance.com/se...stic-Chart.htm
http://www.applianceaid.com/amana-wash.html#belt
Lots of pictures and help at these sites.
Main thing is use ONLY the factory-authorised replacement belt on these. It is designed to have the right amount of slip/grip to enable your washer to work properly. This is CRITICAL on Amanas.
Apr 14, 2010 | Washing Machines
Tighten the belt on an Amana washer?
The belt should already be pretty tight after wrapping around the barrel and the motor pulley. The belt may be worn and should be inspected and probably replaced.
To prevent similar problems in the future I suggest you be aware of how big of a load you put in the washer.
Mar 13, 2010 | Amana 3.2 cu. ft. Top-Load Washer
I have an amana washer...Model # 8318015...The belt is broken..I have a new belt that I need to put back on, and I need directions on how to do this
take the bottom panel out(2 screws) then the upper panel out(its clips)
now the pump need to take off the shaft 3 screws then you can put the new belt in it with tention from the pully roller... try to see if there are video for that in youtube...good luck not so EZ to do :(
Jan 02, 2010 | Amana ALW480DA Top Load Washer
Replacing belt
Put The Belt On The Motor First Then Put What You Can Get Of The Belt On The Other Pulley And Turn It. It Will Give You The Anchorage Needed To Put The Belt Back In Position. If This Doesn't Help Let Me Know And I Will Further Assist You.
Sincerely,
Michael Scott
Feb 10, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Replace belt on amana washing machine
Dec 06, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Diagram of installing belt on amana washer
show diagram on how to install a belt for Amana washer model number ALW410DAW Serrial number 0006303339
Nov 02, 2008 | Amana ALW480DA Top Load Washer
Washer belt
To replace the belt on your Amana washer, pull the unit forward then tilt the top of it back to about a 45 degree angle. Once you get the right angle, the unit will rest against the wall behind it instead of falling forward. Take your new belt (availble through local appliance parts stores or on line from the manufactures web site) and first put it in the track around the large pulley, then the track on the smaller pulley on the right. Lastly, the pulley on your left should be moveable. Move the final pulley so that you can get the belt over it. It will then move back to a tensioning position.
May 14, 2008 | Amana NAV5800A Top Load Washer
Amana washing machine LW4203W2 MODEL
make sure you have the right belt because there are 2 belts for the machines if your motor mounts to the tub or if it mounts to the bottom of the washer and make sure the belt is on the tensioner
Jan 06, 2008 | Amana ALW480DA Top Load Washer
Amana ALW540RA Top Load Washer Logo
200 people viewed this question
Top Amana Washing Machines Experts
Charles T Nevin
Charles T Nevin
Sal De
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
