Question about Epson Stylus Photo R320 InkJet Printer
Epson Stylus r320 photo
I have an issue with one of my print heads. the dark cyan has blank spots on the test print and i have exhausted my options for having the machine clean it. It just won't fix the problem. their tech support just offered me a discount on a new one instead of fixing it. I would like to fix this and was wondering if there was a better way to clean the print head to see if that helps.
Thank you, Ed
    Problem Solver:
  • 4 Answers
Hello Ed,
I believe I can help. I happen to have the same printer. My printer was unused for about a month and I could not get the black to print. What happens with these ink jet printers is that the ink drys out and becomes clogged in the print head and other jets. The spray orifices are extremely tiny.
I have a unique method of handling these problems that "usually" works. Here's what you can try.....
1), Get a paper towel
2). Set the ink cartridge to the setting where you remove the ink cartridges and can slide the print assembly back and forth.
3). remove ALL the ink cartridges
4). Fold the paper towel into a rectangle that is 1 inch wide and about 4 inches long) it should be like a fat pillow.
5). saturate the paper towel with clean water.
6). Position the saturated paper towel underneath the print head so that it is pressing against the bottom side of the print head where the ink would spray out on the paper. (It is crucial to get the damp paper towel into contact with the print jet's lower discharge surface. Make especially sure you get it under the clogged (non functioning color position).
7). allow this to set overnight.
8). The next day, remove the paper towel. Whatever color was giving you trouble printing, you should see that color ink in the paper towel. This is because the dampness has loosened the dried up ink. You may also see other colors too.
9). Re-install your ink cartridges and try it again (you may have to do 1 clean cycle but often it isn't even necessary.
This has worked like a charm for me over and over again. No guarantee it will solve your particular problem but it's easy and worth a shot and has returned my R320 to perfect service after sitting for long periods. (You can also leave a moist paper towel under the heads when not in use to prevent clogging). But IMPORTANT...if you don't remove the ink cartridges, the paper towel may pull all the ink out..
Jolly Chollie
Posted on Dec 16, 2007
Epson Stylus Photo R320 InkJet Printer not printing black or yellow
I had same problem, fixed mine like this... just choose the head cleaning option and run this about 5-10 times in a row takes about half hour or twenty minutes but it starts printing black eventually.
Dec 27, 2010 | Epson Stylus Photo R320 InkJet Printer
Printing Streaky
Most likely the printer has been sitting for along time not used or you have used cheap replacement ink. Epsons are notorious for clogging the jets with cheap ink. unfortunately replacing the ink cartridges will not help because the jets are seperate from them. If cleaning numerous times does not work your next best bet is to buy a cleaning ink cartridge for your model. otherwise youll need a new printhead or new printer. If your going to use cheap replacement cartridges stay away from epson.
Jun 16, 2009 | Epson Stylus Photo R320 InkJet Printer
Epson Stylus Photo R320 - How to print to inside hole of DVD
In Epson Print CD program go to File ->Inner/Outer Diameter Settings. Set the inner diameter to the size you want.
Nov 22, 2008 | Epson Stylus Photo R320 InkJet Printer
When you run the nozzel check, do each of the colors print out right, or just the magenta ones?
Oct 28, 2007 | Epson Stylus Photo R320 InkJet Printer
Print problem with Cyan cartridge
i had to run 10 cleaning to get a printer to print magenta. finally it cleaned it self..it gets expensive..leaving your printer on keeps the in nozzles clean..when its off for long periods it dries in the nozzles.
Oct 14, 2007 | Epson Stylus Photo R320 InkJet Printer
New Canon Rebel xti photos won't print on my Epson Photo R320
Re-install the printer after downloading the latest driver from Epson. It is quite likely that the Canon software has over written the colour profile for the Epson.
Sep 16, 2007 | Epson Stylus Photo R320 InkJet Printer
Color is not correct in printing
it is possible that you have a clogged nozzle this is not a user serviceable part, you'd pretty much have to bring it in for service
Sep 26, 2006 | Epson Stylus Photo R320 InkJet Printer
Epson Stylus Photo R320 InkJet Printer Logo
341 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
