Question about Car Audio & Video
Amp I have a amp iam trying to hook up but i want to keep my factory head unit,1. does my unit have rca's or not 2. if not how do i hook up my amp with out them ? I have a 2000 dodge durango. its not infinity
    Problem Solver:
  • 12 Answers
Yes, a line-out converter should do it.
Posted on Jan 07, 2008
    Sergeant:
    Champion:
  • 231 Answers
If its the factory radio more likely it dont have RCAs ..You will need a 'speaker to line level adaptor" ..This has 3 or 4 wires at one end and RCAs at the other.simply connect a left and right set from behind radio or from rear speakers into left and right sets on adaptor ..then connect your RCA cables side to amplifier using RCA wires.
Posted on Dec 15, 2007
Factory subwoofer 2005 subaru, the after market head unit I got dont have the connectors for it.
try to get a "speakerwire to rca cable" connector. hook it into your back speaker wire and run your amp off of that. then hook the sub up to the amp as usual. without an amp, just splice into your closest speaker wire
Feb 23, 2010 | Car Audio & Video
Xm-2002gtr amp keeps kicking protect light on
check your amp and speakers and make sure their both hooked up 4 ohm instead of 2 ohm because if you have 1 set of voice coils on your speakers they can only be hooked up four ohm and not bridged to your amp because if you keep trying this you will lock up your speakers if the speakers are only 4 ohm than just hook them up regular to each channel on your amp if your trying to brigde four ohm speakers to your amp it will keep going into protect or worst case scenario you will fry your speakers and you can check your ohm with a ohmmeter trust me my brother owns a stereo shop
Oct 19, 2009 | Sony Car Audio & Video
I have 2006 ford five hundred limited im trying to install to 12" subwoofers and an amp but i wanna keep the factory radio installed what do i need and can it be done
Hi what you need to find out is if your head unit has sub out or any rca that you can hook up to as they send sound to amp though rca cable hope this helps
Oct 19, 2009 | MA Audio 800XL Car Subwoofer
How do you connect an amplifier to factory stereo?
crutchfield.com has a complete list of speaker sizes. Most car amps now have connections for RCA inputs and speaker-level too, so you can probably use the existing head unit: most OEM head units do NOT have RCA outputs.
Jul 30, 2009 | 2003 Mini Cooper
Wiring the scosche fai-3a to a pioneer two channel amp
the 2 left and right dont matter, it only matters when ur hooking up a 4 channel amp.
all u do is connect one of the channels to it but it would be best o buy a stereo ull have alot of engine nose and vibration on ur speakers and a thump every time u turn on ur car but itll sound ok for now ti
Jul 07, 2009 | Scosche Industries Scosche Slc4 Speaker...
THERE IS NOT 2 RCA HOOK UPS FOR THE SUBS HOW KAN I HOOK UP MY AMP SO MY 2 12S WILL HIT
If there's only a single sub-out RCA cable, you have two options. The amp may have a manual switch that puts it in Mono mode, in which case you only use 1 of the 2 RCA jacks. The other option is to go get an RCA splitter. This will take your single sub-out cable and feed the exact same signal to both left/right of your amp. Either way, you get the same result. If the 1200W amp is for your sub(s) only, you should set the high-pass filter and subsonic filters to help your bass "hit harder" and cleaner.
May 17, 2009 | Dual XDVD8182 Car DVD Player
Have one wire for audio sub out, but two input ports to amp
This one Wire should be for the +. Try connecting the + to the Head Unit and - to a Common Ground. At the Worst, You will Blow the Amp Fuse if not Correct. The Lead from the Head Unit is Only an Off and On from the Ignition. Please Rate My Response! Thanks!
Jan 31, 2009 | Power Acoustik PTID-8960 Car Video Player
Soundstream300 amp how do I hook it up to my pioneer head unit
That depends on which wires you are referring to. High level inputs or low level (RCA) outputs? If you are thinking about trying to wire the amp up to your Pioneer direct, ie; running the power and ground off of the factory harness, think again, you'll fry your electrical system. You need to run a seperate power kit (8 gauge minimum; 4 gauge pref), then run RCA's from the line level outputs on the Pioneer. If you are planning to run a sub with the Soundstream then run your RCA's from the Pioneer's sub output. Let me know if I can help you any further.
Aug 17, 2008 | Soundstream EGA900D Car Audio Amplifier
Car amplifers,,,,kicker amp's RCA jacks!
You could do a couple things if your head unit has all three outputs, then take them and hook them into the inputs. If you have just the front and the rear outputs, hook those to the inputs front and rear. Then hook the output of the 4 channel to the input of the mono block. I hope this helped
-Andrew Hawkins
Mar 28, 2008 | Audio Players & Recorders
Car Audio & Video Logo
160 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
