Question about Philips HTS3440/37 System
Speakers playing low
My speakers and subwofer are playing at a very low volume, even a maximum volume. When in enter audio setup page, the speaker volume option is locked out. please help
  • 3 more comments
  • klkeller Sep 29, 2008
    I looked at the setup and the night mode was already off.
    Anything else that could help
  • oddballkelly Oct 10, 2008
    I have the same problem.. I suspect it may be software related. I have tried the reset to default from th Setup menu, but it doesn't reset everything, as my radio stations are still there. Does anyone know the code to reset it to the as-delivered condition?
  • Flaca09 Mar 22, 2009
    The volume is very low even when we turn it up to max volume....
    The volume on our Phillips home theater system is very low even when we turn it up to max volume...
  • mjh37 Apr 07, 2009
    My speakers and subwoofer are playing at a very low volume as well, even at maximum volume. Any help would be appreciated in fixing this. Thx.
    Please send me an e-mail: mjhoner@cox.net
Its becuz the heat sink in the inside is getting way 2 hot so volume slowly turns down even on max so what i did waz open it up an put a new fan on the heat sink an it work i have no problems now
Posted on Aug 11, 2009
Open the disc tray and press setup and the speaker volume option will activate and also turn off the night mode for louder sound
Posted on Apr 22, 2008
My Roland FP8 plays very quietly through its own speakers, through an external amp & speaker and through the earphones. There is a hissing/crackling/static sound too from the speakers. Anyone
A number if things can be wrong with it, from the audil preamp to the the audio amplifier. Even as simple as a bad volume control. Does the actual noise change patterns when you move the volume?
Jan 03, 2015 | Roland Music
My volume went low.
These are speakers with their own power?
No? - Get some.
Yes - Win7 - If you speaker icon is missing go to Start > Control Panel > Hardware and Sound > Manage Audio Device > Sound. In Playback Check levels and configure speaker setup, like 2.1 or 5.1.
You should also check speaker connections for left speaker.
Oct 11, 2012 | HEWLETT-PACKARD ProBook 4520s
Panasonic CT 27 SL - 13 GL how to connect external speakers
This TV is set up to connect to an external amplifier which that controls the speakers. It has an analog audio output which means you need an RCA audio cable (2 RCA plugs (red and white) on each end. You can't directly connect a set of speakers. The audio output jacks at between the antenna in and the video inputs. Then you need to enter the menu and enter the Audio submenu. Go to the Speakers item. Turn the TV speakers to off and fixed audio out.(The amplifier will adjust the volume.) Use the Up/Down arrows to navigate through the menu options, press enter to enter a sub-menu and the volume up button to change a setting.
There is also a headphone jack which may be compatible with computer speakers. That has a 3.5 mm jack. To use headphones, set the Speakers Audio item to TV speakers Off and variable audio out. (The TV controls will adjust the volume.)
To use a Universal remote to set the audio or modify the channel list, you need one that matches the Menu function of the original remote. You may need to try multiple codes for Panasonic TVs to get the button to work. Some low-end universal remotes may not have the menu button; get a different remote or use the menu button on the front panel of the TV.
To set the channel list, press Menu and select Setup. Go to the Prog Chan option. Then set your Mode in the first option (Cable or Air). Then choose Auto Program to scan all channels or Manual Program to edit the channel list.
The manual for the TV is available at retrevo: http://www.retrevo.com/support/Panasonic-CT-27SL13-TVs-manual/id/275ag210/t/2/ . You will need to enter a code to access the manual. See page 5 of the manual for the input connections (page 7 of the PDF).
Sep 13, 2012 | Panasonic Televison & Video
We are working with a yamaha HTR-6240. The memory guard is locked on and we wont to use auto setup. Also, as it is currently set, we are getting a lot of volume from our rear speakers and very little...
The manual is available at retrevo.com
Page 43:
Under Setup / Memory Guard on/off
For volume of individual speakers see Speaker Setup (Auto) or (Manual) on page 39.
Dec 23, 2010 | Yamaha Audio Players & Recorders
Ihave purchase of emachine note book of acer. volume of the speaker is so low hat even one person can not hear.i have talk with service center of acer,but they told that this is a maximum volume of the...
I have had that laptop once and had the same problem. I knew that it was the maximum volume of the speaker so I purchased external USB speakers to connect to the computer and the sound was clear and loud enough to hear anything played on the computer.
Thanks
P.S. Please rate if this solution was helpful
Nov 01, 2010 | Acer Computers & Internet
Rear speakers not working
Your FM tuner will only generate sound from the front sepakers. CD's, Tape, and I guess mp3 player, as well, will only play through the front speakers.
I've included a link for the manual. The audio on this rig is pretty complex. read through the info, especially pages 11,12,13, and play with the audio controls.
http://support.radioshack.com/support_audio/doc61/61792.pdf
Aug 16, 2009 | RCA RT2500 System
Possible blown speakers
I have experience with that model of speakers. When they give up the ghost, the volume is VERY low. But just to be on the safe side, check the volume properties to make sure nothing is set too low. Start>Control Panel>Sounds and Audio Devices. Check the slider bars here, check in the Advanced area as well to make sure nothing is low and check the Speaker Volume as well. If all the bars are set to their maximum, it's time for some new speakers.
Thanks for using fixya.com. If you like my answer, please help me out and rate me accordingly.
Jan 11, 2009 | Dell A215 Computer Speakers
Volume is Always Low when playing DVDs
i may try to change other DVD player software..........see if any change
Dec 25, 2008 | HP Pavilion dv2000t Notebook
My pair comuter speakers work, and there pluged in right, but don't pay anything out of them.
I assume you have told Windows about you new speakers ???
(Start, Settings, Control Panel, Sounds and Audio Devices = Volume tab, Speaker Settings box, Advanced button ...)
Oct 30, 2008 | Dell A215 Computer Speakers
Compaq wf 1907 monitor speakers--no sound
No sound from monitor speakers
If the built-in speakers on the monitor do not produce sound, perform each step that follows, testing for sound after each step, until you can hear sound:
  1. Close the software program you are using that is experiencing the sound problems. Test for audio using another software program.
    If the volume is adequate using another software program, the issue is with the computer, not the monitor. If the volume is still low, continue with this procedure.
  2. Check the cable connection. If the monitor-to-computer connection is a VGA cable (usually blue on both ends), an additional audio cable is needed between the monitor and the computer. Check that the audio cable is connected properly.
  3. Try to adjust the volume higher using the monitor front-panel volume button.
  4. Using the buttons on the monitor, navigate through the onscreen display (OSD) menu to find audio or speaker settings and enable the speakers.
  5. Click Start c01292216.gif , Control Panel , and then click Sounds and Audio Devices .
  6. From the Volume tab, check the Device volume, and make sure it is not muted.
  7. From the Audio tab, in the Sound playback field, click the Volume button. Make sure the audio device is not muted and the volume outputs are at adequate levels.
  8. If the monitor-to-computer connection is an HDMI cable, an additional audio cable might be needed, depending on the setup and configuration of the system. To find out whether an additional audio cable is needed, go to
HP and Compaq Desktop PCs - Using HDMI Audio with a Desktop Computer
This document pertains to HP or Compaq PCs with an HDMI (High-Definition Multimedia Interface) connector.
HDMI sends both audio and video through the same connection. If you want to hear audio from an HDMI connection, HDMI audio must be set through Windows . For example, if a computer is connected via HDMI to a monitor or TV and the proper HDMI audio settings are made, both audio and video will be sent to the display device.
Use the following steps to activate HDMI audio on your computer:
    NOTE: If you are setting up your computer for the first time, it may be easier to use a DVI connection or DVI-to-VGA adapter connection for the initial setup. Then, if you want to use an HDMI connection to connect a TV or monitor, activate sound for the HDMI connector using the steps that follow before connecting the HDMI cable to the TV or monitor.
    NOTE: After recovering the computer using the Recovery Manager, repeat this procedure to activate sound for the HDMI connector.
Step 1: Enabling HDMI sound in the BIOS
To hear audio through the HDMI connector to a monitor or display, enable the Onboard Audio setting in the computer BIOS settings by completing the following steps.
    NOTE: If you choose the default BIOS Setup options or upgrade the BIOS, you must repeat this procedure to enable audio for the HDMI connector.
  1. Turn off the computer.
  2. To enter the BIOS, turn on the computer and press the F10 key repeatedly until a BIOS Setup screen opens.
    A BIOS Setup screen opens.
  3. Press the right arrow key on the keyboard to select the Advanced tab.
  4. Press the down arrow key to select Onboard Audio , and then press the Enter key.
    Figure 1: Example of Onboard Audio menu
    An option window opens.
  5. Press the down arrow key to select Enabled , and then press the Enter key.
    Figure 2: Onboard Audio Enabled
  6. Press the F10 key. Select Yes to save the default settings, and then press the Enter key.
  7. The computer restarts. HDMI sound is now enabled.
Jan 03, 2008 | HP Compaq WF1907 Monitor
Philips HTS3440/37 System Logo
986 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
