Washer stops in rinse cycle
We have a problem with our Kenmore Mod. 110-88762793. Every time we do a load of wash it stops in the rinse cycle, it does not spin and the water does not leave. The machine remains full of water. THis happens in all cycles. What can it be?
Note: I do not know if it helps, but in this Kenmore's model the washer loads fron the top.
  • DFonse Dec 15, 2007
    Electroguy, many thanks in advance
    This is the information I have:
    Mod. 110.88762793
    Ser. MM0109390
    Type DFSO-ELE-2406027-FM96
    I veryfied this in the dryer door --I do not see anything else in the washer.
    I guess we found it. It's plastic and it is broken.
    SOme questiones:
    1) What is the name, number or model of this part? DO you know it?
    2) How do we change it? It is connected to a electric wire and secured with a silicon type of glue. The wire is not so long, so it is hard for us to cut it and change the part with no risk --and risk is to lose the wire in the bottom of the machine.
    3) And how do we seal it?
  • 231 Answers
Your contacts swithces for rinse cycle inside timer could be burned or bad..very model I will locate part number
Posted on Dec 15, 2007
  • 1 more comment
  • crispin melchor Dec 15, 2007
    verify model I will locate part number
    well first check the lid switch ,make sure its working or locking the lid.If this is not latching then it wont spin as a safety feature.These switches and or plastic latches break oftenthen see if you could hear the water pump or a humming when in drain or spin mode.If pump is stuck or not pumping .It will not spin..check this link to forum maybe this will help .
    im glad you found what appears to be the solution..actually you should be able to lift the washers top panel and replace that switch..YOu can remove and locate an appliance parts place in your area and they should be able to match it with model number..Hope my info helped you..Please dont forget to accept my solution on this website if it helped you..have agood day..
Why does a Kenmore washer not finish the cycle?
Washer Repair - Not Advancing -Repair & Diagnostic ...
? 8:30
Sep 6, 2013 - Uploaded by
Repair your Kenmore Top Load Washer suffering from these following issues: Will Not Advance Past Rinse ...
Kenmore washer doesn't complete final spin cycle - ApplianceBlog
May 16, 2012 - 9 posts - ‎2 authors hello, my kenmore washer doesn't complete the final spin cycle. i ... Does it stop in the middle of the final spin cycle or does it not go into the ... FIXED Kenmore Washer - Not finishing the spin cycle
Dec 20, 2014
FIXED Washing Machine Does Not Complete Cycle ...
Mar 14, 2013
FIXED Kenmore washer won't spin out all water from ...
Jun 27, 2009
FIXED GE front load washer WCVH6260F0WW stops ...
Jul 2, 2007
More results from
Nov 05, 2015 | Kenmore Washing Machines
My Kenmore HE2t washer is stopping about 8 minutes into the cycle (any wash cycle)..completely turns off. I can run rinse and spin then and it completes the cycle. No error codes when it turns off. W
htc sensor isnt working i would recon
perhaps the element isnt getting power
did it trip your circuit breaker
some times the htc fails
all you get is machine stop because the heater is not detected
if it spins rinses and empties in a timely manner
then all thats left is the heater system
Jan 09, 2015 | Kenmore HE2t 3.7 cu. ft. Front Load Washer
Adding liquid to rinse cycle
on your h-3 the soap disp tray will allow you the add powder ,liquid, bleach, or fabric softner at the time you put soap in disp then the water valve will dispence at proper times in the wash cyc you don't have to stop the wash cyc
Aug 26, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore 80's series top loader only works on wash and rinse cycle
This is a problem with the pump being stuck so the motor cant turn the whole thing. Turn the washer on its side, underneath you can acces the pump, which is connected to the motor by two long clips. remove the pump and take out the colg that caused it to get stuck.
Jul 01, 2009 | Washing Machines
Water will not stop filling for the wash or rinse cycles
OMG! Dude, what up cuz, down here in Mobile trying to solve my own washer problem!!! Tina Wow, talk about coincidence!!!
May 30, 2009 | Kenmore Washing Machines
Washer stops during rinse cycle and isn't easily restartable....
Sounds like the contacts in the timer has a problem. Unplug washer. Remove the back of the washer and spray WD40 in the timer. Put towels around and under to to collect excess runoff.
Rrotate washer dial 25 times and spray some more wd40. Rotate 25 times again. Do a wash load. If it works put everting back together.
May 04, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Kenmore elite washer problem
sounds as if you have a drain issue, most common cause of fault is theres something stuck in the pump housing. remove the lower acess panel(3 screws along the bottom of the forn of unit) youll gain acess to the pump housing, remove the large cover to the "button trap" by uncscrewimg the cover, it will be righthin front of you in the center of machine when cover removed, im sure youll find your blockage within there
Oct 29, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
870 people viewed this question
Top Washing Machines Experts
