Question about Panasonic DMR-ES10 DVD Recorder
Panasonic DMR-ES10 My 2 year Panasonic DMR-ES10 is not powering on manually or with my remote.
  • 5 more comments
  • Sherron Jacobs Dec 21, 2007
    I opened my unit and discovered a bulging capacitor and a small section of possible diodes darkened. I'd tried the fuse first and nothing but my plan is to purchase the capacitors and install them or contact panasonic for help with the repair.
  • Sherron Jacobs Dec 22, 2007
    Gopali,
    Nothing is on, the unit is totally dark, and without power. Checked the fuse and bought new ones, nothing until noticing the capitor bulging and a darkened area nearby. Contacted Panasonic by email with no response yet. Thanks for your help but I think the solution is in purchasing and installing capacitors.
  • Peamasher Jan 02, 2008
    I seem to have the same problem as Shebb- the unit seems to be 'dead'. I have checked the fuse in the plug and it is ok. Two local repairers have told me, over the phone, that it is not repairable. It has lasted only a few months longer than Shebb's.
  • Anonymous Apr 21, 2008
    My Panasonic dmr es10 went dead while watching a dvd.
    The screen went black the clock came on and off about 3 times and everything went black.
    The fuse is good and tried a diff cord.
    It died the end of 2007 and was less than 2 years old.
  • rainbow80 May 26, 2008
    My two year old Panisonic DVD recorder DMR-ES10 was working fine when I went to bed last night, but this morning it is completely dead. I tried turning the main power off and on and switching plugs.....nothing is working. I am completely NOT knowledgable about electronics, I guess this means I better get new one?
    Dammit.
  • wild bill 08 May 11, 2010
    which capto replace in the es-10?
  • Anonymous Mar 13, 2014
    User manual for Panasonic DMR E700BD
ES10 Dead Same problem
Easy fix replace capacitor exact match not req, i replaced mine with 1000uF 25V105C (just 50C at WWW.allspectrum.com). Works perfect now.
sk
Posted on Mar 15, 2008
The problem is absolutely in the power supply and there is a bulging capacitor. I had the same problem with a HE DVDR 960 DVDrecorder that did not work but I saw three bulging capacitors, changed al three with second hand capacitors from a computer motherboard and it works again,
Succes with the repairing of your recorder
Posted on Jan 09, 2008
  • 39 Answers
Std by light is on?means red light is on.If not than check fuse,vdr,and regulator ic in power unit.if fuse is open than change these component because fuse will blow if the regulator ic is faulty.
Posted on Dec 18, 2007
3 Suggested Answers
tvservice306
  • 458 Answers
SOURCE: Panasonic DMR EZ47V Remote
EUR7659T70 REMOTE CONTROL 31.35https://www.pstc.panasonic.com/Epartr/PartsListChoice.asp?validate=1
Posted on Aug 18, 2009
  • 10 Answers
SOURCE: Panasonic DMR-EZ28 won't talk with remote
hi you need to reprogram the remote to fit with the unit there have 3 codes for remote 1 or 2 or 3 to reprogram your remote with the code indicated on your display press and hold the [3] and [ENTER/OK] buttons together for approx 5 to 10 seconds, then release
Posted on Sep 06, 2011
Need to find a manual for remote eur7721x10
Since the EUR7721x10 remote shipped with specific Panasonic DVD/VCR units, the manual for the DVD/VCR recorder may give you the information that you need. One of the models is the DMR-E75V. Panasonic has the manual on the product support page: http://shop.panasonic.com/support-only/DMR-E75VS.html?supportpage=true . The direct link to the manual is http://service.us.panasonic.com/OPERMANPDF/DMRE75V.PDF . The remote buttons are described on page 6; the TV codes are given on page 17. (Note: these codes will probably only work on TVs that are older then the programming in the remote.)
I do not know of any available manuals for the remote that are separate from the DVD/VCR Recorder manual. I hope this helps.
Jun 30, 2015 | Panasonic Remote Control EUR7721X10...
Panasonic DMR-EZ47V DVD Recorder / VCR Combo RC1 errior message how do I fix this problem
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/model.DMR-EZ47VK
http://www.retrevo.com/support/Panasonic-DMR-EZ47-DVD-Players-manual/id/2811ag420/t/2/
To get into Service Mode, first put the machine in STANDBY mode, then press the buttons ChUp OPEN/CLOSE and REC all at the same time on the front panel (Ch Up is hidden inside the AV3 input flap). Eventually the front panel display will show "SERV" (after its "HELLO" messages). Anyway, pressing [6] then [5] on the Remote Control tells me that I have an Error Code of "04" which is a Digital PCB or Communication Error (whereas an Error code of "02" means a "Defect of RAM drive"). (To exit from Service Mode, press [0] then [0] which should get you back to "SERV" and then POWER-OFF the machine).
Hopefully, your manual will display your error codes.
Perhaps the remote control is not set to the same control code as your DMR-ES40V. Codes may be set to 1, 2, or 3 on the remote by holding down the enter button and one of those number buttons for several seconds at the same time. The factory default is code 1. Try 1 first. If that doesn't work try 2. If that doesn't work try 3. If one of those codes doesn't work you may have a bad remote or a bad sensor on your machine. On DMR-ES35V models the sensor is located just to the right of center behind the black window
Jun 23, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
Jun 24, 2009 | Panasonic DMR-EZ28K DVD Recorder
Any1 know how to unlock Panasonic DMR-EX768EB to multi region??
Hi
Get an unlock device DMR-EX768 (never mind the EB) from www.genuinecopies and follow the instructions. On the handset the red square in the bottom row is the STOP/EJECT
Mark
Feb 14, 2009 | Onkyo DV-CP704 DVD Player
Panasonic dmr-e55 won't work, just says "hold" on display
HOLD or X HOLD? If the latter - which is most likely - then the Child Lock has been activated! Press and hold ENTER and RETURN simultaneously until HOLD disappears!
Jan 22, 2009 | Panasonic DMR-E55 DVD Recorder
Re: Panasonic Remote Control for DMR-ES35V
All you have to do is unplug the power cord from the unit, wait 10 seconds, and plug it back in. The reboot will make your remote work again. Actually, it is the UNIT that is faulty, not your remote.
Jun 25, 2008 | Panasonic DMR-ES35VS
Remote Controle Problem
You can get a replacement original Panasonic DMR E-50 remote from various suppliers on the net or on eBay - part number is IRC85049. Just google 'Panasonic DMR E-50 remote'
Jan 04, 2008 | Panasonic DMR-E50 DVD Recorder
Remote interacting with TV
According to my manual the codes for Samsung TVs are 31, 32 or 43.
Press and hold the TV on and off switch button.
Enter the two-digit code for your television set (while holding the TV power on the remote)
Nov 11, 2007 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Panasonic DMR ES30V DVD Recorder/VCR
take it to a tech to check the system control chip could be bad.good luck
Jul 06, 2007 | Panasonic DMRES30V DVD Recorder/VCR Combo
Panasonic DMR-ES10 DVD Recorder Logo
353 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
