Question about Acer Aspire™ T180 PC Desktop
Can't Get Case Off
Hi!
Just got the T180 with the AMD 4400. Bought smoe more RAM and a vidro card, but can't get the case off. I've removed the rear screws and thumbscrews, but can't get the case to slide. an you help?
  • 4 Answers
Hello i also own this computer one takeing out the scres you will see a black think on the back just push it down and it unlocks the case : )
Posted on Oct 29, 2009
    Scholar:
  • 103 Answers
Remove the 2 screws from the side panel, Try sliding a flat head screw driver behind the face plate cover on the side of the case and and gently pry it backward. That should allow it to free up and slide easily.
Posted on Dec 15, 2007
HELP! Acer T180 is possessed!
Have you Googled the beep codes? This is most likely your solution. You should do the RAM test on your system.
Blue Screen Of Death
  • Remove all USB attached devices.
  • You may need to roll back system with System Restore. Under Safe Mode (press F8 during boot and choose safe mode). Start > Search type System Restore. Now choose a date prior to problem. You may have to try a few dates.
  • Uninstall last program(s) that was installed, again in safe mode.
  • Test one DIMM at time. One slot at a time. To eliminate possible bad RAM. Unplug PC. Opening case. Remove all RAM. Use static precautions!
  • Re-install Windows. Clean install works best. All data will be lost.
  • Lastly you may have other hardware problems. If it does another blue screen after reloading windows, especially with a clean install.
Oct 04, 2012 | Acer Aspire T180 PC Desktop
Hi, I have a newly installed desktop with Biostar A770E3 motherboard, AMD Phenom II X 4 945 3.0 GHz CPU, XFX GeForce 8600GT video card and Logisys case with 480W power supply. And Corsair 4GB X2 DDR3 RAM....
if you have a different video card try that, seems like the fan should spin on the video card. or pull the video card then reinstall see if that makes a difference beeps or something
Apr 20, 2017 | Biostar A770E3 AM3 AMD 770 ATX AMD...
I HAVE A HP PAVILION SLIMLINE (S5310F) AND WANT TO PUT IN A VIDRO CARD, SO I NEED A LARGER POWER SUPPLY. HOW DOO I DO THAT?
Replacing the Power Supply DEPENDING on the power needed? you might have to settle for a slower, weaker performing video card. Make sure you check the video card power supply specs needed.
Chances are you will max WATT at about 300WATTs less then what you'd need to power a gaming video card. OR you could do as I'd do.
Remove everything and place it all in a standard tower case - install a 650WATT power supply in to the new mid/full size case and BAM solution found.. Have fun and a great day to ya.
Oct 10, 2010 | HP (0950-3952) (09503952) 425-Watt Power...
Acer Aspire M5100 AM5100-U5313A AMD 4400 will not boot. Powers on but does not display boot sequence... Monitor acts like it is not hooked up... tried onboard card as well and pci express. I am thinking a...
Could be. Sounds like a repair shop issue if no system info is appearing.
This may be pointless, but try it anyway: -
It shows symptoms of RAM error, except it lacks warning beeps or led flash usually associated with this. Some PC's don't have this function.
Remove all RAM and replace one stick only, presuming you have at least 2 sticks. then try the same thing with the other sticks, one module at a time.
It's rare, but RAM does fail and it causes these symptoms. Also, if RAM is mixed and incompatible, this would also occur.
Mixing RAM may also kill the good RAM.
Next, check your PSU voltage readings ie 5v rails and 12 volt rails with a good quality multimeter. Or you might try another PSU.
Really need to have it physically in front of me to give a better answer.
Jan 13, 2010 | Acer Aspire M5100 AM5100-U5313A AMD...
Unplug MB just to turn it on?
I had this exact same issue and after much head scratching replace the power switch, fixed the problem
Mar 02, 2017 | ASUS MB M3A78-EMH HDMI RT Motherboard
Custom Building Gaming Question
yea man its a good set up I have the 7900 gforce I love it and i always love amd processors
Feb 13, 2009 | Dynex (DX-500CC) ATX Mid-Tower Case
Power to everything but CPU fan and case fan - won't boot
Hi this is tech crazy
The solution to the problem is as follows
The main reason for CPU fan overworking or not working is due to the load we put on the syatem while operating.So,the first reason for fan not working may be due to the SMPS malfunctionality.Better check out for it.The reason if fan is working but Overworking is due to viruses is system.So go in for format
Hope this solution helps you
Please do rate me on the above said solution
Feb 04, 2009 | Intel Motherboard
Trobleshooting
I had the same issue with my AMD Athlon 3800+ dual core. I found that I wasn't getting enough airflow to keep the system and processor cool. You may want to check the heatsink and fan rating for your processor unless it was sold in a bundle. Also, On AMD's of such power, they tend to run hot if overclocked. Look into, if you haven't already 2 case fans to go along with the processor fans. I recommend a 90mm in front and a 80mm in the rear of the case. If this doesn't help, let me know.
Mar 16, 2008 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
Video card
the computer should have the card in it. go to wal mart and look and some of them you will find one that will work. turn the computer off, take off the case, lay it on it's side take out the card, start up the computer, put in new disk, install software, turn computer off, lay it back on it's side, put the new card in, you will see how it goes in, case back on, start up computer. Your done!
Nov 26, 2007 | Acer Aspire™ T180 PC Desktop
Acer Aspire™ T180 PC Desktop Logo
168 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
