Yamaha RX-V461 receiver audio
Audio suddenly stopped. No input from remote or switches on console. Display is on . Checked all cables . Appear ok. All other components of home theater system work.
  • 1,512 Answers
Disconnect the unit from the mains at the wall socket. Leave powered down for 5 mins to ensure a good reset and turn unit on again and see what happens. If there is still no life. Check for failed fuses inside amp. ALWAYS RELACE FUSES WITH THE SAME RATING AND TYPE.
Posted on Dec 17, 2007
What are the surround sound settings for a yamaha rx-v461?
It has many, depending on the your speaker configuration, the source hardware and the source material...
Read the manuals...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Yamaha-RX-V461-Receivers-manual/id/2526ci760/t/2/
May 07, 2011 | Yamaha RX-V461 AV Receiver
RX-V461 Yahama Receiver is hooked up to TV with optical THX cable but can't get sound. Tuner on receiver plays and all speakers work perfectly for radio listening.
double check input used on amp and make sure u use the auto format decoder fuction on your amp ok if it has none than turn it on optical digital ok that should work for you :)
Feb 10, 2011 | Yamaha RX-V461 AV Receiver
How to connect a mic with yamaha rx-v461
hi,
for connecting a mic to ur receiver, u need a micro phone amplifier. connect the microphone amplifiers out put to any of the analog input of ur receiver( cd,aux). if u need information on connecting calibration mic then feel free to contact.
ok
Dec 22, 2010 | Yamaha Audio Players & Recorders
I own a Yamaha RX-V461 and since making a few changes, new Bravia TV and BLu-Ray DVD player, I no longer jhave sub woofer output. I bought a new sub woofer cable and even bought a new Polk 8" 300watt sub....
You can reset the settings to factory defaults via the Advanced menu - it should be in your manual (I have RX-V465).
Do it from the standby mode.
Press the STANDBY button on front panel (not remote) together with STRAIGHT button on the front panel. Now you are in the Advanced Setup. Scroll to the INIT menu and select ALL.
Now you will have all settings in the default.
Jan 24, 2010 | Yamaha RX-V461 AV Receiver
Need a hookup diagram for yamaha rx-v461 plus yamaha yst-sw216 please
Here you can find the manual for your subwoofer. Looking at its back side, it has 2 RCA plug input for stereo. Receiver has just mono sub output, but as low frequencies are not easily locatable, mono is perfectly OK.
Just connect receiver SUB-OUTPUT with RCA cable to your subwoofer's RCA LEFT input. Then adjust volume to match rest of your speakers.
Feb 21, 2009 | Yamaha RX-V461 AV Receiver
Problem hooking up my Yamaha RX-V461 to my PS3
When you connect the optical cable to the ps3 you must change the output to optical on the ps3. To do this, startup your ps3 then go to settings then audio output settings and change it to Digital Out (Optical).
Dec 01, 2008 | Yamaha RX-V461 AV Receiver
Help setting up Yamaha RX-V461
Typically, only stereo inputs exist on any comsumer-grade receiver, and the actual decoding to 3, 4, 5, 6, and even 7.1 is done internal in the receiver. When a "placement" signal is detected by the receiver, the sound is routed to the correct speaker.Please refer to a user manual
..accordianman
May 01, 2008 | Denon AVR-4802 Receiver
Yamaha rx-z9 can not get digital audio
If your receiver is saying you only have analog, it must not be able to see the optical input. Check your optical cable, maybe it is damaged or not tight.
Dec 09, 2007 | Yamaha RX-Z9 Receiver
131 people viewed this question
 Grubhead
Grubhead
