Question about LG VX5200 Cellular Phone
Broken main screen
I cant see anything on my screen, and I just found out about Backup Assistant as I tried to replace it. Can you walk me through what I need to press to get to the Backup Assistant on my phone? I know how to do the online stuff, and I can get to the "Get it Going" menu. Beyond that, I can't tell where to go.
  • 41 Answers
Well i have the same phone and i ended up replacing it because there was an factory default so if i were you i would see if there was any warrenty left on the phone and get it replaced
Posted on Dec 15, 2007
Backup samsung convoy contacts to pc
Because of the importance of transferring contact information from one communication vehicle to another, there are a number of different automated ways to transfer contact information. To import contacts, such as VCF files from computer to Samsung Galaxy S9/S8/S7/S6/S6 Edge, you need to ask help from an Android data transferring program named MobiKin Assistant for Android or Assistant for Android (Mac Version). With it, you can move contacts between your Samsung Android phone and computer in 1 click.
Step 1. Click the above button to download and install MobiKin Assistant for Android on your Windows or Mac computer according to its prompt instructions. Then, launch it directly. After that, you'll be required to connect your Android phone to computer with USB cable or WiFi. Just choose the method for connecting as you like.
Step 2. After connection, you need to do some operations to make the device be recognized by the program. For example, you need to open USB debugging under "Developer" option, and install a right USB driver on the PC. (Sometimes you may need to install the USB driver manually due to unknown reasons when the automatic operation is not working well.)
Step 3. When your Android is recognized by the Android Assistant software, you can see an interface like below. Now, directly click "Super Toolkit" in the top menu, and select "Backup" option.
Step 4. Check the device and click "Contacts", then specify an output folder according to your needs. After that, click "Back Up" button to begin the process. backup-android-files-uwkecbqhxdnurjdgs33nmwp2-4-2.jpg
Complete procedure can be found on below link: 5 Ways How to Backup Android Contacts
Learn More:
How to Import Contacts to Samsung Galaxy S9 S8 S7 S6 Edge
Dec 21, 2012 | Samsung Convoy Cell Phone
Sanyo DP42848 screen goes blank after few seconds have replaced main board both converter boards power supply has all voltages screen showes connect all cables or channel up or down when first turn on then...
I had the same thing happen to a DP42848 I'm repairing but I could smell ozone on the left side so I didn't replace anything. I just disassembled the screen and found four flouresent tubes not working! I exchanged them to be sure it was the tubes and it was.New screen is out of the question. I am trying to find a broken used LCD screen somewhere and rob the tubes from it as they just snap in and that might not happen so goodbye tv!
Oct 11, 2011 | Sanyo 42 in. LCD TV
Screen says ram cleared
When the calculator is turned ON, power to refresh the RAM is supplied by the main batteries. However, when it is OFF, the RAM relies on the backup battery to keep itself refreshed.
If you get the RAM CLEARED message whenever you turn calculator ON, it most certainly is due to a depleted backup battery. You will have to replace the backup battery.
To avoid losing anything important from RAM (what do I say, you are already losing the contents of the RAM), make sure that main batteries are still good, then replace the backup battery.
You can verify the state of the main batteries in a battery tester or by connecting the calculator to the computer with TI USB Silver cable and TI Connect software. If you run into problem such as calculator not recognized it is most probably due to weak batteries.
When you connect it to computer try updating the OS if OS version to 2.53 MP or a more recent one..
Aug 30, 2011 | Texas Instruments TI-84 Plus Calculator
Need step by step instructions on how to save contacts to sim on a nokia n95 with a broken screen phone still turns on but cant see anything
Hi, as the LCD screen of the Nokia N95 is broken, I suggest that you use Nokia PC Suite to backup the Contacts to the Computer.
Please download the Nokia PC Suite from the below link:
http://www.nokiausa.com/get-support-and-software/software/nokia-pc-suites
Apr 13, 2011 | Nokia N95 Cellular Phone
The screen on my TI-83 Plus says, "RAM cleared" and won't do anything. It has the curser after I press "ON", but won't do anything else. I tried holding clear, holding ON, hitting it, etc. Can anyone...
When you connect it to computer try updating the OS if OS version is not 1.19.
Mar 02, 2010 | Texas Instruments TI-84 Plus Silver...
Insignia NS LCD32 no power
If one is domed on top and there several other of the same value replace them also even if not domed. Check fuse on power board. When plugged in there is a constant 5 volts that will be going to the main board from the power board. The main board will send a turn on voltage to the power board from the main. Disconnect the inverter boards from the power board. If it still won't turn on replace the power board.
Nov 22, 2009 | Televison & Video
NEED TO SAVE MY ADDRESS BOOK ON MY SIM CARD,BUT SCREEN IS BROKEN AND CANT SEE TO DO ANYTHING..HOW CAN I DO THIS..
this is all different per phone, so you need to say which samsung it is
but if you take it into a store they should be able to assist you and transfer the contacts to a backup
Nov 10, 2009 | Samsung Cell Phones
I can hear but I can not see anything on the screen. The screen mantained black. Could you please help me to find out what happen?
the screen is most likely broken or connector is loose.
here is the apple online service assistant
https://selfsolve.apple.com/GetWarranty.do
you can also try a reset which is found here
http://www.fixya.com/support/r561901-ipod_problems_start_5_solutions
also here is another possible place to get your ipod fixed incase apple cots too much.
http://www.ifixipodsfast.com/
Jun 14, 2008 | Apple iPod nano 3rd Generation
Iriver h10
Reset
Reformat
Use Recovery Tool from iRiver website
Jun 02, 2007 | iRiver H10 MP3 Player
LG VX5200 Cellular Phone Logo
197 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
