Question about Philips 51PW9363 51" Rear Projection HDTV-Ready Television
Ic's stk 392-120
I have the 2 ic's but can't find what board they are on.Please advise as to location and are they plug in.they appear to be
  • salr Dec 15, 2007
    i paid for a premium assistance plan.haven't heard back and don't see it online.
    President:
  • 4,402 Answers
How do you know these are the correct ic?
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Jan 14, 2008
On my mitsubishi ws65909 I have a 2-2 power light error code, what does this mean? any suggestions, I tried to power it up and the power light comes on and then goes off after 15-20 sec's
the famous code error 2- 2 is for fault in power supply or faulty power supply board. this has to be checked.
and error 2-3 is fault in convergence ic.so both the error codes are near to each other.so check out both options. i advise first replace the convergence ic on the board and check.the cost of each convergence stk ic is near to $15 .there are two such ic on the convergence board and both has to be replaced.then check out.if the problem is same go for power supply board replacement.
the ic which you have to remove and replace is stk 393-110 both the ic looks same anve same number .
you can get the required board and components at ----- www.partstore.com -------- or from ------ www.radioshack.com ----
if you are not familiar with doing this you can get it done by local tv repair technician familiar with this model tv.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Nov 26, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Hi!! my sony projection tv kp-51ws500 shows double picture. there is reddish outline & its out of focus. i need help to reapir this. please advise. thanks
This sounds like a convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400
Sep 30, 2009 | Sony KP-51WS500 51" Rear Projection...
STK IC 392-110 Chips
am having stk 4392 amp board 2 channel, i want to change this two channel in to one channel. what modofication should i do
Dec 02, 2008 | Toshiba 42H81 42" Rear Projection...
Blinking colors
there is a stk ic in the tv.which is located on the main board of the tv.that stk ic has gone faulty so u r getting this problem. u can get this new stk ic for replacement at  radioshack websites.
Dec 01, 2008 | Toshiba Televison & Video
Hitachi 51UWX20B Projection TV
Hitachi part number JT23051 is Obsolete the new part number for the Deflection Convergence PWB is JT23051R its available from Hitachi for around 350.00
Oct 08, 2008 | Televison & Video
The Blue and Yellow colors on the left half of the screen(looking at TV) will not adjust correctly. Sony Rear Projection HDTV-Ready TV about 7 years old...
its the problem of convergence on your television.so resolder convergence STK ic's. if that does not work, change (STK-ics).
they ar located on the main power supply board and there are two such ics on the board replace both the ics.and easily available in the local electrical shop.
Sep 24, 2008 | Televison & Video
I'm experiencing different colors on the tv when displaying an image.
If these colors appear to be like a 3-D image, the problem is in the convergence circuit. Please update this with the make and model and I will provide you with further information and instructions.
Thanks,
Dan
Trying to find stk ic's
97c8712.jpg Stk's are on the back of those metal heat sinks
Sep 15, 2008 | Televison & Video
Green convergence, bad IC?
C8011 could definately cause the problem you are indicating as one side of that capacitor is tied to the postive feed for Red horizontal in IC8001 ( STK392-560) and the other is tied to the Green vertical return . I would replace that along with the IC as the IC is sure to be weakend if that capacitor has shorted. Let me know if you need further assistance.
Apr 08, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Sony HS30 Convergance Issue
The STK ICs are located on the D board their locations are IC801 and IC 802 they are both STK392-560 and you will only have to remove the D board. Usually only 1 or 2 resistors go bad right next to the ICs heatsink. You can get replacements at the following link and they include installation instruction plus free tech support heres the link.
http://servicemanuals.vstore.ca/
Apr 07, 2008 | Sony KP-46WT500 46" Rear Projection...
Philips 51PW9363 51" Rear Projection HDTV-Ready Television Logo
29 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
