Question about Car Audio & Video
RE: VOLUME BUTTON POSITION ON FACE OF UNIT
ARE YOU ABLE TO ADVISE WHERE THE VOLUME BUTTON IS LOCATED ON THE FACE OF MY UNIT PLEASE?
I DO HAVE A REMOTE BUT ALSO FIRMLY BELIEVE THERE MUST ALSO BE A MANUAL BUTTON ALSO.
ARE YOU ABLE TO ADVISE ASAP PLEASE?
  • cheekykes Dec 18, 2007
    Thank you for your help it is much appreciated!!
    Scholar:
  • 143 Answers
If there is a knob rotate it clock wise / to the right, to increase the volume, & anti clock wise to the left, to decrease the volume.
there may be buttons with this symbol ' ^ ' or ' + ' means volume up, there may be a ' - ' or ' v ' to decrease the volume.
or this one ' > 'can also mean up & this one ' < ' can mean down.
Hope this helps?
Posted on Dec 17, 2007
Volume down button doesn't work
hi, make sure the face pins are clean; try resetting the unit; check to see if the feel of the down switch is the same as the up switch....if not then your down switch is faulty and needs to be replaced. confirm the volume down operation by using the remote control (if available), if it works then your problem lies with the switch or a broken connection between the switch pins and the face control circuit. cheers.
Jun 21, 2012 | Blaupunkt RPD-545 CD Player
Sk4000 remote will not pair with headset, tried everything and checked with support. They said be sure and pair remote before pairing phone. Tried that and still nothing. if the remote is no good there is...
If you have verified that the battery is good in the unit, try this (from the folks at Parrot). The HCU is the main control unit.
1) Turn the HCU on
2) Clear the memory on the HCU by holding down the power button and accept call button (the two large buttons on the face of the HCU)
3) Wait until you hear the HCU make the request "please pair device"
4) Hold the volume up and the volume down keys on the remote for 15 seconds
5) Release the buttons on the remote.
It might be fixed now. Press the switch on the bottom of the remote to switch to radio and see.
Jun 09, 2011 | Parrot SA Parrot SK4000 Motorcycle...
Remote does not work on SK4000.
1) Turn the HCU on
Jun 04, 2011 | Parrot SA Parrot SK4000 Motorcycle...
Sony xplod controls not working, volume, tuning, channel selection, etc. mode select...
unit most likely has either malfunctioned or has dirty contacts take the face off and press the RESET button if this does not fix it take a QTip and some rubbing alcohal and clean the contacts on the face and unit this unit does come with a remote try using that
Oct 22, 2010 | Sony XPLOD CDX-GT200 CD Player
When i turn the tv. on, the volume line appears all the way to zero. if i turn the volume up, it goes up but when i release the up button the volume goes down all by itself.
It sounds like one of the volume down buttons is stuck in the activate position. The same as if you were holding the down volume button continuously. It could be either the volume down button on the TV or the remote. I would try remove the batteries of the remote then adjust the volume by the TV buttons.
If the volume doesn't go back down then the remote is the problem. In order to fix the remote you may need to take it apart. This is normally easy to do just locate any screws that may be holding the remote together. If you don't see any screws then you will need to pry the two sections apart. Separate the circuit board and rubber buttons and clean them both with some rubbing alcohol and reassemble it. If it still has the volume issue you may need to replace it.
If the problem persists with the remote deactivated then it's the volume button located on the TV. That is a little more difficult. You can try wiggling the button or some canned air (used to clean computer keyboards) to blow it clean. However it may need to be disassembled to gain access to the switches for proper cleaning.
Hope this helps.
Oct 19, 2009 | Toshiba 32A33 32" TV
KDC-322 - New battery, now asking for password
There are afew types of override procedures for Kenwood.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
The security is canceled and the set enters the TUNER mode!
"TRACK UP BUTTON" for 3 seconds.. and youre done.
Aug 17, 2009 | Kenwood Sirius KDC-MP522 CD Player
880 universal remote volume button broke. little rubber botton on inside that pushes the volume button on inside broken.face plate cracked and arrow button on left right underneath face broken and missing...
My volume button also broke (actually, the VOLUME UP function stopped working). Rather than trying to get the remote fixed, I found a different solution...
I reprogrammed the + key (bottom left of the remote) to be my new Volume UP function. You can do this by going to any of the activities you've already defined, and adding a custom button to the activity.
Choose the + button (it will probably not have an existing function), and tell it to use the Volume Up function of the component you normally use for volume. In my case, it was the Home Theater Receiver.
I hope that helps.
Mar 02, 2009 | Logitech Harmony 880 Universal Remote...
Resetting lamp hour meter
It is the MUTE button on the remote and the VOLUME DOWN on the TV.
May 11, 2008 | Panasonic PT-50DL54 50" Rear Projection...
Remote volume control for Sharp Aquos 42inch LCD not working
ok please open the remote then clean it with pencil eraser.
Oct 09, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Face does not come down and remote won't work
EXTREMELY common problem for these units. The faceplate ribbon cable has gone bad and needs to be replaced.
Sep 20, 2006 | Sony CDX-M800 CD Player
Car Audio & Video Logo
50 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
