My dehumidifier is 15yrs. old & has started making a loud shrill noise whenrunning(always set on normal). Also, its hot on the backside. The cord is hot also. Iunplugged it.
a change in tone of the noise from a working unit indicates to me that a bit of dust/dirt has built up on the internal fans blades and has caused a imbalance in the fan now , this usually requires a complete disassembly and cleaning out to remedy
Hello, Consumer. We're sorry to hear about the difficulty with your dehumidifier. Below are links to our Use & Care guides, Parts Diagrams, Troubleshooting information and the Service are of our website. We hope this helps! http://bit.ly/112Lu7q
If the unit is not running fully, but you have this noise, sounds like the internal fan might be the culprit. Contact your manufacturer for further options.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
When the compressors start to go bad they often start to get very loud also...the cost to replace the compressor will probably be more then a new unit...
Also check out this tip about dehumidifier problems...
Hi, When the compressors start to go bad they often start to get very loud also...the cost to replace the compressor will probably be more then a new unit...
Yes they should last longer than that, but the sad thing is that they don't make anything like they used too...just check out all the problems in this site for a few minutes...most of the problems should never happen...
Mine does the same thing, for the third time. Seems the plastic fan on mine, lasts a little over a year. Not hard to change, just a bad design on the part. I'm ordering an extra tis time, to save on freight.
