All of a sudden the ice maker started to make a grinding noise. The noise stops when the door is open and light on, but once the door is closed or the little button inside the freezer is pressd to indicate the door is closed, the noise starts again. The noise sounds like a creaky door slowly opening. Not sure why it's doing this, but would like to know how to fix it. We took the ice bucket out and made sure everything was lined up. We also adjusted the auger driver and that didn't fix the problem either. The fridge is only 1 1/2 years old. Help!
Mine is the Jenn Air JCD2389GES , 3 years old and giving noises when we set the front panel to ice making mode. It is a continous ratle noise in the position of making ice or not ( up or down).Any help to solve this annoyance ?
clicking sound that goes up and then down in pitch. like a swing.
Comment by hmw666, posted on Dec 21, 2007
But, the blow dryer was a great idea. I will see if this reoccurs in a couple of days,
Thanks.
I hope to repay the favor by helping someone else in the future.
first ofall just feel around the icemaker and see if you can find a peice of ice jamming it that you can remove. if that doesnt work heat it up with a blow dryer until any ice that is there will melt away and it will free up..
there is one other possibility: the stripper could be jammed against the side of the icemaker in which case you'll have to remove the icemaker from the refrig and unjam it..
hope that helps and good luck
Post a New problem for Jenn-Air JBL2086HES Bottom Freezer
Email this problem
