Question about HP DeskJet 5650 InkJet Printer
Postcards causing printer jam
I am trying to print postcards (avery matte white 51/2 by 41/4"- heavyweight- 4 cards per sheet) and every time the printer jams and will not print or it sends through a paper with nothing on it. The jams occur 4/5 times. I have tried different printer settings, but nothing seems to work. It has worked previously on a card from a different company.
  • 417 Answers
I think the card is too heavy or too thick for the machine as when it prints it has to turn the paper. If the card is too rigid it is unable to bend causing a paper jam. Suggestion is to try a less grade of card.
Thanks J
Posted on Jan 14, 2008
How do I print cardstock with Samsung ML-2510?
Hi
I found a manual for your printer here:
http://downloadcenter.samsung.com/content/MM/200605/20060510151657234/um_ml-2570_manual_eng_060328.pdf
and under print media, it suggests limits of 60 to 163 g/m2 for the 2 trays. If you get some 160 g/sm2 card which is quite readily available, I think you will find it much lighter than the Avery business cards card, which from memory come in around the 200 - 220 g/sm2 level.
Even Avery quote this card as "heavyweight card stock", and although the say will print on all laser printers, it's my experience that they do not. Only on a laser with a flat paper path.
Cheers
Mar 02, 2015 | Avery 5376 Perforated Business Card
Epson r350 printer does not print thick paper or inkjet paper
Hi, this printer is "clever" in that you don't adjust the thickness setting it does it itself.
It does this based on the paper type you set in the printer properties, see the table below for the different types of paper it will accept & the setting you need to use.
For this paper Select this paper type setting Plain paper, sheets Epson Premium Ink Jet Plain Paper Epson Bright White Ink Jet Paper plain papers Epson Ultra Glossy Photo Paper Epson Ultra Glossy Epson Premium Glossy Photo Paper Epson Premium Glossy Epson Premium Semigloss Photo Paper Epson Premium Semigloss Epson Glossy Photo Paper Epson Glossy Epson Matte Paper - Heavyweight Epson Double-Sided Matte Paper Epson Matte Epson Photo Quality Ink Jet Cards Epson Photo Quality Ink Jet Epson Photo Stickers Epson Photo Stickers Envelopes Envelope
Hope this is of help.
Regards
Sham
Jun 01, 2009 | Epson STYLUS R350 Photo Printer
Printing heavy weight invitation stock on Epson R200
The card is probably too thick. Try cleaning the feed roller in the Sheet feeder to improve its grip. Check the GSM of the paper is within the spec of the printer.
Nov 03, 2008 | Epson Stylus Photo R220 InkJet Printer
Can't print bus. cards
You have solved your own problem with out even knowing it. The heavy paper is what is causing your problem. The solution to most problems is not to panic step back take a few deep breaths. Then kindly ask God. PS Also Thank God. I am just a Poor Sinner but God is my witness.
Jul 16, 2008 | Brother MFC 210C All-In-One InkJet Printer
Printing business cards
Feed sheets through front manuel feed slot.
base tray is mainly for up to 90grm paper,anything heavier
can feed for a time but tends to fault.also try and clean the
paper pick up rollers regularly.
mongrelken.
May 20, 2008 | Brother HL-2040 Laser Printer
Photo printing
hi doug
I had to reread your first post the mention of what to do with all the photo paper. I see you mean that you don't use matte photo paper you use matte heavy weight paper. I guess I mean that as a question! That is the only thing that works for me with no smearing problems. I haven't found one that is thick enough for a good feel. I used an avery matte paper that has a coating for photo but it just feels very light. Doesn't smear and looks sharp but very light weight. What brand do you use ?
post in me back
oke, thanks
cropp
Mar 11, 2008 | HP Photosmart 7450 InkJet Printer
Printing on CD labels seem to ruin fuser in Phaser 7300
Probably the labels have a slight plastic fiber or coating in them and is getting a coating on the heat roller.
Here are part numbers of the correct CD labels you can run without a problem.
Xerox Matte Coated CD Labels, 6-Up, 11x17
Reorder 3R12373
75 sheets per box
spacer.gif Other items to consider: Return to Top spacer.gif Item Color Price/Unit Quantity Xerox Gloss Coated CD Labels, 6-Up, 11x17
Reorder 3R12372
75 sheets per box
Item Color Price/Unit Quantity Xerox CD-ROM Glossy Coated Labels, 4 x 7
Reorder 3R6322
50 CD-ROM Labels, 25 Sheets per carton
White - Glossy Coated 1-9 Box $17.44 10-49 Box $16.90 50-99 Box $15.65 100+ Box $14.89spacer.gif
Feb 22, 2008 | Xerox Phaser 7300DN Laser Printer
Avery Ink Jet Magnetic Sheets - 3270
It worked fine for us on an Epson. We printed about 40 sheets fed one at a time. Do not stack the sheets in the feed hopper, they stick together because of the magnetism.
There is no template because the material is not die cut. It is just full 8.5x11" sheet size.
Feb 04, 2008 | Avery DesignPro Deluxe CD-ROM...
Repeated paper jam in fuser
Fuser's orange roller is not meant to be wrinkled, if this is then I would recommend you replace it (just slides out) pic below
b4eead5.jpg If printing on card, you need to feed via manual bypass and exit from the back, not on the top, aka the "face up tray." Tray pulls out from rear. Rear tray will only stack a few card sheets at once.
Setting on printer's control panel must be set to card/heavy paper type on manual bypass tray
Their may still be some card in fuser causing jams.
Please rate as FIxya or post back,
Cheers
S. :-)
Jan 01, 2008 | OKI C5200n Laser Printer
HP psc 1315 all in one-printing cards
Make sure you check the settings in the print driver. Sounds like your paper size settings do not match the size of the paper that you are printing onto and you are actually getting a false jam because the machine is seeing a different size paper then you ahve in it.
Dec 18, 2007 | HP PSC 1315 All-In-One InkJet Printer
HP DeskJet 5650 InkJet Printer Logo
200 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
