Question about HP LaserJet 1012 Printer
Printer paper comes out black when printing
All of the sudden when I request a print job, the paper comes out black with no image on the sheet. I have been getting SetConfig Application Error messages when I reboot HP computer... Is it a toner issue?? A printer issue?? Or a software issue??
  • raptorsbb Feb 06, 2008
    Can that be fixed?
There`s no power going through to the corona wire
Posted on Dec 30, 2007
Printer suddenly started drawing paper through without printing anything on it. cannot figure out why.
Click on start ,click on devises and printers. right click on printer image, click on troubleshoot , follow instructions.
May 21, 2015 | Canon PIXMA MX300 All-in-One Printer
HP 9050 MFP keeps asking for tray 1. Configuration is set to use tray 4 first, but everytime a print job is sent to the printer, it requests load paper in tray 1. How do I get this problem fixed?
You need to check the paper types you have assigned and the paper types that users are requesting. Print out a configuration page and make sure that Tray 4 shows as plain paper. If it does not then check all the stops. The 2000 sheet tray 4 units are noted for having the stops not engage and this causes the printer to think that tray 4 is custom media. You can also go into diagnostics and print a paper path test for each tray to ensure that all the trays are working.
Apr 21, 2011 | HP LaserJet M9050 MFP Printer
Printing
The Phaser 7400 starts at $2,799. see models and prices see cost per print Color: up to 36 ppm Black: up to 40 ppm First-page-out time as fast as 12 seconds 800 MHz PowerPC processor Maximum paper size: 12" x 18" All models come standard with 10/100Base-TX Ethernet connectivity Standard paper input capacity: 800 sheets Maximum paper input capacity: 3,000 sheets Finisher/stacker/stapler/hole puncher capable of handling up to 1,000 sheets Maximum duty cycle up to 150,000 pages per month What comes in the box show/hide contents Color toner cartridges (capacity: 9,000 pages each 1 ) Black toner cartridge (capacity: 15,000 pages 1 ) Imaging units (capacity: 30,000 pages per color 2 ) Waste cartridge (capacity: 30,000 pages 2 ) Fuser (capacity: 100,000 pages 2 ) Transfer unit (capacity: 100,000 pages 2 ) Finisher ships with 5,000 staples Power cord Software and documentation.
Aug 13, 2009 | Xerox Phaser 7400/N Printer
No black ink is appearing on paper
If this is an old printer. The nozzles might be clogged. A Q-tip with a little alcohol might get some of that dried ink out. Be careful it could get messy. Also see if your printer has a built in cleaning test. you might have to access the test from the printer tools on your computer.
Jul 30, 2009 | HP Officejet 5510 All-In-One Thermal...
First print job, first page jams on output area
Please note that paper absorve humidity, try to keep you equipment in a dry place.
When the paper is that condition, and while passing thru the hot image drum, the sheet hedges sometimes curves and jams...
Sorry for my bad english !
Jun 23, 2009 | Xerox 4150V_P Printer
The printer gives black sheets of paper
some time cartriage drum get short so fist of all check printout with new cartriage , if problem is net fix then
it is a scaner sction problem of yor printer
may be scaner laser diode is get shot
Apr 24, 2009 | Brother HL 5250DN Laser Printer
Using my HP 1000 I try to print a check and the page comes out black. Only the checks
You need to update your printer drivers or contact your printer manufacturer
Apr 15, 2009 | Intuit QuickBooks Premier 2009 Full...
Printer leaves black spots on paper
The black spots mean you either need a new imaging drum, transfer kit or fuser. You'll have to print some stuff and try to catch where the black marks are appearing. Try this method (it's called a Half-self test)
Load 2 -3 sheets of letter paper in tray one (manual feed) and remove paper from the rest of the trays.
From the information menu, request a demo page
The MOMENT the tail end of the paper disappears into the printer, open the right door. Open the front doors and release the levers for the imaging drum and the transfer drum. Carefully remove both pieces and examine your paper.
You should find the paper partway on the transfer belt but not in the fuser. If you see black marks here, start with the imaging drum. Open the shutter that covers the sea green shiny roller and look for marks on the drum (you'll see build up on the edges, that's normal, you should not see any scratches, pockmarks or toner on the center of the drum). If it looks clear, take a look at the transfer drum for marks or cuts on it's surface. (note: the transfer drum can be cleaned off with a dry lint free cloth, do not touch the shiny sea green roller of the image drum)
If everything looks good there, then likely the black marks are coming from the fuser. Let the printer sit, turned off for about half an hour to allow the fuser to cool. You can then remove the fuser and look at the rollers to see if there is any build up or damage there.
If you are not seeing any obvious issues with any of these parts, then start with the imaging drum. If you know that any of these parts have never been changed, then change them as they do have a limit to how many pages and how much time they can be used for.
Sep 16, 2008 | HP DeskJet 6540 InkJet Printer
Brother MFC 8500
Hi, Make sure the rear cover is closed. 2. Usually when you get misc symbols on the printed page the machine couldn't recognize the print job. I would try printing something from another file and see if the problem occurs.
Dec 01, 2007 | Brother MFC 8500 All-In-One Laser Printer
HP LaserJet 1012 Printer Logo
138 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
