Hi. I have never had to do this, but the settings for gross and net are usually in machine features settings, so go through the tables in your book and see if you can find a setting for it in machine features.
Use the PGM key and set to PGM. 3, sub total, enter tax table {1, 2, 3, 4}, Tax PGM, 13.00, ca/amt tend, skip to set 'round off/add-on', ca/amt tend, sub total. 4 tax tables are used for the following purposes: table 1 for the federal tax items, table 2 for the provincial tax, 3 and 4 for provincial and different tax table.
The easiest way to do this is to use Excel spreadsheet. This is what you need to do. Create a label at the top of each column as detailed. Add a employee to each row under Name of employee Then against each employee add the data and the formula in the relevant cell under each column.
The first column - Name of the employee 2nd column - salary rate per hour 3rd column - hours worked 4th column - gross pay (formula = salary rate X hours worked) 5th column - tax deduction 6th column - other deductions 7th column - total deductions (formula = tax deduction + other deduction) 8th column - net pay (formula = gross pay - tax - total deductions)
At the last row you can include a total for Gross salary paid, total Tax collected etc.
Once you have setup this spread sheet make a copy of it and save it as a template. You can then copy this template for each new financial year so you do not have to create a new one each year, you only need to make minor changes for new employees, rates of pay etc.
Another way to make a salary program is to use Access Database. You need more skills to do this, but it can provide greater reporting capabilities.
Hi. That could be tricky. we will need to go through the tax setup in your machine.
My first questions are:
1. Does it happen on all department (item buttons)? 2. Does it happen no matter what payment method you use (cash, check,credit)? 3. When you push Subtotal, does it show the wrong amount then, or only when you press a payment type to open the drawer?
To change the task number you must press and hold % (rate set) for 3 to 5 seconds, should appear tax XX %, now type your tax number and press % again and AC. To test type "100" press TAX + and the result should be 110, if your tax rate is 10% for example.
Press the CA button twice. Then push and hold down the %/set key until the 0 dissappearsd and reappears. Then type in your tax rate and the percent key (eg: 8.25%) and then press the TAX+ key. It should save the new tax rate.
1 press the AC button
2 hold down the SET /SET % / button for a few seconds
3 press the TAX + button
4 input the rate /in your case 6/
5 press SET button again
And you are done. You can also check it - press the Tax + button and the current tax rate will appear
