Question about Microsoft Windows Vista Ultimate Edition
Vista error for games
Hello my name is mike kelley. i currently just bought a vista home premium computer with a flat screen hd monitor. i had bought F.E.A.R. for this computer and it does not seem to work. i get about 3 minutes into the game when it just stops working. ive heard that you need to download a patch for the game to play on a vista but i can't find it anywhere on the internet. i was wandering if you could help me understand this and possibly find a solution.
Merry Christmas, Mike.
  • 1 more comment
  • Anonymous Dec 30, 2008
    Im trying to play the multiplayer games but isnt working!
  • Anonymous Feb 16, 2009
    ahow can I play my windows 98 games "shivers and myst" on my new windows vista ?
  • susiecar Feb 16, 2009
    How can I the play windows 98 games on Vista?..... Help!!!......Susie
  • 1,601 Answers
I read that there is a patch, but like you i couldnt find it.
Here are some tips from Sierra,. I dont know if you had seen these or not.
Also you didnt say what video card you run.
If you are encountering errors, during your F.E.A.R. Perseus Mandate installation process, please use the following methods in the order that they appear.
1. Make sure there are no smudges, scratches or other residue on the game DVD. If you see any smudges, try cleaning with damp soft lint free cloth (like an old T-shirt) from the inside edge to the outside edge in straight lines.
Note: Try the game installation on another pc system (if available), to determine if the disc is bad or damaged. If same issue occurs on another computer, you may need to replace the game disc.
For information regarding disk replacement, please go back to our main support page at:
2. Try you game Installation from a secondary DVD or DVD-RW drive if available.
3. We advise you to have Administrator privileges to properly install and run games on your Windows OS.
If you have administrator rights, and wish to give a user administrator rights, you can do this in the Users option of your Windows Control Panel.
4. Temporarily disable programs from running at system start-up, which in some cases could prevent game installation.
Use the Selective Startup option in MSCONFIG.
Go to your Start then select Run(if you don't see Run, Hold down the Windows key, and then press the R key on your keyboard to invoke the Run dialog box) In the Open: box type: msconfig and then press the Enter key.
When the menu appears, click on the General tab, if it is not already at the front. Under Startup Selection, select Selective Startup, and uncheck the selection Load Startup Items.
Click on Apply and then Ok/Close, and restart the system to retry the installation.
5. Locate and delete a file IsProBE.tlb from Runtime folder located in C:\Program Files\Common Files\InstallShield\Professional
You can find the file by going to your My Computer icon
-Open local drive C and then Program Files
-Go into InstallShield folder then open the folder Professional and delete IsProBE.tlb then re-run the installation again
6. Check you system's manufacturer web site and see if they have any firmware driver updates for you DVD or DVD-RW drives.
7. Ensure that you have cleaned out your temporary directories. To do this, double click on My Computer, with the Right Mouse Button click on the appropriate hard drive and click on Properties with the Left Mouse Button. Click on the Disk Cleanup button ensure temporary files are checked and proceed to clean up these files.
8. Try ‘copy the contents’ method below.
Copy all DVD contents of the game into a folder on your hard drive and run the installation from that location (If you receive an overwrite prompt select Yes to all).
Note that you will need about 8 GB plus free space on the hard drive to apply this option.
See below for instructions.
-Quit all programs that are running.
-Right-click in empty are on the desktop then point to New, and then click Folder.
-Name the folder, and then press ENTER.
-Double-click on the folder that you just created.
-From the Tools menu, click Folder Options.
-Click the View tab. Under Hidden files and folders, click Show hidden files and folders, and then click OK.
-Insert game DVD into your drive. Hold down the SHIFT key on your keyboard to prevent the program from starting automatically.
-Open My Computer, then right Click on game icon and left click on Open.
-Go to Edit menu at the top and click on Select All.
-Now, go to Edit again and click on Copy.
-Next step is to open the folder you created on the desktop, go to Edit menu, and then click Paste.
-This will copy the contents of the disc into the folder.
Please be patent since this may take some time. After all game contents been copied into the folder, double-click Setup.exe and then follow the on-screen instructions to install your game.
9. Ensure that your hard drive is not fragmented. To defrag your hard drive, click on START, go to PROGRAMS, go to ACCESSORIES, go to SYSTEM TOOLS, and select DISK DEFRAGMENTER, select the appropriate drive and click DEFRAGMENT. Please be aware that this process, depending on the size of the drive, may take up to and over an hour to complete.
Here are the requirements for F.E.A.R.
• Windows(R) XP, x64 or 2000 with latest service pack installed or Windows Vista(TM)
• DirectX(R) 9.0c (December 2006 Edition – included) or higher
• Pentium(R) 4, 1.7 GHz or equivalent processor (2.2 GHz for Windows Vista(TM))
• 512 MB of RAM or more (1 GB for Windows Vista(TM))
• 64 MB GeForce(R) 4 Ti or Radeon(R) 9000 video card (GeForce(R) 6600 or Radeon(R) 9800 video card or equivalent for Windows Vista(TM))
• 8 GB free Hard Drive Space for installation
• Additional hard drive space needed for a swap file and saved game files
• DVD-ROM drive
• 16-bit DirectX(R) 9.0-compliant sound card with support for EAX(TM) 2.0
• Broadband or LAN Connection for Multiplayer games
• Mouse
• Keyboard
Radeon(R) 9000* Series
Radeon(R) 9500* Series
Radeon(R) 9600* Series
Radeon(R) 9700* Series
Radeon(R) 9800 Series
Radeon(R) X600 Series
Radeon(R) X700 Series
Radeon(R) X800 Series
Radeon(R) X850 Series
Radeon(R) X1300 Series
Radeon(R) X1600 Series
Radeon(R) X1800 Series
Radeon(R) X1900 Series
Radeon(R) X1950 Series
Radeon(R) 2600 Series
Radeon(R) 2900** Series
* Not supported while using Windows Vista(TM).
Also, the Radeon® 9000 is not supported if using an AMD® processor.
** Not supported while using Windows(R) 2000.
Catalyst(TM) Drivers 6.2 (Windows(R) 2000)
Catalyst(TM) Drivers 6.11 (Windows(R) XP) or 6.2 (Windows(R) 2000) – ATI Radeon 9250 Series and below
Catalyst(TM) Drivers 7.8 (Windows(R) XP and Windows Vista(TM)) – ATI Radeon 9500 Series and above
GeForce(R) 4 Ti Series
GeForce(R) FX 5900* Series
GeForce(R) 6600 Series
GeForce(R) 6800 Series
GeForce(R) 7800 Series
GeForce(R) 7900 Series
GeForce(R) 8400 Series
GeForce(R) 8500 Series
GeForce(R) 8600 Series
GeForce(R) 8800 Series
*Not supported while using Windows Vista(TM)
Tested with:
ForceWare(TM) Drivers 93.71 (Windows(R) 2000/XP) – NVIDIA GeForce 4 Ti Series (not supported on Windows Vista(TM))
ForceWare(TM) Drivers 96.85 (Windows Vista(TM)) or 162.18 (Windows(R) 2000/XP) – NVIDIA FX Series
ForceWare(TM) Drivers 162.18 (Windows(R) 2000/XP) or 162.22 (Windows Vista(TM)) – NVIDIA GeForce 6600 Series and above
Latest Drivers:
NVIDIA Vista: 163.69
NVIDIA XP: 163.71
ATI: Catalyst 7.9
Please note that attempting to play the game using video hardware that is
not listed here may result in reduced performance, graphical anomalies,
or both.
Please let me know if these work for you,
Posted on Dec 15, 2007
BOD problem
Depends, if u pirated it, its a virus, trojan prolly, if you bought it legally something might have interupted the download, skipping a file code, reinstall.
Oct 06, 2009 | Video Game Consoles & Games
Error states Spy Sweeper is not compatible with 64-bit operating systems.
This from the Webroot Web site on supported operating systems:
Windows Vista® (32-bit versions of Home Basic, Premium, Business, or Ultimate), Vista SP1 (32- and 64 bit versions of (Home Basic, Premium, Business, or Ultimate).
So, assuming you have bought the latest Spysweeper (and assuming you have Vista 64 bit) , then you need to upgrade your Vista to SP1.
Sep 12, 2009 | Webroot Spy Sweeper (spysweeper) for PC
Acer AL1716 monitor
First of all check your monitor's color configurations using the buttons in the monitor. Then, if colors are set to default, go to your GPU's control panel, usually found by right clicking your desktop and finding an option that says ie. Nvidia control panel. Go to video control settings and/or desktop color settings and either restore defaults or configure them yourself if you know what you are doing. Hope that helps.
Jun 11, 2009 | Acer AL1716 F Monitor
No display on Windows Vista need driver?
Make sure that the settings in the new video card are actually set to run both monitors.I see this happen in my comp. repair shop quite often. It is a common mistake.
May 04, 2009 | Dell 1703FPT 17-inch Flat Panel Monitor
When I boot into Windows Vista Premium nothing on screen
In Safe Mode, your monitor will not be listed as it is using a generic device driver for basic display. Go into your video settings and reset it to the lowest resolution available. Reboot the computer into Vista again and your display should be working. If you check Device Manager now, you should see your monitor listed. If it isn't, you will need to load the Vista drivers for it. You can then modify your display settings to suit your preferences.
Mar 28, 2009 | ViewSonic VX2035WM LCD Monitor
Hd on my satellite L305-S5891 blue screens after clean install
hello , friend its very easy to do that, steps are
1. insert bootable cd/dvd VISTA.home premium DVD.
2. Boot from tht cd and start the installation. 3. Format the whole HDD and create new partiotion as there is facility of doing this before installing. 4. Remember format whole disk. and then go for installations .
3. once it i completed install all video, audio drivers.
4. if you dont have that drivers pls download it from toshiba site by entering the toshiba serial no
Mar 25, 2009 | Toshiba Satellite L305-S5894 Notebook
Stop: oxooooc1f5
The error "Stop: oxooooc15" is usually caused by the new vista SP1.
Try the following
Start>Programs>Accessories>System Tools>System Restore. Restore you laptop to before you had the problem or error.
You can also try the solution from this article by Microsoft
Jan 09, 2009 | Acer TravelMate 5520 Notebook
How to upgrade from vista home premium to vista ultimate
just right click my computer then select properties and click the upgrade
Apr 07, 2008 | Computers & Internet
Slow To wake-up
just replace ur CMOS battery & reinstall the os with NTFS file system.ok
Apr 01, 2008 | Computers & Internet
Screen flashes when using dvi input
make sure the cables are tight if they are i would look at replacing the video card.
Feb 06, 2008 | ViewSonic VA2012WB Monitor
Microsoft Windows Vista Ultimate Edition Logo
244 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
