Question about SanDisk Sansa e200 MP3 Player
Please help me?
After putting 2 videos on my sansa e200 i took it out out the computer and after that it said "refresh database" but it stop 75% along the way and i could not use it please help me fix it
  • 2 more comments
  • Anonymous Dec 18, 2007
    when i unplugged my sandisk sansa e200 from my computer its says refreshing database and stop about a centimeter from the begining of the bar
  • d0lph1n136 Dec 25, 2007
    same problem....
  • Anonymous Jan 01, 2008
    Hey everyone,i have the same problem i was putting music in my sansa e200,and when i unplugged it reads ''refreshing database'' and then the screen turns either blue or green it only gets half way every time,somebody help.
  • DonHill Mar 02, 2008
    Same issue. I tried deleting all the files and reloading a few (10-15) at a time and the e200 would refresh OK. But now, after a few hundred files are loaded, the same thing happens.
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 26, 2008
Refreshing database
User guide for Sansa e200R:
http://mp3support.sandisk.com/downloads/um/e200r_userguide_en.pdf
Check this link for Sansa e200 "freezing in refreshing database",
2 steps to follow up:
http://kb.sandisk.com/app/answers/detail/a_id/34/kw/e200r%20freeze/r_id/101834
1. Reset the device as described on the site of Sandisk.
http://kb.sandisk.com/app/answers/detail/a_id/189
If resetting didn't solve your problem
2. Update the firmware.
http://kb.sandisk.com/app/answers/detail/a_id/306
2.1 Use the Sansa Firmware Updater for a download of your device
with the next link:
http://mp3support.sandisk.com/sansa/Application/SansaUpdaterInstall.exe
2.2 Follow the instructions "update the firmware" for sansa e200 series:
http://kb.sandisk.com/app/answers/detail/a_id/306/kw/e200r%20freeze/r_id/101834
Sep 20, 2009 | SanDisk Sansa e250 MP3 Player
Frozen sansa at refresh database
This is from the Sansa Website at http://www.sansa.com/support/sansa_e200/faqs
My e200 freezes on the “Refreshing Database” screen
STEP 1 – Reset the device
  1. Press the Power button and hold it for approximately 10 seconds.
  2. Release the Power button once the device is powered down.
  3. Turn the device back on.
STEP 2 – Download and Install the Sansa Firmware Updater
I this helps please dont forget to rate my answer.
Mar 07, 2009 | SanDisk Sansa c240 MP3 Player
MY SANSA HAS BEEN STUCK IN THE REFRESH DATABASE MODE AND WILL NOT TURN ON NOR OFF . IT WONT EVEN CHARGE EVEN THOUGH IT IS SHOWING A FULL BATTERY HELPPPPPPPPPPPPPP THANK YOU MRS.C.L.C.
Mar 07, 2009 | SanDisk Sansa e250 MP3 Player
My sansa e250 keeps shutting down
switch the usb mode which ever one is highlighted first chose the other and then it will stop refreshing
Feb 19, 2009 | SanDisk Sansa e200 MP3 Player
(e260R) Refresh Database eternal loop
Turn it on into recovery mode (Hold + Record Button + Power)
Connect to computer (You should detect a 16MB drive)
Make an empty text file inside the 16MB Drive and rename it to "sansa.fmt"
Unplug the Sansa. You should see now a "Formatting..." on the Sansa's screen.
Sansa fixed!
Sep 13, 2008 | SanDisk Sansa e200 MP3 Player
Sansa e200 shows refresh database fail
try putting it in MSC mode and formating it and then putting back on MTP mode. Hope that works
Aug 24, 2008 | SanDisk Sansa e250 MP3 Player
IT TOOK MY MEMORY!
have you deleted the partial video, if not......
1. connect the sansa to your computer,
2. select open device with windows explorer,
3. click on the drive where the video content is stored,
4. click on the video folder, then right click on and delete the video,
the path,
My Computer/Sansa e200/SELECTED DRIVE/video
May 05, 2008 | SanDisk Sansa e200 MP3 Player
Sansa e200 locks up in refresh database during startup
if the computer can find ur sansa(or 16mb format) you should rightcliick and format it. this will delete ur music, videos, etc but it will make ur player usable
Mar 17, 2008 | SanDisk Sansa e200 MP3 Player
Refresh database
Sansa e200 provides a RESET function for unresponsive units. Press and hold the MENU button for 15 seconds, and this should work to regain normal funtionality. Please note: settings and adjustments from the last operation WILL BE LOST. The files however should remain.
Sep 19, 2007 | SanDisk Sansa e200 MP3 Player
My sansa is stuck on refresh database
Turn it to recovery mode by putting it on hold, while off, and holding the record button along with power until it go's into a screen with a black background and white text. Then update it with the updater. You can get it here: http://sandisk.com/Retail/Default.aspx?CatID=1376 NOTE: Updater will NOT work on windows vista. Good luck and i hope this fixes it! Have a nice day!
Jul 17, 2007 | SanDisk Sansa e200 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
19 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
