Question about HP OmniBook XE3 Notebook
I forget my bios password
I want load my operation system but i can not pass my bios passwod because i forget it ?
  • 1 more comment
  • Anonymous Jan 07, 2008
    WHEN L TOP IS TURNED ON IT ASKS FOR HDD PASWORD IT IS A PACKARD BLR1935
    laptop keeps asking forhdd pasword it is a packard bl r 1935
  • Anonymous Jul 17, 2008
    The same problem
  • 383 Answers
Answer: If you have mistakenly forgot or lost your BIOS password or you receive a password at boot that you do not know, you will need to clear the BIOS password by one of the below methods. Precaution: When inside the computer please be sure of the potential of ESD.
  • Try using generic BIOS passwords. A complete listing of these passwords can be found on document CH000451.
  • There are utilities designed to help bypass BIOS passwords. An example of a great utility to decrypt / bypass BIOS passwords is the PC BIOS Security and Maintenance toolkit, which is available by clicking here.
  • On the computer motherboard locate the BIOS clear / password jumper or dipswitch and change its position. Once this jumper has been changed, turn on the computer and the password should be cleared. Once cleared, turn the computer off and return the jumper or dipswitch to its original position.
The location of the jumpers or dipswitches may vary; however, here are general locations where these jumpers / dipswitch may be located.
  1. On the edge of the motherboard - Most jumpers are located on the side of the motherboard for easy accessibility, verify by looking at all visible edges of the motherboard.
  2. By the CMOS battery - Some manufactures will place the jumper to clear the CMOS / BIOS password by the actual CMOS battery.
  3. By the processor - Some manufactures will place the jumpers by the processor of the computer. However, note that in some cases these jumpers will be to change the processor and not the password.
  4. Under the keyboard or bottom of laptop - If you are working on a laptop computer the location of the dipswitch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment.
  5. Other visible location - While it is possible that the jumpers / dipswitches may not be in a visible location, most manufactures try to make things easier by placing the jumpers / dipswitches in another visible location.
Additionally, when looking for the jumper / dipswitch the label of that switch can be anything; however, in most cases will be labeled CLEAR - CLEAR CMOS - CLR - CLRPWD - PASSWD - PASSWORD - PWD.
  • On the computer motherboard locate and remove the CMOS battery for at least 10 minutes allowing the computer to lose its information. Note: this will not work on all computers.
  • If your manufacturer has a bypass password this can be entered and allow you access to the BIOS and/or computer. Because of the security risk of a bypass password, generally only older computers will have this option. In addition, it is likely that this information will only be able to be obtained from the computer, motherboard or BIOS manufacturer.
  • On the computer motherboard locate the CMOS solder beads and jump the solder beads to clear the password. The identification and location of these solder beads can vary and if not available in computer documentation is generally only obtainable through the computer manufacturer.
If one of the above solutions do not clear the password or you are unable to locate the jumpers or solder beads, it is recommended you contact the computer manufacturer or motherboard manufacturer for the steps on clearing the computer password.
Good Luck, this should get ya back on line/Please dont for get to Vote.Thank You.
Posted on Dec 15, 2007
How can i have the password bios of laptop dell E6420
f you are running Dell servers, it is recommended to enable BIOS password. This is will prevent accidental changes done to Dell BIOS settings by others who get physical access to the server.
You can setup two different types of passwords in Dell BIOS:
System Password: This will be prompted before the system can boot up, and load the operating system.
Setup password: The system will prompt for this password only when you are trying to access the BIOS settings.
Depending on your situation, it might be a good idea to enable both the system and setup password at the BIOS level. I recommend that you at least enable BIOS password.
Press F2 for System Setup
When the Dell server is booting up, press F2 to start system setup, from where you can change Dell BIOS settings.
BIOS System Security
From the Dell BIOS main menu, scroll down to "System Security" and press enter.
Password Not Enabled
From here, you can see that both the System and Setup password is not enabled by default.
Enable System Password (and Setup Password)
Scroll to "System Password" and press enter, which will prompt you to enter the password that you like to set for the system. Please understand that if you set this password, you have to enter this password everytime you start the system. Do the same thing for Setup Password.
Don't forget this bios password. If you forget, then you have go through the painful process of resetting the Dell BIOS password.
Password is Enabled
Once you've enabled both the password, from the "System Security" menu, you'll see that that both system and setup password is enabled as shown below.
password is set
System Password Prompt (During Startup)
From now-onwards, anytime you start the system, it will not load the operating system, unless you specify the system password as shown below.
12345
Setup Password Prompt (To Access BIOS)
If you press F2, to get to the BIOS, it will prompt for the setup password as shown below. If you don't enter a valid password here, you cannot access the Dell BIOS settings anymore.
Dec 16, 2014 | Dell Latitude E6420 Laptop Computer...
Toshiba sattelite 1905-s301 master codes or passwod by-pass. forgot passwords to unlock computer for use and also forgot my bios password causing computer to keep running the start-up screan, safe-mode,...
I think if you do not have a recovery disc then the operating system needs to be reinstalled. It is also possible that the system needs a virus scan if there was a case of malwares within the PC.
Oct 16, 2011 | Toshiba Satellite 1905-S301 Notebook
My dell(my brothers who passed away some few months) needs a bios password----sysytem or adminstrators passwod before booting the model is Dell Vostro A860 servive TAG number BFY2WG1. the machine will...
I am very sad to hear about your brother. My condolences. In order to remove the bios password, you need to remove the CMOS battery from the laptop. To do this, you must:
Remove the power supply and the battery from the computer
Open the laptop up
Look for the CMOS battery. It is a small silver battery in the shape of a disc; similar in size to the face of a watch.
Remove this battery, and hold the power button for ten (10) seconds to drain any residual charge inside the computer.
With the battery removed, boot up the computer; it should say "password disabled"
Reinstall the battery. Your computer should now be restored to full functionality. Please don't forget to rate this solution.
Mar 30, 2011 | Dell Latitude D610 Notebook
I forgot my password to my netbook
click alt ctrl delete then type admistrater press enter
please vote me
Feb 07, 2011 | Asrock Computers & Internet
Passe word bios compaq 6735s
go here http://www.pccmos.com/
download the image file burn it with imgburn or any other software after that boot with the CD and follow the instruction to remove the password
Jul 03, 2010 | Compaq Computers & Internet
Acer aspire 2920 bios password removing
The password to by-pass bios password are these, hope they will hope you, once you enter BIOS using these passwords you can reset it to normal
Phoenix Backdoor BIOS Passwords:
  • BIOS
  • CMOS
  • phoenix
  • PHOENIX
Mar 18, 2010 | Acer Aspire 4720 Notebook
Are there any free pass recovery
Visit ophcrack.com
Download the live cd for Windows XP and burn it onto a disc. Insert the disc into the machine where you need the password and boot from CD. It will take you to a mini Linux where an automated software will try to break your password.
PS : Always remember to have a passwod reset disc.
Oct 08, 2009 | Microsoft Windows XP Professional SP2
I get the message 'error loading operating system' everytime i start my computer, when i do start it it says to press DEL for setup, when i press this a blue screen appears and a passwod box appears in red...
The Setup option is for your BIOS , heres a link to resetting the BIOS password if you want to access it.
but as for the error loading operating system you will need any setup disks or recovery CD's that you got with your computer, preferably a Windows Installation CD , then you will have to insert the CD restart and let the computer boot from the CD and reinstall your operating system.
Apr 08, 2008 | Computers & Internet
HP OmniBook XE3 Notebook Logo
1,446 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
