Question about RCA 32F531T 32" TV
My tv will not come on because of block; my remote doese not work how do i get the tv to work
My tv is locked; my remote dose nt work; how do i take the parental code off
  • lmec May 29, 2008
    accidentally put on the parental control on and cant get it off
  • nyy1933 May 30, 2008
    Tv turns off and on w/o someone doing it. t also changes channels and has text on it stating it is searching, now the tv wont turn on! its only 2 yrs old and I bought it new at circut city!!
Go to parental control and turn off front panel lock
Posted on Mar 24, 2008
Press menu button on front panel and volume down on remote for 3-5 sec.
The volume control on my sercive electric remote dose not work but everything else dose why?
you need to program the tv code into the remote. then the volume will work the tv volume.
Jan 19, 2013 | Televison & Video
RCA Truflat TV 27F522T is completely locked both manually and remote do not work. Was working manually but after checking menu for block accidently FPA locked not can't turn on tv at all.
You must have its remote control to unlock this TV. Try to make your remote control get repaired, and check these.
Most RCA sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Jun 28, 2012 | Televison & Video
I connected an Apple TV HD version to my TV with an HDMI cable and it works fine except when i pause or restart the stream it makes my MAC come to life and start playing music from my songs on Itunes. the...
I would suggest turning off the remote in itunes
OSX 10.6.6
iTunes > preferences > Devises > forget all remotes
if that dose not work you can disable the remote from the Computer :
apple logo > system preferences > security > unlock lock icon > disable remote control
Jan 26, 2011 | Apple TV Digital Media Streamer
Some channels are block out using 0000 or 9999 dose not help nee to cancel the c9od that in there, help
1. Select Canada V-Chip from the PARENTAL CONTROL menu.
2. Highlight English Ratings or French Ratings and press OK.
3. Determine the rating you want to block.
4. Press the down arrow button to scroll to the rating you want to change.
5. Press the OK button to change its status to block (the lock icon appears and all ratings above the one you selected change to lock). FRENCH RATINGS Go Back 18+ 16+ 13+ 8+ G
Press OK to view/block programs intended for children over the age of 8. V-Chip Movie Rating Limit Set movie rating limits by blocking movies rated above a specified level.
To access the Movie Rating Limit menu:
1. Press MENU on the remote control (the MAIN MENU appears).
2. Select Parental Control.
3. Select USA V-Chip.
4. Select Movie Ratings. Blocking Movie Ratings Once you are in the Movie Rating Limit menu, follow the same steps described for blocking Canadian V-Chip Ratings.
V-Chip Exempt Program Block The Exempt Prgms. option lets you decide if programs that the V-Chip recognizes as unrated can be viewed. Unrated TV programs may include news, sports, political, religious, local and weather programs, emergency bulletins, public announcements, and programs without ratings. The Exempt option applies to both USA and Canadian unrated programs and Canadian programs rated E. 20 Graphics contained within this publication are for representation only.
Using the TV's Features Unlocked All unrated programs are available. Locked All unrated programs are not available.
Nov 08, 2010 | RCA 27V530T 27" TV
I have a 32inch prive remote dose not work how can i get one
i have a 32inch prive remote that dose not work how can i get one or find a code or the replacement remote
Sep 20, 2010 | Soyo Atlas DYLT3212 32 in. HD-Ready LCD...
Missing code for comcast remote to work new rca tv
Hit tv then hold the setup button untill in flashes....then you type in 991 and then hit tv power tv power.... untill your tv turns off when it dose hit setup to lock the code
Jun 11, 2009 | RCA L32HD31 32 in. LCD HDTV
Locked channel
my sons tv keeps saying blocked by tv-7 and tv-14
Jul 07, 2008 | Emerson SpongeBob SquarePants TV
No controls
this should be easy to fix. The first thing is to check the buttons. Make sure that the buttons ar not pushed in and they work. What I meen is that when you push a button make sure it makes a cliking noise when you push it and releas it. If it dose not that is your problem. If they all work, Unplug the tv for 30 min. then plug it back in. It should work after that. If the remote dose not work after unplugging the set, you may have internal problems
Mar 15, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
RCA 32F531T 32" TV Logo
129 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
