Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
Dishes are not getting dry...help
We just got this dishwasher and are very disappointed that are dishes are not dry. We have been using the heat dry option, thinking that would help, but it doesn't seem to do anything. Is there something we are doing wrong, did we hook it up incorrectly? Thanks!
  • 2 more comments
  • hovenj Dec 22, 2007
    I'm having the exact same problem. In addition, the detergent dispenser won't open. Its brand new.
  • Anonymous Jan 02, 2008
    I have the exact problem. The first time I had the repair people come out and his solution to me was "that's because you are not using "JET DRY"!!! I may look stupid, but I knew that would not solve the issue, but I would give it a try. It did nothing. I just had another repair person come out to make sure that it was working correctly ($70 just to come out and look) and he checked the drainage, heating coil, vent, etc. and found all to be working fine. Good thing I bought the extended warranty! NOT! Now I have mold growing throughout the dishwasher. I did a search on the web and several people are having the same issues. One person suggested putting 1cup of bleach in the dishwasher (without dishes) and run it through the HOT selection. I will be trying this tonight....I have had the cheapest dishwashers in the world for the past 15 years and have NEVER had this happen to me.
  • Anonymous Apr 22, 2008
    I recently moved to a 18 month old home with the above model diswasher.It works fine but I was disappointed with the condition of the dish racks.Both had areas of rust the lower one was worse. I confirmed with the previous owner about the age of the dishwasher. Has anyone had the similar experience ? I had a Fisher and Paykel dishwasher for 10 years in New Zealand and the condition was still excellent. Is the quality of Frigidaire poor ? I have just ordered new racks and it's costing me $143/- including shipping and handling.
  • Anonymous Aug 10, 2008
    I have the same problem and it is making me really angry. My old cheap diswasher never had this problem...no mold in there yet but I'm sure its coming. Don't know what to do. I have been cracking the door open to let some air into the dishwasher but I should not have to do this. Gallery Series is supposed to be better than this.
  • 125 Answers
The most common thing I find with dishwashers not drying is that people are not using the rinse aid, (Jet Dry..etc). If your not using it the water won't sheet off the dishes. You can also turn it up to use more, one notch at a time. The dial is in the dispenser compartment where you add the jet dry. hope this helps
Posted on Aug 19, 2008
    Genius:
  • 1,554 Answers
It is very likley that your hot water heater is not turned up high enough. most folk try to save money and keep the kids from scalding themselves.mine is maxed and ***** run out of very hot water. though I pay for it.
these units run on 110 volt energy mizer and won't heat up like the old units did.
you can put in an on demand heater but that is 200. at the low end.price.
open both to your hot water heater covers and crank them up as a test. wait for 2hrs~ for it to level out.
Posted on Mar 10, 2008
How do you turn up the heat on the dish washer drying cycle?
There is no way to turn up the heat of the dishwasher during the drying cycle. As part of the current ecological, energy-saving, environmentalist-wacko movement, dishwasher makers have cut back on the heating used to dry dishes. But you can do these things to help with drying:
1. It is imperative that you use rinse-aid (Jet-Dry). This allows more water to flow off the dishes and what flows off does not need to evaporate.
2. If the dishwasher has the options, turn on high-temperature wash and sani-rinse. This gets the dishes hotter for better evaporation during the dry cycle.
It is possible that the heater may not be working at all, and that will cause poor washing performance and no drying. That problem can be caused by a bad heating element, or by a bad controller.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Sep 21, 2014 | Whirlpool Dishwashers
When in use, my dishwasher at times, makes a lot of repeating noise and it appears to tick.. th digital reading on the right blinks CL CL CL CL then HOT then goes back to tell you the remaining time, and...
Some dishwasher noises are normal, like the hiss of water rushing through the water inlet fill valve, or the hum of the pump motor, or the slosh of water. But if your dishwasher is making strange sounds or is unusually loud, it's time to investigate. A thumping noise could be the drain line vibrating against the cabinet; a grinding noise could be caused by a popcorn kernel being stuck in the chopper blade area of the dishwasher.
The CL is normally indicated child lock has been activated.
Dishes typically dry by the end of the dishwashing cycle, with one exception-plastic items. Because plastic doesn't retain heat like glass, ceramic and metal do, you'll almost always see drops of water on plastic items after the cycle finishes. Rinse aid helps water drain off all dishes so they dry better. Make sure that you fill that rinse aid dispenser when it's empty. A heated dry setting also is an option to enhance drying. You may have this option turned off to save energy, but if your dishes aren't drying as well as you'd like them to, you might want to consider turning it back on. Consult your owner's manual and select the cycle options that fit your needs and your energy usage goals. If your dishes don't get dry even though you've selected the heated drying option, then the heating element could be broken or the high-limit thermostat for the element may have tripped in error, preventing the element from heating. A malfunctioning vent or drying fan could also prevent dishes from drying. Check out this troubleshooting video that could help you correct a drying problem: Dishwasher Not Drying Dishes Video.
Oct 26, 2017 | Frigidaire FDB1502RGS Built-in Dishwasher
Drying problems
Check the front control panel for a AIR DRY / HEAT DRY switch. Perhaps the switch is in the AIR DRY position. If so and you really want to HEAT DRY your dishes, set the switch for HEAT DRY.
Second, it is not a bad thing to let your dishes AIR DRY. It saves money! Just open the Dish Washer door after the last rinse cycle has finished and let the dishes AIR DRY manually. In a hour or so they can usually be put away.
You can also check for the heating element.Your dishwasher has an electrical heating element that helps to dry the dishes. If the element is burned out, the dishes won't dry properly, and you need to replace the element. Many high-priced dishwashers have a small fan that blows air or heated air into the dishwasher to speed up the drying process. If the fan is defective, you need to replace it.
Thank you!
May 14, 2010 | KitchenAid 24 in. KUDS25SH Built-in...
I just purchased an LDF6920. It does not dry the dishes. In fact, there is water remaining in the bottom, and all the dishes and drum and door are beaded with water. It suggests putting some sort of...
First off, there should not be any (visible) water standing in the bottom of the dishwasher after the cycle is done. If yes, check the drain, installation of drain line, etc.
Second: The LG is a very energy efficient dishwasher, but in order to acheive this, it does not use a heater to dry the dishes. It relies on the residual heat from the hot water used in the wash cycle, plus a small fan to vent some moist air. It is imparative that you have soft water and use a product such as Jet Dry to assist with drying on the LG dishwashers. Even at that, plastic items (which retain little heat from the water) will not dry well, if at all. Plates, pots, glass, anything with some mass will dry. You may have to adjust the Jet Dry dispenser setting up a bit. If it is set too high, you will get white streaks on your dishes, so then back it off just a bit.
Aug 12, 2009 | LG 24 in. LDF 7811 Stainless Steel...
Model # dwu7702aae has heat delay light coming on during cycle. Why?
Heater is used to both heat water during clean cycle and dry dishes after wash cycle. Most washers have either a separate switch for Heat or Dry for optional use, or some have the water heat and dish dry options built into cycle set options.
You can save money by turning off the Dish Dry option since it is a very in-efficient way to dry dishes. Instead, open the wishwasher door after washing cycle completes, just enough so fresh air can get into, and humid air can escape, dishwasher.
Water Heat option is only needed for dried food on dishes, and is never needed if dishes are either rised off before putting them in the dishwasher, or rinsed off inside the dishwaser with a Rinse cycle, if they are to stand for a time waiting for a full dishwasher for wash.
Feb 22, 2009 | Maytag Dishwashers
My bosch dishwasher will not dry the dishes
this dw to save energy works this way- the final rinse will reach a temp of 161 F . the dishes have to absorb this heat. when the cycle is complete the dishes become a heater in themselves radiating the heat they absorbed during the final 161 F heat. If you have any tupperware or plastic dishes in the unit they will not absorb heat therefore not radiate the 161 f temp need to dry all the dishes. try to avoid plastic items and they must always have jet dry. this is the european way of conserving energy. on the old ge or whirlpool they had electric element in the bottom that would bake the dishes dry ....not these..but they do save alot of energy.. it helps right after a cycle to crack the door open release all the steam from the unit
Dec 07, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishes are ALWAYS WET!!!
If the dishes are made of plastic they will be wet , they don't retain heat when in the drying cycle!
Aug 10, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Wet dishes
If the dry cycle has a problem, check these:
Heating element
Drying fan
Thermostat
Heating element Your dishwasher has an electrical heating element that helps to dry the dishes. If the element is burned out, the dishes won't dry properly, and you need to replace the element.
Drying fan Many high-priced dishwashers have a small fan that blows air or heated air into the dishwasher to speed up the drying process. If the fan is defective, you need to replace it.
Thermostat Some dishwashers have a thermostat that monitors the drying temperature. If the thermostat is defective, the heating element may not cycle on or off properly. If that's the problem, you need to replace the thermostat
Jul 19, 2008 | KitchenAid 24 in. KUDP01IL - Multiple...
Dishwasher not drying
Same problem here. I read the manual very carefully. "OptiDry", "ExtraDry", "EcoDry", "condensation drying" -- lots of fancy words to cover the simple fact -- they DO NOT DRY the dishes. There is no heating element. I wish they would just state this up-front. Air drying the dishes for 24 hours after each wash is not workable for most users...
Nov 12, 2007 | Bosch 24 in. SHX99A15UC Stainless Steel...
My Dishwasher does'nt dry my dishes.
How old is the dishwasher? Check the front control panel for a AIR DRY / HEAT DRY switch. Perhaps the switch is in the AIR DRY position. If so and you really want to HEAT DRY your dishes, set the switch for HEAT DRY. Otherwise: Second, it is not a bad thing to let your dishes AIR DRY. It saves money! Just open the Dish Washer door after the last rinse cycle has finished and let the dishes AIR DRY manually. In a hour or so they can usually be put away. Works for me :)
Nov 30, 2006 | Frigidaire 24 in. FDB510LC Free-standing...
Open Questions:
See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
128 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
