Whirlpool Duet GHW9150P Front Load Washer Logo
Posted on Sep 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
CONTROL LOCK BUTTON IS ON CANT START WASHING
CONTROL LOCK BUTTON IS ON CANT START WASHING MACHINE
Anonymous
Level 2:
  • Expert 64 Answers
  • Posted on Sep 22, 2009
Anonymous
Expert
Level 2:
Answers
64
Questions
Helped
15030
Points
181
Go back & foroth acouple of times on the pause & start button
How do I stop my washing machine door alarm beeping?
do this and fix it. God bless you
However read the instr. manual section troubleshooting /
if doesnot have download from www.fitness.manualsonline.com
The processes below will get most controls unlocked.
Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 15 seconds.
Some Models- Press and hold the control lock button for 15 seconds.
If none of these work try unplugging for 5 minutes
Power to machine but will not start a cycle
If child lock has been activated, all buttons on the control panel except for the power button will be inoperable. Child lock is usually activated by pressing either the [pre-wash] or [tub clean] button for 3 seconds. To deactivate the child lock function, press and hold the same key again for 3 seconds.
Try switching the machine off by pressing the on/off button. Press the same button after a few seconds to restart the machine.
Mercedes Parts
How do I use the Child Lock option on Samsung WF-B1456GW?
You can use the child lock feature in 2 ways.
1. To prevent operation of the washing machine when no wash cycle is running
To set this feature, switch the machine on using the POWER button at the top-left of the control-panel. Next, press and hold both the SPIN and RINSE buttons for about 3 seconds - until the child lock light indicator on the control panel illuminates. All functions of the washing machine will now be disabled apart from POWER ON/OFF until such time as the child lock is deactivated.
To deactivate the child lock, press and hold the SPIN and RINSE buttons again until the child lock light indicator on the control panel goes out.
2. To prevent any tiny fingers from tampering with the machine while a program is running.
After pressing the START/PAUSE button to start the wash cycle, press and hold the SPIN and RINSE buttons until the child lock light indicator illuminates. All buttons on the control panel will now be disabled until the child lock has been disabled. When the wash cycle has finished, you will need to switch the child lock off again to reactivate the buttons. Once you have finished using the washer, reactivate the child lock again before switching the power off as above.
The feature can also be used when using the delayed start feature, but needs to be set after pressing the START/PAUSE button.
Hope this helps. Please let me know if I can be of further assistance.
Regards,
BElectric
My control lock button is on and cant get it unlocked to start machine!
Press the end of cycle signal- button for 3 seconds and it is ready to go.
The control lock button is on. Can't start washing machine
Locate the button(s) on the control panel with a small "lock" icon and press and hold for about 5-10 seconds.
I have managed to key lock my machine somehow and
Try holding the ON/OFF button for 5 seconds.
10helpful
2answers
Control Lock light is on. Cannot get it off. cannot run washer
To unlock the controls Select and hold END OF CYCLE SIGNAL for 3 seconds until the CONTROL LOCKED Status light turns off.
2helpful
My control lock is on and my machine will not turn on.
Press & hold the 'end of cycle' button on the right side of panel for 3 seconds. Child lock button, you do the same thing again & it locks. You dont want kids bathing in the machine, no. Pl rate me nice.
3helpful
2answers
''Control Lock'' won't ''unlock''
Press and hold the "End of Cycle Signal" button to lock or unlock the control panel. The instructions should be printed directly below this button. I hope this helps you.
2answers
Child lock light stays on - & cant start mc programmes
HI I KNOW IT SOUNDS DAFT BUT HAVE YOU TRIED SWITCHING THE CHILD LOCK OFF? I CANT REMEMBER EXACTLY WHICH BUTTONS IT IS ON YOUR MODEL BUT YOU USUALLY HAVE TO PRESS 2 BUTTONS AT THE SAME TIME (& SOMETIMES HOLDING THEM FOR A COUPLE OF SECONDS) RATHER THAN JUST 1 TO SWITCH THE CHILD LOCK ON/OFF. IF YOU STILL HAVE THE INSTRUCTION MANUAL IT WILL TELL YOU WHICH BUTTONS YOU PRESS TO SWITCH CHILD LOCK ON/OFF HOPE THIS HELPS!
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
